Go Back   ADVrider > Riding > Trip Planning
Old 03-26-2013, 01:06 AM   #1
404 Travels OP
Oddometer: 4
Anchoring a hammock to your bike
For my North-South America trip, I plan to mainly use my hammock (Hennesy). The main issue I foresee is finding two tree's or poles spaces nicely apart in a location that is suitable.
So, I am determined to use my bike as one of the anchor points, making it so I only need one tree/pole anywhere I go (much easier to find )
I know this guy did it (kinda), by running the tie line over the handle bars to second point (cheating) that can be pretty much be at any height.
I have searched high and low to find something that would allow me to simply use a single pole, the bike and a support for the bike, but haven't found a thing! Suggestions???
I am riding a 2008 650cc Versys
Cheers
404
404 Travels is offline   Reply With Quote
Old 03-26-2013, 01:16 AM   #2
404 Travels OP
Oddometer: 4
Also, I know of this one, but it requires some serious ground anchors and what seems to be a lot of webbing & really complicated!
Anything simpler?
Old 03-26-2013, 08:36 PM   #3
nuttynu
nuttynu's Avatar
Oddometer: 979
Why not just tent ? To much of a hassle setting up ??
nuttynu is offline   Reply With Quote
Old 03-26-2013, 09:28 PM   #4
404 Travels OP
Oddometer: 4
I'll be bringing a tent too, it was simply to be able to use the hammock more. Because hammocks are awesome
--404
Old 03-26-2013, 10:35 PM   #5
babarnette
babarnette's Avatar
Oddometer: 903
Sounds like a bad idea to me, but I'm not a big hammock fan.
babarnette is offline   Reply With Quote
Old 03-27-2013, 11:44 AM   #6
DADODIRT
DADODIRT's Avatar
Oddometer: 3,564
Take some pics for Face Plant.
I find your lack of faith in the force disturbing.
DADODIRT is offline   Reply With Quote
Old 03-27-2013, 11:50 AM   #7
Wlfman
Wlfman's Avatar
Oddometer: 1,292
Sounds like one of those "Hold my beer, watch this..." moments.
Don't think I would want to take the chance of several hundred pounds falling on me in the night nor the damage to the bike itself...
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 03-27-2013, 12:41 PM   #8
NCK
NCK's Avatar
Oddometer: 480
the hell with the negative nancys! let's figure this out!
NCK is offline   Reply With Quote
Old 03-27-2013, 12:46 PM   #9
MatatuPuncher
MatatuPuncher's Avatar
Oddometer: 37
You should be able to find two anchoring points most of the time. For those times that you can't, just go cowboy style with one end of the hammock attached to the bike. If you rig it up right, the portion where your head is should provide enough room. Down sides are you will still need a sleeping pad and you could have condensation issues.
Have a good trip!
MatatuPuncher is offline   Reply With Quote
Old 03-27-2013, 12:54 PM   #10
Solarbronco
Oddometer: 493
I do alot of backpacking. Even out west, I have almost no trouble finding two trees to secure my rig. A good tip, get a mat for your back or you will freeze all night. I have a lightweight thermarest that rolls up like a loaf of bread.
Alot of great info can be found on Backpacking sites.
Solarbronco is offline   Reply With Quote
Old 03-27-2013, 08:08 PM   #11
250senuf
250senuf's Avatar
Oddometer: 2,414
How about tying one rope to the rear of the bike running it forward "draped" over the bar to the hammock? The pic you linked to has the rope coming from the side of the bike. What I'm suggesting is using the weight of the bike against itself. The rope is trying to lift up the rear but since the rope is going forward, not up, there is not much "up" force. The rope is also pushing down on the front due to the hammock. Maybe, maybe not??
Do you have a centre stand or just the sidestand?
Not all who wonder are confused
250senuf is online now   Reply With Quote
Old 03-28-2013, 10:10 AM   #12
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,991
Ok, this is what i would do. Be advised I have not tried this. I usually just sleep on the ground. But this is how you construct an anchor point to extricate a stuck vehicle when there is no ready anchor point.
You will need 2 stakes, 3 if the ground is soft.
Do not tie the hammock to the bike. Pass the rope over the bike at the lowest point of the seat and perpendicular to the bike. This is for stability.
Drive the 1st stake into the ground at an angle away from the bike. Tie the rope to the bottom of stake one.
Tie a short rope to the top of the 1st stake. Drive in a 2nd stake a short distance from the 1st. Tie the short rope to the bottom of the 2nd stake.
The hammoc, the ropes and stakes should all form a straight line.
2005 Ural
2005 BMW F650GS
2012 Triumph Tiger 800xc
Yankee Dog is offline   Reply With Quote
Old 04-03-2013, 10:03 AM   #13
Austinius
Austinius's Avatar
Oddometer: 5
+1 for Over the Bars
+1 on this Idea. And you should test it. Using the long wheelbase of the bike should be much more stable than one side or the other. Might need to leave it in gear so you dont roll it forward on you. Go forth and test! Put up a pic if you can get it to work!
Austinius is offline   Reply With Quote
Old 04-04-2013, 09:12 PM   #14
RVDan
RVDan's Avatar
Oddometer: 2,665
I think you need a pole slightly taller than the bike. Stand it beside the bike. Tie your hammock to the top of it, and then tie it to the bike in a way that your weight in the hammock is trying to lift the bike rather than pull it over. Of course the pole would have to be fairly strong, and you'll have to anchor it to keep it from falling side to side, but it might work
Sometimes wheelies happen
Originally Posted by RedRocker
You can never have too much hook.
RVDan is offline   Reply With Quote
Old 04-08-2013, 09:17 AM   #15
Throttlemeister
Oddometer: 3,878
On the other hand an ultralite cot will be far more versatile and still keep you suspended above the ground.
www.throttlemeister.net
Throttlemeister is offline   Reply With Quote
Times are GMT -7.   It's 06:21 PM.
