Old 04-03-2013, 07:19 AM   #1
amnon_d OP
Oddometer: 4
KTM SMC690R muffler problem
Hi there,
I fitted my SMC690R model 2012 with a new Akrapovic slip on exhaust, the one recommended by KTM 76505099000
Problem is the bike stalls if I ride without the silencer piece.
Does anyone know of this problem?
Thanks,
Amnon.
amnon_d is offline   Reply With Quote
Old 04-03-2013, 07:36 AM   #2
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,818
The 690 requires a lot of back pressure, hence the need for the silencer.
Old 04-03-2013, 10:38 AM   #3
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,899
did you do the 15 minute idle FI reset ?
wrk2surf is online now   Reply With Quote
Old 04-03-2013, 11:04 AM   #4
amnon_d OP
Oddometer: 4
Does it mean I can't ride it without the silencer?
My mechanic suggested to saw the netted part of the silencer off but I was reluctant to do that.
He also said there are two other mappings but they are for bikes that had the full system replaced (not just the slip on which is what I had).
He said he'll find out if it is OK to use that.
Old 04-03-2013, 11:06 AM   #5
amnon_d OP
Oddometer: 4
Yes I did all that. I can't see why the problem after all this is the muffler that KTM suggest.
Old 04-03-2013, 01:58 PM   #6
Ranies
Oddometer: 38
You need to go to dealer and load a new map, akra map or evo 1 if your filter is modified.
Its not enough to do the 15 min reset, the bike needs more fuel than the 15 min procedure can fix.
Ranies is offline   Reply With Quote
Times are GMT -7.   It's 08:24 AM.
