Old 03-28-2013, 06:29 AM   #4051
billfires
Oddometer: 45
Has anyone mounted a removeable top box yet? I am going to start riding the bike to work and need secure, waterproof storage, but I would like it to be easily removeable when not needed. I don't need a lot of capacity (change of clothes, lunch, and my portable radio). Thanks, Bill
billfires is offline   Reply With Quote
Old 03-28-2013, 07:31 AM   #4052
SAPB
SAPB's Avatar
Oddometer: 1,661
Snake brake
Just thought of the route I'm going with the snake brake/shifter. Go to where they sell single guitar strings, the kind with a eyelet on the end. Put the end through loop to make a hangman's knot. Pull it tight over the shifter, and secure it with bailing wire (the kind we used to put where the spokes crossed, or similar), to make sure it can't back off. Drill a hole somewhere on your skid plate, nut and bolt from hardware store/Locktite, trim off excess. On the brake side, I'll drill a hole through the lever. Hey, if you know someone who plays, it's free, they're going to trash them anyway, except for the hardware. Leave a little slack, you won't even need a tuning fork. Hey, the blue bike guys have tuning forks on the tank.
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB screwed with this post 03-28-2013 at 10:17 AM
SAPB is online now   Reply With Quote
Old 03-28-2013, 07:31 AM   #4053
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,403
If you are looking to keep the price down these knock off Givi trunks can be found in various places on the net and they come with their own mounting plate. Looks like Amazon has the best prices. The only thing you need on your bike is some sort of rear rack to attach their mounting plate too. You can easily take the bog off and just have the mounting plate there which isn't that intrusive.
I can tell you from experience on these cheap ones, don't ever slam the case down on the locking mechanism without actually unlocking it and pushing in the button. You can do it with the Givi's, but I actually broke the lock mechanism on one of these some years back.
Amazon has the smaller one for under $30 - http://www.amazon.com/Universal-Deta.../dp/B008OIUQXG
Here's another one even a bit larger and cheaper - http://www.amazon.com/Universal-Moto.../dp/B004IAC3ZS
One more - http://www.amazon.com/Universal-Moto...=pd_sbs_auto_2
Another smaller one - http://www.amazon.com/Motorcycle-Sco...d_sim_sbs_sg_1
- Pic is too big to hot link - http://ecx.images-amazon.com/images/...L._SL1500_.jpg
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 03-28-2013, 10:58 AM   #4054
trainman
trainman's Avatar
Oddometer: 397
For those that installed the DRC 12 o'clock Labs LED Tail Lamp, was it a plug and play, or did you have to tap into the factory wiring harness with connectors that were not factory plug and play. Thanks for any info on this.
John
trainman is offline   Reply With Quote
Old 03-28-2013, 11:24 AM   #4055
billfires
Oddometer: 45
BlueLghtning, thank you for the links, I never even considered Amazon. I just have to figure out if a flat rack is the way to go to mount it on. Thanks again, Bill C
Old 03-28-2013, 11:31 AM   #4056
Trollisfed
Trollisfed's Avatar
Oddometer: 17
John
It's not a plug and play.
I'm installing mine on Saturday, I'm sure others will let you know, but my quick read of the destructions it states you cut the bikes wires about 6" from the harness and connect them with the supplied connectors. It looks like they give you at least 12 connectors... I'm guessing crimp on & male/female???
I was suprised mine came with the separate 12 o'clock labs circut board that you have to install into the DRC light. Not a huge deal, but I wished it would have come preinstalled into the light, those screws are small! I guess I will have a back up circut board if the fancy one ever dies.
Did everyones come separately, or did I get a "rush job" do-it-yourself kit.
Trollisfed is offline   Reply With Quote
Old 03-28-2013, 11:38 AM   #4057
SAPB
SAPB's Avatar
Oddometer: 1,661
Destructions, I like that. Do the directional lights just unplug, or you snip the wires?
Old 03-28-2013, 12:29 PM   #4058
emreturkeli
emreturkeli's Avatar
Oddometer: 120
John
Yes you have to cut the original end of the stock tail to use its socket...
Emre Turkeli
"Specialist"
ARh-
emreturkeli is offline   Reply With Quote
Old 03-28-2013, 12:39 PM   #4059
Dago52
Dago52's Avatar
Oddometer: 58
John
I just did this mod and it was very simple. Don't forget to add electric grease on your connections. This will help to prevent any corrosion.
thanks
2012 KTM 350 EXC-F the BEAST
Dago52 is offline   Reply With Quote
Old 03-28-2013, 01:46 PM   #4060
BlueLghtning
Oddometer: 5,403
Most of those appear to come with what I call the wavy clamp that basically grabs onto the bottom of a bar type rack. So in that case, I would think a bar type rear rack would work better, but even if you got one of the more solid flat ones, I think you'd figure out a way to attach the base. The thing I like about the bar type ones is they are pretty stout.
Old 03-28-2013, 02:02 PM   #4061
SAPB
SAPB's Avatar
Oddometer: 1,661
The Givi, or Coocase, while more expensive, have the feature of the two red buttons you can see on the back. The top one opens it up, while the bottom one releases it from the base unit. Some of them have a handle incorporated , so you can carry it like a briefcase. I have a Givi top case on my street bike, made by Givi, sold as an accessory through Kawi. http://www.twistedthrottle.com/shop-...=3019&limit=48
SAPB screwed with this post 03-28-2013 at 02:10 PM
Old 03-28-2013, 02:34 PM   #4062
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 866
Well as a guitar player - no matter what gauge guitar string, they aren't going to be stong enough - same with the bailing wire - my brake snakes appear to be braided steel(?) wire
2014 BMW R1200GS -- 2011 F650GS-- 2013 Honda CRF250L -- 2013 KTM 250 XCW
In loving Memory of Cruzn2b - 1953 - 2014
SugarDust is offline   Reply With Quote
Old 03-28-2013, 03:06 PM   #4063
siyeh
Lawn Nazi
siyeh's Avatar
Oddometer: 1,692
Yep, I put a GIVI 300 on a ManRacks. Got the generic plate from Twisted. I needed a way to get my lunch and other crap to work. Will never leave the GIVI on for anything off road tho. Not a good idea at all.
Twas a cold ass 24F on the way to work this morning (5:30 am) But by 9am it was warming up nicely
If this was July, there would be two Harleys, an older Connie, a Gold Wing, and a CRF250L parked here. Today, there was only my Lil Honda in the lonely motorcycle parking spot.
guess my co workers are sceered of a little ice and snow
siyeh is offline   Reply With Quote
Old 03-28-2013, 03:14 PM   #4064
Trollisfed
Trollisfed's Avatar
Oddometer: 17
thanks
Did your light come with a separate 12 o'clock circut board that you had to swap out with the other circut board?
http://www.youtube.com/watch?feature...&v=y59BJCUVyQY
First links, so hopefully they work. All in all, it's a great kit, and I'm very happy with it!
This is what was included with my purchase.
Old 03-28-2013, 04:09 PM   #4065
trainman
trainman's Avatar
Oddometer: 397
Thanks for the info on the DRC 12 o'clock Labs LED Tail Lamp.
John
Times are GMT -7.   It's 03:18 AM.
