Old 04-02-2013, 07:01 AM   #14266
mait
mait's Avatar
Oddometer: 332
Miguel, the bike is looking very good. In general I like the original design with beak and large tank but yours is appealing, too.
mait is offline   Reply With Quote
Old 04-02-2013, 11:20 AM   #14267
the_sad_punk
the_sad_punk's Avatar
Oddometer: 353
Originally Posted by spen View Post
Rob i have been asking BOB on the other site some questions about the "shims" that are in behind the three gears that take the drive from the starter to the crank ,They are not listed in the book ,Just wondering have you shimed your starter gears ??? Although my bike isn"t running i have turned it over and there is quite a noise as if one of the gears is moving along the shaft and thumping the back of the outer casing ,just thinking is there a shim missing that would hold the gear in position.Any thoughts . cheers
You must have missed my reply to you re this on the other channel...
http://www.drbig.info/forum/viewtopi...p=12446#p12446
Second last post.
Your welcome
the_sad_punk is offline   Reply With Quote
Old 04-02-2013, 12:37 PM   #14268
jurvooss
Oddometer: 17
complete engine full of gasoline, 1990 big!
yaaay
what went wrong and where?
thanks in advance!
jurvooss is offline   Reply With Quote
Old 04-02-2013, 02:54 PM   #14269
Simosez
Simosez's Avatar
Oddometer: 433
Originally Posted by jurvooss View Post
yaaay
thanks in advance!
float valves leaking. replace these.
turn your fuel off when you shut down the bike, that way if they do leak your engine will not flood.
plenty more info on this further back in the thread. suggest a full rebuild of the carbs when you have them out.
"Safety Turd. Because the only skid marks should be on the dirt."
"If I could get back all the money I ever spent on dirt bikes, I'd spend it all on dirt bikes."
DR750 BIG
Husaberg 350
Simosez is offline   Reply With Quote
Old 04-02-2013, 03:06 PM   #14270
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,998
What went wrong?
Gravity...and.....Twenty year old O-rings and/or float needle valve and seats
There is an O-ring around the needle valve seat (the brass bit) that seals it (or NOT in your case) into the carb body. So even if the float valve and seat are good you might leak fuel above this valve.
There is another one on the plastic float valve "tree" and yet another under the slide guide.
In short, replace all the flexible sealing bits on both carbs and you'll be OK.
The fuel valve on the tank is there for a reason.
Ladder106 is offline   Reply With Quote
Old 04-02-2013, 04:31 PM   #14271
spen
on my arse
spen's Avatar
Oddometer: 346
Second last post.
Your welcome
spen is offline   Reply With Quote
Old 04-02-2013, 08:21 PM   #14272
jurvooss
Oddometer: 17
is that the set u can order from hrt?
Old 04-02-2013, 08:59 PM   #14273
Ladder106
Ladder106's Avatar
Oddometer: 4,998
Yes, you can get the kit from Hessler. You can also get the standard Suzuki parts from a dealer. Stefan has a very good reputation for quality bits and is just about the only large shop in the world who still goes nuts for these machines.
Old 04-03-2013, 02:29 AM   #14274
MiguelXR33
Suspenso en inglés
MiguelXR33's Avatar
Oddometer: 12
FINISHED! A BIG with small fuel tank and without "beak's duck"
Originally Posted by robmoto View Post
Miguel, I read your links and looked at your pics, a fair bit of weight has now gone and making the Big more usefull in the bush.
A very well done from me cheers . .
Robmoto, really thanks. Curiosly when I was thinking about this transformation, was looking for pics about it around the world... and the better changed Big for me is your "black Supermoto"... really pretty. I was writting about:
http://www.voromv.com/2012/09/con-el...llo-29_22.html
When I saw your bike I thought "Really I can do it"... and I have now my different DR 750.
Robmoto, you was my inspiration... thanks to you.
Thanks Mait... and a secret... I like more the original design too!!!! But now I haven't money for another bike... and I NEEDED another bike, another illusion. Well, now I have a different, unique, bike... MY bike.
And is a DR ...
Miguel
Finished!!! Suzuki DR 750 Garbí
No pretendo tener razón, sólo expresar mi opinión.
Los Envíos de MiguelXR33 en www.Voromv.com
Malo en campo, malo en carretera ¡piloto total!
MiguelXR33 screwed with this post 04-03-2013 at 02:57 AM
MiguelXR33 is offline   Reply With Quote
Old 04-03-2013, 03:52 AM   #14275
wundis
Oddometer: 79
Oil pump Oil Seal dimensions
Howdy,
Could anyone confirm the dimensions of the oil seal by the oil pump on the clutch cover ? Bottom right in the pic:
wundis is offline   Reply With Quote
Old 04-03-2013, 04:02 AM   #14276
robmoto
robmoto's Avatar
Oddometer: 3,861
Hi Miguel, I can not take the full credit of my 800, a lot of mods were already done to the bike, but when I bought it , it was in very bad condition, I just kept throwing money at it till it was right and rebuilding it changing things as I went along it owes me 12k .
Funny thing is I only ride it a couple of times a year or so evan though it goes like the clappas.
I ride alone and not a KTM in sight .
Menace Racing supported by Robmoto Industries
robmoto is offline   Reply With Quote
Old 04-03-2013, 04:05 AM   #14277
robmoto
robmoto's Avatar
Oddometer: 3,861
Wundas ,a very important part I would buy the Suzuki one myself .
Old 04-03-2013, 05:27 AM   #14278
wundis
Oddometer: 79
Alas
part 09282-16002 dimensions 16x30x6. Not sure why, but it seems i wasn't able to find it in the parts manual, or was looking in the wrong place.
It's a shame that no local oil seal supplier has them, waiting for an original part to arrive means a big delay in my plans
EDIT: ok, I must edit my reply, turns out, the big delay isn't that big right now - fast delivery is 1 week from a wh in Germany. yay.
wundis screwed with this post 04-03-2013 at 07:17 AM
Old 04-03-2013, 09:10 AM   #14279
motolab
motolab's Avatar
Oddometer: 2,714
It is very rare for there to be an issue with a float seat. Usually the float needle and/or the needle seat o-ring are at fault.
Also make sure that the float itself doesn't leak, i.e. that there's no fuel inside the two chambers. You can either hold it up to a light, in which case it should be evident if there's fuel inside, or you can put it in a container of liquid and see if one side sinks more than the other.
Agreed.
Regards,
Derek
motolab is offline   Reply With Quote
Old 04-03-2013, 10:10 AM   #14280
motolab
motolab's Avatar
Oddometer: 2,714
I have three different rebuild kits in stock for these carbs, one for the '88-'89 DR750 & '90 DR800, one for the '91-'96 DR800, and one for the '97 DR800.
Regards,
Derek
Times are GMT -7.   It's 06:15 AM.
