Old 03-29-2013, 04:17 PM   #1
slogger OP
Oddometer: 656
XR650R. Clutch adjustment problem.
This has happened to me 2-3 times on my current XR. After a long ride, I shut my bike off. The clutch lever is within spec's(2-3cm). The next time I jump on the bike(after sitting for a few days), there isn't any play in the clutch lever. After riding the bike around the block, all the adjustment 2-3cm comes back into the lever.
What causes this?
slogger is online now   Reply With Quote
Old 03-29-2013, 07:49 PM   #2
jbrownmxr
Gas Passer
jbrownmxr's Avatar
Oddometer: 335
Clutch play
Im not sure what is meant by 2-3cm. The clutch should be adjusted such that disengagement starts at 2-4mm. As the engine gets hot, especially the clutch, that play will be lessened which is the reason for the wheel style on the fly clutch adjusters. Refer to a shop manual for proper adjustment.
"When a man cannot choose, he ceases to be a man."
JB
jbrownmxr is offline   Reply With Quote
Old 03-29-2013, 09:38 PM   #3
slogger OP
Oddometer: 656
Yes, I'm talking about the "clutch play" in the lever. The spec is 1-2cm.
This play goes from 2-3cm(which is where I set mine), to 0cm after sitting for a couple days. Then back to 2-3cm after being ridden.
Old 03-30-2013, 10:42 AM   #4
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,215
Probably have grooves worn into the basket fingers, makes the adjustment fiddly, eventually you'll get a honking noise and a grabby clutch. Take it apart and check it out. You can file the grooves down to get some more life or get a Hinson billet basket.
Times are GMT -7.   It's 04:21 PM.
