Old 04-02-2013, 11:58 AM   #1
CanadaBiker OP
Oddometer: 269
how to remove jet needles
I want to replace the jet needle (nozzle needle in the fiche) but I can't figure out how to remove them. My manual says something about push and twist, but I can't figure it out. The fiche shows clips and toothed rings, but as I understand it, not all models use those clips?
Also, once I get them out, it must be challenging to get them back in at the right groove? Any advice?
2005 Suzuki DR650
CanadaBiker is online now   Reply With Quote
Old 04-02-2013, 12:29 PM   #2
Hookalatch
Born Under Bad Sign
Hookalatch's Avatar
Oddometer: 395
Twist the needle 90 degrees or 1/4 turn and gently push up on the needle. Continue the 90 degree rotation until the needle comes out. Count the number of turn to determine what groove it was in. You can also measure how far the needles stick out to get the same location when they are replaced. It becomes pretty obvious how that works when you actually see the needle.
Chuck
Hookalatch is offline   Reply With Quote
Old 04-02-2013, 01:09 PM   #3
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,242
+1
it helps to wear latex gloves or similar for a slip-free grip between fingers while turning the needle through 90 degrees, at which point it can be drawn to the next pair of opposed notches, or out as the case may be.
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is online now   Reply With Quote
Old 04-02-2013, 02:16 PM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,511
You probably have to have Latex or some type of glove to get a grip on the smooth needle. I didn't have any nice clean new latex gloves the last time I did this and ended up with an old pair of gardening gloves in heavy rubber.
Well it worked.
Your leather motorcycle gloves probably won't work. The needle is slippery.
---Albert Einstein
Old 04-03-2013, 12:54 AM   #5
Plaka
Brevis illi vita est
Oddometer: 4,612
record how much they stick out before you remove them. Just make a mark on a 3x5 card.
Old 04-03-2013, 07:17 AM   #6
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,503
http://youtu.be/vFnTVxm0FVw
boxerboy81 screwed with this post 04-04-2013 at 02:09 AM
boxerboy81 is offline   Reply With Quote
Old 04-03-2013, 10:03 AM   #7
CanadaBiker OP
Oddometer: 269
So i got the jet needles out, but damn, the new ones I ordered from Maxbmw are much longer. And the taper profile is much different. The part number seems correct, and it matches the fiche...
Anyone have this problem?
2005 Suzuki DR650
CanadaBiker screwed with this post 05-27-2013 at 11:09 AM
Old 04-03-2013, 10:07 AM   #8
blaine.hale
blaine.hale's Avatar
Oddometer: 3,145
What are the markings on them? There should be an X or some other markings to denote which needle is which.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 04-03-2013, 10:13 AM   #9
CanadaBiker OP
Oddometer: 269
I just now looked very closely and I can't see any markings.
2005 Suzuki DR650
Old 04-03-2013, 10:16 AM   #10
blaine.hale
Oddometer: 3,145
Now that I think about it...I may have imagined doing that on my bings. I think I did that for my Amals haha.
Sorry, way too many carbs in my life at the moment.
1974 BMW R90 /6
Old 04-03-2013, 10:30 AM   #11
daveoneshot
Oddometer: 398
I've used lightweight Vice Grips, set real low on the squeeze scale, with rubber strips on the teeth. The job got done, but I almost had heart trouble while doing it. Latex gloves seems like a good idea.
daveoneshot is offline   Reply With Quote
Old 04-03-2013, 10:43 AM   #12
CanadaBiker OP
Oddometer: 269
So I think I've tracked down the issue of the differing lengths on the new nozzle needles. The fiche at Maxbmw is wrong, in that it lists the part number for the 40mm carbs instead of the 32mm carbs. uggggggg
fwiw, In fairness to MAX, the fiche at Bobs is wrong too, so maybe it's an error coming from the main BMW fiche.
still uggggggggggg
2005 Suzuki DR650
Old 04-03-2013, 12:25 PM   #13
naginalf
Handy Schtroumpf
naginalf's Avatar
Oddometer: 250
Eek Wait... what?
I just ordered all new needles, jets, and whatnot from Max. Are you telling me they are the wrong part now? So what's the correct part number?
'91 R100GSPD
Adventures with a Type1 TARDIS.
naginalf is offline   Reply With Quote
Old 04-03-2013, 12:53 PM   #14
CanadaBiker OP
Oddometer: 269
Not sure for your bike, but the 32mm Bings use nozzle needle (jet needle) 13111255840.
However the fiche, at least for my bike, lists the part as 13 11 1 335 321, which is actually for the 40mm Bings. The confusion is that many of the R100s have the 40mm carbs, but the 'plain jane' R100/7 uses the 32mm carbs.
Clear as mud? :)
2005 Suzuki DR650
Old 04-03-2013, 01:31 PM   #15
naginalf
Handy Schtroumpf
naginalf's Avatar
Oddometer: 250
Bluhduh Even muddier now.
I have 32s on my 91GSPD, and the fiche says PN 13 11 1 337 692 I guess I'll see what happens when I get them apart.
Oh, sorry, I'm probably just confusing things, didn't realize you guys are talking about 70's bikes which probably had different bings. Nevermind me.
'91 R100GSPD
naginalf screwed with this post 04-03-2013 at 02:52 PM
Times are GMT -7.   It's 02:37 PM.
