Old 04-02-2013, 10:41 PM   #16
ontic
Oddometer: 1,070
Originally Posted by One Less Harley View Post
anyone care to get me that clearance measurement??? I'm still curious.
Bugger of a spot to measure with the tyre on.
I squeezed the end of an old set of calipers in between the narrowest point of rim to swing arm and this end of the caliper measured 15.65mm. Lets call it 15.5mm for an easy fit.
However mine is a 81 year with the older 2.15 Weinmann rim (same as my new spare wheel).
at .35" narrower than the 3.5" rim, that is almost 9mm narrower- a bit less than 4.5mm for for each side, 11mm to 15.5mm seems about right if they have aimed to centre the rims to the same point.
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 04-03-2013, 04:26 AM   #17
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,547
Yep, I'm with Hans. my 606s arent' even close to rubbing. Sorry Richard, hope you get it sorted.
Old 04-03-2013, 04:50 AM   #18
desmo
desmo's Avatar
Oddometer: 233
On later models some people use this 2mm shim from a K Bike.
36 31 1 451 791 SHIM - 2,000MM $20.51
2002 BMW 1150GSA (some changes)
2003 BMW 1100s BCR(140/200)
1994 BMW R100GS (Bumble Bee)
2007 Guzzi Cali Vintage (skunk seat)
2001 Porsche 911 (Speed Yellow)
desmo is offline   Reply With Quote
Old 04-03-2013, 10:19 AM   #19
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,763
yeah it's a very difficult spot, that's why I used a socket as a gauge..then measured it's OD, works pretty easy.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 04-03-2013, 11:30 AM   #20
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 677
Originally Posted by Airhead Wrangler View Post
Earlier G/Ss have a 2.15x18 rim which will squeeze a tire a little bit narrower. I believe '83 and later have a 2.5x18 rim
on the earlier 2.15 wheels are the hubs identical to the later 2.50s?
had bought some unloved 2.15 wheels on fleabay for the hubs on the assumption that they did not change- but worth checking before getting some excel rims
Ras Thurlo is offline   Reply With Quote
Old 04-03-2013, 11:50 AM   #21
One Less Harley OP
Oddometer: 4,763
same hub different rim width.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 04-03-2013, 06:48 PM   #22
mendoje
Oddometer: 240
...clearance from the outer edge of the rim to the swing arm
1986 G/S, 2.50" Akront rim.
0.463" clearance. I used a stack of feeler gauges inserted into the gap, then measured the stack with my digital calipers. Super easy.
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1993 Suzuki RMX250 / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike )
mendoje is offline   Reply With Quote
Times are GMT -7.   It's 03:18 AM.
