Old 03-28-2013, 03:24 PM   #1
Ron from BC OP
Ron from BC's Avatar
Oddometer: 1,385
Old Dyna Beads?
So today thought I'd put some new Heidenau K60's on. Normally I just let the air out of the tires before peeling them off but I thought I unscrew the core of the valve.
So I get the tire off the rim and I see these tiny black beads in various sizes......never seen any debris left in the tire before.
I've had this bike for almost 5 years and changed tires lots....is it possible that these are dyna beads that the original owner had used and somehow got stuck around the valve stem and when I removed the core they became dislodged?
.....and yes those freaking K60 rears have not gotten any easier to put on. I had to wrap a strap around the tire to perform the tourniquet maneuver to get it to keep the air and seat the bead.
Also cut off the oem rubber stem and installed the angled ones.....
'02 BMW R1150 GSA
'06 Kawasaki KL250H Super Sherpa
Ron from BC is offline   Reply With Quote
Old 03-28-2013, 04:15 PM   #2
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,534
the Dyna's are all the same size.
Are they bits of rubber or harder, Dyna's are hard.
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 03-28-2013, 04:20 PM   #3
mjfields_228
mjfields_228's Avatar
Oddometer: 381
Constipated tire mouse............
Present Bikes:
2015 Triumph Street Triple R -- Matte Black
2013 Ducati Multistrada -- Red
2011 Triumph Speed Triple -- Black
mjfields_228 is offline   Reply With Quote
Old 03-28-2013, 07:21 PM   #4
Ron from BC OP
Oddometer: 1,385
Yep they're hard
'02 BMW R1150 GSA
Old 03-28-2013, 08:00 PM   #5
wrysingfeenix
Dust off those ashes
wrysingfeenix's Avatar
Oddometer: 638
I've seen the same thing happen with car tires, and a knowledgeable tire shop guy told me it's a very common phenomenon. Any kind of loose debris will "gather" rubber over time and cause those tiny balls of what were, for all intents and purposes, pure rubber. He told me to ignore it; it was of no consequence regarding wear, balance, or safety.
I've been using Dynabeads for years/thousands of miles in Conti Road Attacks, Metzeler Tourances, and TKC80's and have always expected to find those black balls when I change tires; hasn't happened yet. The Dynabeads might have some black on them, but they've never been coated or enlarged. I'm guessing it happens with softer rubber and not with "dryer" harder rubber.
YMMV
---'99 BMW R1100GS
---'96 BMW R1100GS Mod Project ???
---'80 Honda CB750 Street Tracker Project
---'09 Vespa GT200 Granturismo
wrysingfeenix is offline   Reply With Quote
Old 03-29-2013, 06:23 AM   #6
Ron from BC OP
Oddometer: 1,385
Works for me thanks.
'02 BMW R1150 GSA
Old 03-30-2013, 12:14 AM   #7
ultane
sqeezin the bag
ultane's Avatar
Oddometer: 1,210
Someone smarter than me, on this board, several years ago, stated that the little black beads were from the tire overheating during its use, due to either too much weight, or too fast of speed,... or both. As it turns out, I found the same in a well used TKC80 that I had removed after some 'strenuous' 2-up freeway use.
Sent from my party line rotary dial iPhone using Tapatalk
I might be wrong, just ask my X...
If a man speaks, and there is no woman present to hear him,..
Is he still wrong?
ultane is offline   Reply With Quote
Old 03-30-2013, 12:50 AM   #8
AKTREADs
Oddometer: 63
Ron from BC-
Pitch the Dyna Beads &
Mount tire/seat beads/break bead approximately 6" length on top side &
install 1oz in front & 1.5oz in rear wheel of 6mm Air Soft Beads in tubeless tires.
Avoid the green or black beads that are biodegradable if using liquid/soap to mount tires.
Ride Safe,Have FUN,
Dan
Adventure Cycleworks Providing support to the Adventure Touring Motorcyclist in Fairbanks, Alaska
AKTREADs is offline   Reply With Quote
Old 03-30-2013, 05:40 AM   #9
Ron from BC OP
Oddometer: 1,385
Weight? High speed? Nope....this is the time I've seen this and I started loading my bike lighter on trips during 2012. I rarely go over the posted speed limit which in some of the States I went through last year was 70mph.
Pitch the Dyna Beads? I've never used them....
I'm sure liking the angled (80-90 degree valve stems)
'02 BMW R1150 GSA
Old 03-31-2013, 10:31 AM   #10
ultane
sqeezin the bag
ultane's Avatar
Oddometer: 1,210
The point is, or so the tire 'expert' stated, different tires are rated for different load carrying capacities, as well as speed rated. Under inflation, and overloading can cause heat build up, or going faster than recommended can cause heat build up. If your bike is loaded, add air to the tires. Under-inflation for the load, and higher speeds, adds significant stress to the tire, resulting in too much HEAT generation. This 'heat' is what can destroy a tire. He stated that the little round balls of rubber were an indication that the tire had generated TOO MUCH heat, and a warning that tire failure was imminent at some point while the tire was being used.
Is he still wrong?
Times are GMT -7.   It's 10:05 PM.
