Old 03-28-2013, 09:14 AM   #25
jar944 OP
jar944's Avatar
Oddometer: 712
To make this bike even more unique i'm attempting to add a core exp clutch. Rekluse does not sell a core exp for the 500, and it may not work due to the low rpm TQ. The only one off part will be the clutch cover. It will require machining up a deeper clutch cover to clear the thicker clutch assembly.
as for the parts:
rekluse RMS-7711 kit with out the deep clutch cover (would not fit)
with the addition of
442-112 PRESSURE PLATE SPRING - EXP (heaviest available)
RMS-268 WEDGE KIT - EXP 2.0 Heavy (heaviest available)
and for the basket
Barnett basket 321-35-01004
Hopefully it will lock up early enough as is and I will not need to add tungsten to the wedges. If it does not my first plan is to replace all the 36 of the 3/16 steel bearings with tungsten carbide.
Failing that I'll be drilling the wedges for more tungsten alloy.
wedges:
core exp
jar944 is offline   Reply With Quote
Times are GMT -7.   It's 06:27 AM.
