Old 06-18-2012, 01:25 PM   #46
Motodeficient
Oddometer: 448
Thought I would compile some info about the differences in the various R6/R1 throttle tubes here, consolidated from some of my posts on ADV. It may help people that are confused about the conflicting info on this subject.
1999-2005 R6 - 1/5th turn
2006-2009 R6S - 1/5th turn
2006-2009 R6 - 1/6th turn
And the R1 throttle tube is also 1/5 turn.
If you have the black R6 throttle tube, the part number is 5SL-26240-01 and its the smaller cam 1/5 turn tube from the older R6, the R6S, or the R1. If you have the white R6 throttle tube, the part number is 2C0-26240-00-00 this is the larger cam 1/6 turn from the newer R6.
Sometimes with a getoff or bad landing the idle stop can roll under the housing past fully closed throttle and start sticking. This has happened to me, its because the stops on the DR650 tube are taller than the yamaha tube. And even though the DR650 cam looks bigger, the part where the cable rides is actually smaller since there is a groove on the sides that the cable rides down in, where on the R6S throttle tube the cable rides right on top of the cam. There is no groove on the sides.. This is the R6S (5SL-26240-01) throttle tube. The regular R6 (2C0-26240-00-00) has an even larger cam, which may be closer to the outside size of the DR650 cam, so it might not have the problem of rolling past the idle stop. For some reason I haven't thought of adjusting the cables. I just file down the idle stop on the R6S throttle tube to match the size of the idle stop on the DR650 throttle tube. On the latest R6 tube it took about 30 seconds with a grinding stone on the dremel. Really easy. But this probably explains why some people don't modify the R6S tube, they just adjust their cables instead
I decided to hold off ordering the more expensive R6 tube, and will just run this R6S (5SL-26240-01) tube until I wreck it, which will happen eventually. Like I said above, since the R6 (2C0-26240-00-00) tube has an even larger cam then the R6S tube, I think it might fix the problem of rolling past the idle stop and then sticking after that happens. Plus it will be an even quicker pull. I just don't know if it will fit in the DR650 throttle tube housing, I know the SV650 guys have to grind down their housing a little to make it fit. Eventually I will order one and find out.
Then there are aftermarket throttle tubes like the motion pro ones, that say they are applicable to pretty much all of the R6 and R1 bikes, I have no idea about the size of the cams on those.
Here are a couple pictures courtesy of ER70s-2 on ADV. You can see the difference between the R6S throttle tube on the left and the DR650 tube on the right. Notice how the stops on the DR650 tube are taller, where as the R6S has shorter stops which in certain instances mentioned above can cause it to roll past closed and start sticking. However the cam that the throttle cable rides on is actually a larger diameter than the DR650 which results in the quicker throttle pull. The white R6 throttle tube may have taller stops, not sure yet.
You can also see the left side of the idle stop, this is where I file it down to be the same length as the DR650 idle stop, otherwise when you start the bike you will be at like 4,000 RPMS which is frightening! I guess people have suggested also adjusting your throttle cables to compensate, but I just take 30 seconds and dremel the idle stop to match the DR650s.
Motodeficient is offline   Reply With Quote
Old 04-03-2013, 12:57 PM   #47
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
Warp 9 levers:
http://www.advrider.com/forums/showp...ostcount=75576
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 04-03-2013, 04:19 PM   #48
wavygravy87
wavygravy87's Avatar
Oddometer: 167
Sweet!
Originally Posted by eakins View Post
I've been waiting on a decent pic of these. So...... how you like em? Are they pretty well-made? They look great! Nice setup.
You'll never make it out of this life alive...try and enjoy yourself while you can
2009 Suzuki DR650
2013 Yamaha Super Tenere
wavygravy87 is offline   Reply With Quote
Old 07-23-2013, 04:43 PM   #49
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
indicator bulbs
What size are the small bulbs in the indicator set?
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Old 07-23-2013, 04:50 PM   #50
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
they are awesome!
Alaska
Old 07-27-2013, 11:46 AM   #51
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
Upgraded shift lever:
http://www.webbikeworld.com/suzuki-dr650/shift-lever/
https://www.denniskirk.com/moose/ste...prd/571075.sku
Alaska
Old 08-01-2013, 05:33 PM   #52
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
Just received my new Moose shift lever.
The old one is still serving me well but a few hard dumps over the years have bend the tip up some. I wanted to a fresh one for crisp shifting and the old one will be a spare.
Same part # as the old one. Should say 96-13 DR650. Built like a tank!
Alaska
Old 10-28-2013, 02:36 PM   #53
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
I recently installed Vibrantors - http://www.vibranator.com/default.asp
into my handlebars and damn does these things work great to further smooth out the grips on a DR.
I mounted 1 side 1st to test and you can really fell the vibration levels through the grips go down. I have Protaper SE alum. bars. It's not like the DR is a paint shaker like a KTM 640 motor, but every bit of smoothness helps IMO.
I mounted both and then the next day went for a long ride and it was indeed smoother and more comfortable. Not inline 4 smooth, that's impossible as it's still a thumper, but smoother enough to be worth the cost.
These things are mounted inside bar via different methods and work to counter-act the vibration in the bar. I have alum. guards so i replace the end bolt with a 10mm longer one and lock-tited the vibranator to the end of that. The whole thing went inside the bar and bolted down normally.
Since protaper bars are slightly thicker than the normal alum. opening hole size, they are drilled to that size but only so deep. I need to pull out my largest drill bit and drill a bit deeper inwards so the Vibranator could fit in deeper inside the bar.
I'm an extremely satisfied customer!
I plan to upgrade to the vibration reducing grips this winter and this should help even more. http://spidergrips.com/spiderg/model...der-peak-grip/ I've used Spider Grips before on my KLR and love em.
It's still a thumper in the end, but the technology is out there to reduce vibs as much as possible
Alaska
Old 02-28-2014, 04:46 PM   #54
Fishnbiker
Tire smuddy, hook swet
Fishnbiker's Avatar
Oddometer: 444
Handlebar Damping - Gauges
Anyone tried good old Silicone Seal in the bars? Before I went to 3 cylinder engines, I used a caulking gun cartridge with bathtub caulk to fill the bars & let dry for a few days before using. Any inserts would need to be permanent if not cleaning out enough space while still soft. Total cost usually under $4.00
On another topic ... has anyone thought about installing a tachometer on the DR? I'm thinking of using my GPS for a speedo which opens up a space for a rev counter.
Ken / Fishnbiker
Felix, 95 Tiger - Dirty Cat,
Buzz, '08 DR 650 - To Infinity, & Beyond!
My Photos at: http://fishnbiker.smugmug.com
Fishnbiker screwed with this post 02-28-2014 at 04:55 PM
Fishnbiker is offline   Reply With Quote
Old 03-01-2014, 12:04 AM   #55
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,655
speedo/tacho
Get a trailtech vapor or similar. You get a speedo you can adjust to wheel size, a tacho, trip meters, temp guage and warning lights you can set to come on at preset temperature and rev limits.
Windscreen homemade jobby from perspex helps protect the 'dash'
Double take mirrors from adventuremoto are the bomb. Easy to fold in or remove altogether. Very hard to break in a fall, just folds in.
Quick throttle- billet throttle tube fro Zeta racing boasts 15% faster opening than stock. Has been working well.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson screwed with this post 03-01-2014 at 12:55 AM Reason: add photo
kezzajohnson is offline   Reply With Quote
Old 12-16-2014, 05:12 AM   #56
nzrian
nzrian's Avatar
Oddometer: 362
new dash
[IMG]Untitled by Rian2008, on Flickr[/IMG]
If you don't know where you are going, any road will get you there.
-Lewis Carroll.
nzrian is offline   Reply With Quote
Old 12-16-2014, 06:50 AM   #57
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,891
peg position
350R
plugeye is offline   Reply With Quote
Times are GMT -7.   It's 09:42 AM.
