Old 03-19-2013, 03:05 PM   #2086
pilacs
pilacs's Avatar
Oddometer: 73
Question Help needed
Is there anybody in the Orlando,FL area who can load up the stock map for me?
I have a custom map now,but my gas milage is a mess.Bike runs perfect with a 100 to 110 miles range before the light come on.
2007 990ADV. Please let me know if you can help. I do have the cable,but no idea how to do it. Thanks in advance.
pilacs is offline   Reply With Quote
Old 03-19-2013, 03:28 PM   #2087
SixDays02
SixDays02's Avatar
Oddometer: 274
The official download link @ tuneecu.com is out of bandwidth.
Any alternative download links?
SixDays | Croatia
SixDays02 is offline   Reply With Quote
Old 03-19-2013, 04:11 PM   #2088
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 935
See link in reply #2068
itS working.
690R
Old 03-19-2013, 04:45 PM   #2089
Imachimper
Newer than Noob
Imachimper's Avatar
Oddometer: 135
It's pretty easy. Take your panties off and give it a try
Imachimper is offline   Reply With Quote
Old 03-19-2013, 06:10 PM   #2090
Gustavo.Ramos
Oddometer: 935
Two or three thread pages back there is a less than 10 minute vídeo with a very clear HOW T about changing maps on the 990. A few pages back there is a link with an archive with the most relevant bits of information of this thread.
690R
Old 03-20-2013, 09:32 AM   #2091
Themastermike
Passin gas
Themastermike's Avatar
Oddometer: 791
ok on base, what on R
Originally Posted by moto-treks View Post
There are two categories of 990 maps; years 07-08 and then 09 and up. Last time I looked the maps say what year they are for, like 07 or 10. As for changes, I've always just downloaded a map for the correct category, in my case 09 and up, and compared it with what I'm currently running.
How about on the R side, which years have the same map?
BBF 03-09-13 "It is cool. I was playing dakar racer It truly was a gr8 day of riding you bitch"
Themastermike is online now   Reply With Quote
Old 03-20-2013, 12:12 PM   #2092
Gustavo.Ramos
Oddometer: 935
Correct me if i'm wrong, but the R map version suits all versions from 09 onwards
690R
Old 03-21-2013, 06:22 AM   #2093
KTM Pilot
KTM Pilot's Avatar
Oddometer: 439
I went back to page 130 looking for the archive link for the best of this Tune ECU thread and can't find it - Has anyone out there bookmarked it??
Smugmug $5 discount coupon # 2ucrtCWwf7D7A
KTM Pilot is offline   Reply With Quote
Old 03-21-2013, 06:35 AM   #2094
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
You mean this?
http://www.advrider.com/forums/showp...postcount=1927
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 03-21-2013, 09:37 AM   #2095
Gustavo.Ramos
Oddometer: 935
Vid here:
http://www.advrider.com/forums/showp...postcount=2071
Page 139, post 2071
690R
Old 03-21-2013, 08:24 PM   #2096
KTM Pilot
KTM Pilot's Avatar
Oddometer: 439
Awesome - thanks
That's it!
(page 129 naturally!!!)
Old 03-31-2013, 05:59 AM   #2097
Themastermike
Passin gas
Oddometer: 791
Driver set up
Originally Posted by Joe View Post
Was having a hard time with the USB driver until I found this. Thanks for posting
Ditto, I found this post on page 102, I was in a no connect state on Windows 7 until I followed thru these steps.
Thanks for the help.
Old 04-03-2013, 08:16 PM   #2098
OZbeemer
OZbeemer's Avatar
Oddometer: 443
Questions on 2008
So hopefully spring is really here in WI. I have been gearing up to deal with the FI concerns on my '08 990 adv. After getting all software and map/s from the website, and then reading the archived info here and the manual from the tuneecu site I have generated a few questions that I could use some help with.
1. 2008 has 2-2 wings exhaust. I figure I would use the akra us spec map, correct?
2. I had removed the "butterflies" to try and help with the snatchy throttle issue, should I re-install them?
3. I don't know enough about FI to adjust any of the values, so will the akra map help with the snatchy throttle issues and not kill the mpg?
Any help,direction, slap up side the head would be appreciated.
I also need to order the cable, unless someone here has one they want to sell. PM me if so.
500cc two-strokes are effective as laxatives too.
-Spikehead
OZbeemer is online now   Reply With Quote
Old 04-03-2013, 09:01 PM   #2099
felixblack1
felixblack1's Avatar
Oddometer: 196
1. akra map will work
2. Depends if it works for you. Did it reduce the snatchy throttle? If not I'd reinstall them. I found changing them to a minium opening of 20% removed that intial burst of power without significally reducing the snatchy throttle
3. I found the snatchy throttle got worse with the akra map. You will get worse mpg especially if you leave the oxygen sensors inactive.
I tried reducing the ignition advance found at around 5-8% throttle as suggested by someone here and intially found an improvement but since changing to aftermarket exhausts and changing to the akra map with the tweaked igntion maps I found the snathcy throttle worse then ever. I think I might go back to standard map with the tweaked igntion vs throttle map as that worked best for me.
felixblack1 is offline   Reply With Quote
Old 04-03-2013, 09:03 PM   #2100
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,100
Proceedure
>>> Yes, closest map available.
>>> Yes.
>>> Yes and No. The Akra map has the O2 sensors turned off, this kills mileage. So that will be your first modification in Tune Ecu. Turn on the O2 sensors, turn off the SAS and install.
>>> Get all the basics nailed down first. Valve adjust, fresh plugs, throttle position sensor adjusted, install acra softwre, sync the throttle bodies with an external vacuum gage, cool down, reset adaptation, 15 min idle, and ride it.
>>> answer above
Once you do all this, then you can start the tweaking process. Smooth the ign, add/remove fuel, etc.
"Son, you can't do both"
Times are GMT -7.   It's 05:40 AM.
