Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 03-26-2013, 03:21 AM   #166
igormortis OP
igormortis's Avatar
Oddometer: 1,368
Much better...
IMG_0175
IMG_0177
But... in my haste I neglected to check piston ring orientation. A search suggests that the sky is again, falling. What now, people?
igormortis is offline   Reply With Quote
Old 03-26-2013, 11:35 AM   #167
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,277
It doesn't really matter in the medium term. The rings aren't fixed on the piston & rotate anyway. If they are aligned & especially if they are aligned towards the bottom, you might see some oil smoke initially. Probably have better things to worry about. Have you got all your parts back that you had farmed out for machining?
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 03-26-2013, 11:39 AM   #168
Padmei
enamoured
Oddometer: 3,682
Were you getting valve guides done?
Padmei is offline   Reply With Quote
Old 03-26-2013, 11:56 AM   #169
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,277
Yes, K-liners. I'm interested in how those turned out.
Old 03-27-2013, 12:32 AM   #170
Padmei
enamoured
Oddometer: 3,682
I Talked to my engine reconditioner about them when I picked up my heads & asked whether he had any preference. He said there wasn't much in it but would probably go with proper guides. He was welding & doing some pretty trick stuff on a top stockcar head before the nat champs so felt reasonably confident in his abilities & advice.
Old 03-27-2013, 01:35 AM   #171
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,277
I think one issue has been the amount of slop the standard new BMW valve guides allow. The k-liners could be potentially set to a much lower tolerance.
I have guides waiting to go in, but am waiting on Igor's report on his head work. If it's positive I may also go k-liners.
Old 03-27-2013, 02:13 AM   #172
Padmei
enamoured
Oddometer: 3,682
IIRC the engineer bloke measured the new guides & was happy with them. I seem to recall it was an issue I was pondering at the time.
Old 04-02-2013, 04:17 PM   #173
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,590
I run K liners on the r90 race bike with the original valves. Have done over 20 races at high revs. Just saying.
Voltaire is offline   Reply With Quote
Old 04-02-2013, 10:16 PM   #174
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,277
It was more a question about the Engineer doing the work, rather than whether K-liners were good. I wanted to make sure the guy did a good, timely job. He was having his heads twin-plugged, the K-liners fitted, & other work to his final drive.
Old 05-05-2013, 12:38 AM   #175
igormortis OP
igormortis's Avatar
Oddometer: 1,368
En route!
Just a quick update on Igor's behalf - he's currently riding the bike up to Auckland to be crated up at Jenners tomorrow. It's a bit wet and miserable out there... but needs must.
Spot tracker: http://share.findmespot.com/shared/f...K1rTdQCtRLmnTf
Penny
Old 05-05-2013, 12:42 AM   #176
advNZer?
advNZer?'s Avatar
Oddometer: 2,887
Penny
so when are you actually leaving?
aka BMWST?
advNZer? is offline   Reply With Quote
Old 05-05-2013, 12:59 AM   #177
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,277
Penny
What time did he leave Penny? When I called in yesterday he was still frantically assembling. Hope it has all come together. The spot tracker is still showing him at home!
Old 05-05-2013, 01:32 AM   #178
Padmei
enamoured
Oddometer: 3,682
Sounds exciting penny. Please keep us posted with your progress. Either here or on the ride reports page.
Old 05-05-2013, 01:38 AM   #179
Mark_S
Fair Weather Faggot
Mark_S's Avatar
Oddometer: 1,842
according to spot he either broke down within the first 10 metres or decided it was too wet...
These are the best days
Mark_S is offline   Reply With Quote
Old 05-05-2013, 02:00 AM   #180
Padmei
enamoured
Oddometer: 3,682
Actually good point - who wants to travel around the world when it's raining? Leave it for another day I say.
Times are GMT -7.   It's 04:26 AM.
