Old 04-02-2013, 09:53 AM   #1
HellSickle OP
Scone Rider
HellSickle's Avatar
Oddometer: 9,519
Adjusting wheel size on 990 odometer?
My odometer is off by at least 5 miles per hour at highway speed. I see the wheel circumference pop up on the odometer at startup, but I can't figure out how to adjust that in the computer. I have been all through the owner's Manual and pushed every conceivable combination of buttons.
Help?
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 04-02-2013, 12:44 PM   #2
Peanuts
Peanuts's Avatar
Oddometer: 1,698
09 onwards? You have to cut the brown/black striped wire on the speedo connector and leave it cut to enable access to the wheel size function.
To adjust the wheel size
1- press MODE to go to TRIP 1
2- Hold the MODE key for around 10 sec
3- It will show actual wheel size. Use the MODE key to increase the wheel size and the SET key to decrease it
4- Hold the MODE and SET key to exit
The default size on the 990R is 2205mm circumference for the 21" wheel.
19" - 2040 mm
17" - 1882 mm
so if yours is 10% out, adjust the circumference figure by 10% and go try again :)
Peanuts screwed with this post 04-02-2013 at 12:51 PM
Peanuts is offline   Reply With Quote
Old 04-02-2013, 02:33 PM   #3
HellSickle OP
Scone Rider
HellSickle's Avatar
Oddometer: 9,519
19" - 2040 mm
17" - 1882 mm
Old 04-02-2013, 02:52 PM   #4
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,030
Just a thought...
19" - 2040 mm
17" - 1882 mm
There is a pretty big difference in tire circumferences between types, brands, etc.
I got into the habit of measuring the distance (in millimeters) it takes to roll the bike forward until the same point on the tire touches the (flat, smooth) ground. It takes a few minutes but then you know your favorite tire size.
Having put tons of bicycle speedos on roadracing bikes/street customs over the years this makes a difference- they are usually more accurate than anything coming from the factory!
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 04-03-2013, 11:34 AM   #5
Rally_West
Central Scrutinizer
Oddometer: 144
Does this trick for 2007 or just the '09 and later? Mine is off about the same.
'07 450EXC Sold but not forgotten...you will be replaced soon.
'07 990 Adv...BOOYAH!
Rally_West is offline   Reply With Quote
Old 04-03-2013, 02:24 PM   #6
Peanuts
Peanuts's Avatar
Oddometer: 1,698
Early bikes with seperate speedo have less flexibilty of wheel size.
Instead of choosing the circumference (or how far the wheel travels when it does one full turn) you only get to choose from 21", 19" or 17".
Try setting it to 19" if you have 21" wheel, its close to GPS speed, but there is no safety factor to protect your licence ;)
Old 04-03-2013, 03:08 PM   #7
scottrnelson
Team Orange
scottrnelson's Avatar
Oddometer: 1,509
I was able to modify my 2008 using the mode button as described. I tried all of the settings and compared it to my Garmin Zumo 550. The 19" wheel setting is within one mph at all legal speeds for my bike (which has a 21" front wheel).
So now I have an accurate speedometer and an inaccurate odometer. The KTM odometer indicates that I have traveled about 3-5% fewer miles than my GPS indicates. I can live with that, although it makes the fuel mileage calculations look even worse.
Old 04-03-2013, 10:32 PM   #8
Jonny955
Jonny955's Avatar
Oddometer: 275
Just as a comparison, I checked the accuracy woth GPS the other day.
Bike: 990 (2012 model) with standard 21" front wheel & Pirelli Scorpion
GPS: Garmin Montana
What I found surprised me a little. The speedo reading on the KTM is pretty accurate and within ~2.5%. It's not so easy to gauge at lower speeds due to the whole integer reading so these are as accurate as I could get in the time I had, based on a steady straight line ride;
KTM 31mph = Garmin 30mph
KTM 40mph = Garmin 41mph
KTM 70mph = Garmin 68mph
KTM 100mph = Garmin 97.something mph (private road, of course )
If I change mine to the 19" wheel setting, the speedo will under-read by a greater margin.
Jon
Jonny955 is online now   Reply With Quote
Old 04-21-2013, 12:16 PM   #9
HellSickle OP
Scone Rider
HellSickle's Avatar
Oddometer: 9,519
19" - 2040 mm
17" - 1882 mm
Cut the wire, still doesn't do anything. Engine off or engine on, doesn't matter. You don't suppose I need to move it for a bit first? That's the only other thing I can think of. I sure would like to have an accurate speedometer, but I'm about ready to button it back up and live with it.
Old 04-21-2013, 04:16 PM   #10
Peanuts
Peanuts's Avatar
Oddometer: 1,698
Did you have TRIP 1 display showing before you pushed the MODE button again and held it a while?
Old 04-21-2013, 08:04 PM   #11
HellSickle OP
Scone Rider
HellSickle's Avatar
Oddometer: 9,519
Yup. Held it up to 30 seconds in both trip 1 and trip 2. Nada. Definitely cut the brown/black (equal-stripped wire).
Old 04-21-2013, 09:44 PM   #12
BuilderScott
BuilderScott's Avatar
Oddometer: 989
great thread
My 950 is new-to-me and the speedo is about 6mph high at 80mph. If anyone has input on the 950 computer, ... Thanks for the input.
BuilderScott is offline   Reply With Quote
Old 04-22-2013, 12:38 PM   #13
HellSickle OP
Scone Rider
HellSickle's Avatar
Oddometer: 9,519
Don't the above instructions work for you?
Mine is a 2010 990. The referenced instructions did not work. My new HID bulbs arrived, so I'm ready to put it back together. Not knowing what the brown/black wire does, I'll have to solder it back together & button things up.
Edit: Google search shows that others are still struggling with this issue. I'm going to call my expert dealer tomorrow and see if he has any tips. Some of the instructions state to press both buttons while in trip F. I can't seem to get back to trip F now. Puzzled.....
HellSickle screwed with this post 04-22-2013 at 01:32 PM
Old 06-26-2013, 05:57 AM   #14
DeeGee
I'm a Yorkshireman thanoz
DeeGee's Avatar
Oddometer: 1,884
The above instructions don't work on the 950. I've just tried it in trip 1 and trip 2 and all it does is convert from MPH to KMPH.
Any ideas?
DeeGee is offline   Reply With Quote
Old 06-26-2013, 06:11 AM   #15
HellSickle OP
Scone Rider
HellSickle's Avatar
Oddometer: 9,519
Any ideas?
I gave up. Even my dealer couldn't help. I'm just living with the error.
Times are GMT -7.   It's 07:10 AM.
