Old 04-04-2013, 09:28 AM   #14
Guy Young
Guy Young's Avatar
Oddometer: 8,583
Originally Posted by TXjames View Post
I had a lot of trouble splitting mine for that very reason. What a PITA. It's very easy to damage the aluminum housing once this has happened so find the strongest purchase you can when splitting a stuck tranny. I think I anti-seized the pins on reassembly but it may not help since the clearance between pin and case is so small.
I hope you replaced that balancer shaft seal JVB. That's nasty. Or is that leaking down from the rear main seal?
Fook!, I'll be happy when I can get to that point.
I've finally managed to get the front u-joint spline to move back about an 1/8", but it's not staying there. Like it's spring-loaded or something. Not so sure there may be something amuck on the butt-end of the drive shaft where the splines engage the final drive.
I'm going to continue to slowly pull the rear frame section back and see what the front splined joint does. If it looks like it will continue to slide back and off, we may be okay. I can deal with the final drive splines later.
GB Young Services, LLC
Garage Project: http://gbyoung2.smugmug.com/Family/Garage-Project
Guy Young is offline   Reply With Quote
Times are GMT -7.   It's 08:21 PM.
