Old 04-02-2013, 04:10 PM   #466
backdrifter OP
Wannabe rider
backdrifter's Avatar
Oddometer: 1,364
Thanks again, gents.
georgesgiralt, where in France are you? A few years ago I got to visit Nice and Monaco during a European tour. I would love to go back and see more of your beautiful country. Hopefully one day soon!
Well, I haven't fixed the front brake yet, but I've determined that the rear brake is actually working pretty darn well. I decided to go for another ride around the neighborhood today, but first I wanted to check the valves. In my haste and excitement when the bike magically started last weekend, I totally forgot to start it up, kill it, and then check to ensure the valves had received oil. I figured they had to have - as I had ridden it a decent amount and there were no signs of any problems, but I wanted to check to be sure. So, today I did, and all is well:
It didn't start as easily this time, but it is roughly 30 degrees cooler, so maybe that's why. None-the-less, she started and off I went. The stutter in the middle of the rev range was more pronounced today too, but it still ran pretty damn well. I probably put 2 or 3 miles on it just running around the neighborhood, and I have a long straight frontage road where I was able to get up to about 60 mph a couple of times. Everything feels pretty good. The front left fork is weeping a bit, I'll have to take a closer look at that.
When I got back, there were some funny smells, but I didn't see anything leaking or any causes for concern. I seem to remember noticing that last time I rebuilt a bike, in that case a 550cc KTM two stroke. Is that just the gaskets breaking in?
"We are very good at preparing to live, but not very good at living."
-Thich Nhat Hanh
1973 BMW R60/5:
http://www.advrider.com/forums/showthread.php?t=608166
backdrifter screwed with this post 04-02-2013 at 07:17 PM
backdrifter is offline   Reply With Quote
Old 04-02-2013, 05:40 PM   #467
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,997
It didn't start as easily this time, but it is roughly 30 degrees cooler...
Ah, there is a Starting Drill:
Depress the tickler until fuel dribbles out the overflow tube in the bottom of the float bowl. Pump the throttle seven times. No more. No less. Seven shalt be the number thou shalt count, and the number of the counting shall be seven. Eight shalt thou not count, nor either count thou six, excepting that thou then proceed to seven. Ten is right out. Once the number seven, being the seventh number, be reached, then crack the throttle by one-in-eight and hit the starter button. And the engine will start, and the people will feast upon the lambs and sloths and carp and anchovies and orangutans and breakfast cereals and fruit bats and large chu--
Skip a bit, Brother.
After 20-30 seconds, if the engine starteth to bog, hiteth the Tickler again...
--Bill
'73 R60/5 Toaster
Old 04-02-2013, 06:22 PM   #468
SRanger331
SRanger331's Avatar
Oddometer: 190
--Bill
Yeah, I read that when you first posted it, it really works.
Ben
'73 BMW R60/5
'12 Yamaha FZ1
SRanger331 is online now   Reply With Quote
Old 04-02-2013, 07:19 PM   #469
backdrifter OP
Wannabe rider
Oddometer: 1,364
--Bill
Thanks Bill, I'll give that a try next time. Do you have any Grail related witchcraft that will make this damn thing idle?
-Thich Nhat Hanh
1973 BMW R60/5:
Old 04-03-2013, 12:33 PM   #470
SRanger331
SRanger331's Avatar
Oddometer: 190
Your going to have to do a good 15-20 mile ride to be able to tune the carbs. Just trying to get anything set going once around the block isn't going to get you very far.
Oh, and before you get that far, there should be some boots that go on the end of the throttle cables at the carbs. I didn't see them in your pictures. You wouldn't want to tune it, then realize you have to take the slide out of the carb, then the cable out of the slide, just to get the boot on. Then you have to go back and re-tune the carbs.
Unless your just going to leave them off.
Ben
'73 BMW R60/5
'12 Yamaha FZ1
Old 04-04-2013, 03:35 PM   #471
backdrifter OP
Wannabe rider
Oddometer: 1,364
At this point, I think I'll just leave them off since I have no idea where they are!
Well, I tried the starting ritual and it worked very well - though it is about 60 degrees out today - the same as it was the first time I got her running and it fired right up. I'll have to try again on a cold day.
According to the speedo, I've put 8 miles on her so far. More to come, for sure. I've got to leave for a bit, but I'll try pulling the plugs soon to check if I'm on the rich or lean side of things. My guess is it's running rich, which is much better than too lean.
More soon....
-Thich Nhat Hanh
1973 BMW R60/5:
Old 04-04-2013, 04:56 PM   #472
georgesgiralt
Oddometer: 102
Hello !
I live, normally, in south of France, in Toulouse. Near Lourdes, the Pyrenees and the castle city of Carcassonne.
Now, back to business ....
It may be normal for the motor to do funny things with today fuel. Remember, the fuel they used when she left the factory have nothing to compare of today mixture. No more lead, added ethanol, different octane numbers... you name it.
Add to this the carbs jets and needle had worn out so the status is not on the perfection end of the scale.
I think you should overhaul the carburetors, replace needle and needle jet, clean everything, change everything rubber and set it to factory specs. The bike should run with these settings. Synchronize both carbs with the bike just started, go for a ride, remember the front brake, do you ? Then when back at home, check idle speed, idle synchronization, idle mixture, and lock the throttle at around 2000 RPM and redo the carb synchronization again.
You should notice a huge improvement in handling.
Of course, you will have to adjust the jets for modern fuels but this could wait 'till you had ridden her for some time and determined where the problems are, if they exist.
Remember that adjusting carbs and fuel mixture tinkering is what comes last. First the engine should be mechanically sound, valves with proper clearance, ignition timing perfectly set, and spark plugs with correct thermal value and equal gap on both cylinders.. Otherwise you'll become silly troubleshooting problems.
As to the smell, remember the solvents, oils, paste, .... you used to clean the engine ? Well they smell when hot.And evaporate so it won't last. Try not to breathe them as they are mostly petroleum based. Especially if you suffer from some kind of allergy. "Work in a well ventilated area..." they keep writing on the boxes and can.
georgesgiralt is offline   Reply With Quote
Old 04-04-2013, 06:10 PM   #473
Bill Harris
Oddometer: 7,997
Oh, and before you get that far, there should be some boots that go on the end of the throttle cables at the carbs...
...At this point, I think I'll just leave them off since I have no idea where they are!
But don't go too long without those throttle boots. Nor the O-rings on the carb tops. There are a couple of openings in the bottom of the slide (where the cable fits and where the needle passes thru) and there is a vacuum on the bottom side of the slide. Those boots and O-rings are there to prevent a vacuum leak at mid-throttle operation. Nothing really major, so don't freak.
--Bill
'73 R60/5 Toaster
Old 06-21-2013, 07:45 PM   #474
backdrifter OP
Wannabe rider
Oddometer: 1,364
Bringing this thread back from the dead for a small update. I (finally) went to get the bike registered today, but I didn't have the right paper work. I'll be able to get a hold of it Monday and I'll try again. In the mean-time, I decided the poor bike was well overdue for a taillight, so I got on it.
I had bought one of these LED strips, originally planning to drill holes in the license plate and attach it there.
Once I had it in hand, I didn't like the way I thought it would look. So, I started working on a bracket from aluminum, as shown in the picture above. It started with aluminum angle iron like this:
Then I had to drill the holes in the aluminum for the individual LED lights to go through. It doesn't sound tough, but it was tedious, and the end result certainly wasn't perfect!
Luckily the little nubs on the LED light are rubber and give quite a bit, so I was able to make do with my sloppy drill work.
Once I knew it would all line up, I painted it.
Then I mounted it to the rear fender.
I didn't like the way it looked without something covering the top of the LED strip, so I cut another equal length of aluminum angle iron and put it across the top to make a box.
You can see the gap between them in the picture above, and that white stuff is double sided 3M tape that is holding the "cover" in place. I'm going to work on getting the gap closed up. It's more noticeable in this photo than in real life.
These suckers are bright - much brighter than the stock unit.
And that's it for now! I was really hoping to have the temporary plate tomorrow so I could go for a proper ride, but it will have to wait until Monday.
Looking forward to a 100 mile riding day soon....
-Thich Nhat Hanh
1973 BMW R60/5:
Old 06-21-2013, 11:15 PM   #475
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,791
Looks great, love me some LED's
Old 06-22-2013, 02:21 AM   #476
mattsz
moto-gurdyist
mattsz's Avatar
Oddometer: 178
But Backdrifter... how's she runnin'? Last I heard, there was some roughness in the middle rev range, and maybe a fork oil leak?
My other wheels: www.midcoast.com/~beechhil/vielle
mattsz is offline   Reply With Quote
Old 06-22-2013, 06:25 AM   #477
backdrifter OP
Wannabe rider
Oddometer: 1,364
Running well mattsz, thanks for asking! I tightened up the left fork bottom and no leaks since (from anywhere on the bike). I set the carbs back to the baseline settings and it's very close. It runs very well and the stutter in the rev range is gone, but I still have idling issues from time to time. I also tweaked the drum breaks and they actually stop the bike now! Once I have a plate, I'll ride the bike out to the local BMW enthusiast shop and have him check the brakes and do final carb tweaks. I've never owned a bike with drum brakes before, so I would like to have an expert ensure that I'm getting as much stopping power out of them as possible.
All in all, I've probably put 70 or so miles on it just putting around close to home.
-Thich Nhat Hanh
1973 BMW R60/5:
Old 07-09-2013, 07:19 AM   #478
backdrifter OP
Wannabe rider
Oddometer: 1,364
Got out for a 30 mile ride over the weekend. It was the farthest continuous distance I've traveled on the bike. Everything felt pretty good, though I think both the brakes and the jetting can still be adjusted a bit.
I looked down at a stoplight and saw some oil spots beneath the bike. Turns out the driveshaft boot, which I had reused because it looked fine, had torn. I guess the rubber was brittle and once it started moving, it cracked open. I took it home, cleaned up the area, refilled the gear oil, and tried using duct tape to seal it just enough to be able to ride more over the weekend, but during my next short ride, the crack propagated and got worse.
Parts are on order and shipping today. Hopefully the first 100 mile day will come next weekend.....
-Thich Nhat Hanh
1973 BMW R60/5:
Old 07-18-2013, 08:59 AM   #479
Packer
Packer's Avatar
Location: Scotland, wonderful biking when it's dry (rarely)
Oddometer: 333
I have a '69 R60 US with the TLS drum front brake. It can lock the wheel, until the drum gets hot
Plan to ride with sufficient anticipation that you don't need the brakes except for that final transition to stationary.
Packer is offline   Reply With Quote
Old 09-28-2013, 10:14 AM   #480
backdrifter OP
Wannabe rider
Oddometer: 1,364
Well, it's been a few months since I upated this, and there really isn't much left to post. I did finally get my custom license plate, shown below. I thought it was a nice final tribute to Papa, though most people will probably just wrongly assume that my name is "Jim".
I still need to dial in the brakes and jetting, but it's running pretty well so I've been taking it for some nice rides. Here are a few photos from this morning's ride. It's a wonderful time of year to be on a bike!
There will always be a few tweaks and odds and ends that I want to update, fix, or tinker with as time goes by, but for the most part I'd call this project complete, so it's probably a good time to sign off. If I start getting more saddle time, I'd like to start an ongoing "In memory of Jim Adams - an R60/5 ride report" thread, but right now I wouldn't do it justice.
A huge thanks to everyone that read along - from the lurkers to the contributors that helped guide my way, I really don't think I could have done it without this site.
And I think the end goal was certainly achieved in style. The bike looks wonderful (in my opinion), our family now has a very personal and beautiful heirloom, and Papa's spirit rides on.
Thanks, ADVrider!
Ben
-Thich Nhat Hanh
1973 BMW R60/5:
backdrifter screwed with this post 10-01-2013 at 08:52 AM
Times are GMT -7.   It's 12:09 PM.
