Old 04-05-2013, 01:08 AM   #1
Kurlee OP
2009: A Bike Odyssey
Kurlee's Avatar
Oddometer: 1,929
R1200GS Final drive removal
Original final drive kicked the bucket at around 23K miles, bought a new one from Max BMW as well as some Galfer rotors. I was hoping that it would be a smooth process but I've had issue after issue. Bike is a 2006 standard GS
Right now I'm stuck on removing the collar that slides into the outside lower pivot point connecting the final drive to the swingarm. It moved a little when I removed the Torx bolt from the opposite end but it has not moved a bit since. Destroyed several drift pins and have pretty much come to terms with having to order all new collars and bolt.
Schematic
Parts that are stuck
02 33 17 7 665 148 PIVOT PIN
16 33 11 7 684 996 GASKET RING - 38X30X2,5
10 33 17 7 665 149 PIVOT PIN
I've been following these instructions for the removal, but I'm not having any luck/missing something.
http://www.mattmccabe.com/r1200gs/r1...el%20drive.pdf
Any help or experience is much appreciated. I have never heard or read about anyone replacing one of these warlocks by themselves, so I'll do a write up when I'm done.
Kurlee is offline   Reply With Quote
Old 04-05-2013, 06:38 AM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,622
I've done it a few times. Does yours have a lot of corrosion on it? I found that an appropriatly sized socket is the best "drift" to push out the collar.
Jim
JimVonBaden is online now   Reply With Quote
Old 04-05-2013, 07:49 AM   #3
Disco Dean
Disco Dean's Avatar
Oddometer: 1,283
Jim
I'm with Jim on it. It can corrode and stick into the bearing race. I got mine out with heat and a press If you have the swing arm off. I did not need to take it off... it came out with a drift though. You will need a new bearing(s) / seals, also - they are cheap... The left side (bolt side) needle bearing was severely corroded.
In fact when I did mine as a matter of course I replaced the two sleeves, and both bearings and seals while I was at it.
Not much more to say. Sorry...
youmoveyou
As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?
Disco Dean is offline   Reply With Quote
Old 04-05-2013, 09:31 AM   #4
roadtrip22
roadtrip22's Avatar
Oddometer: 333
Useing a heat gun to heat up the pivot pin helps too. BMW like to put some good lock tight on there that will make it a pain to remove the bolt. Some good heat and it comes apart easier. Also while your there don't forget to inspect the driveshaft for damage and clean up the splines.
Follow me on Facebook--- http://www.facebook.com/2wheeladventures
100 things all GS owners should read---http://advrider.com/forums/showthread.php?t=836736
Repair and Maintenance DVD's--- http://www.jimvonbaden.com/
roadtrip22 is offline   Reply With Quote
Old 04-05-2013, 10:26 AM   #5
Kurlee OP
Kurlee's Avatar
Oddometer: 1,929
Jim
Thanks! I'll try that. I haven't noticed much corrosion on it, but I'm sure it's there. I'm tearing this apart in the parking lot of my Navy barracks so I'm pretty limited when it comes to tools.
Old 04-05-2013, 11:09 AM   #6
simoneau
Biker/Adventurer/Retiree
simoneau's Avatar
Oddometer: 204
Remove #10 by installing #12 about 4 or 5 turns only and hammer #12 to drift #10. Use a longer bolt than #12 if required to drift #10 all the way out. Then an appropriately sized socket slightly smaller than #10 and an extension can be use to drive #2 out. Hope this helps.
Randy
2014 BMW R1200GSA (OLIVE)
Ride it like you stole it, care for it like you'll keep it, never let it cool down and it'll last forever!
simoneau is offline   Reply With Quote
Old 04-05-2013, 07:15 PM   #7
JimVonBaden
"Cool" Aid!
Oddometer: 54,622
Good advice.
Jim
Old 04-06-2013, 03:40 AM   #8
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,077
Ummm....wouldn't a bottle of Jim Beam give the neccessary lubrication for easy removal over at the repair shop on Base?
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 04-06-2013, 04:49 AM   #9
bobframe
Oddometer: 344
This is pretty cool...where does it come from? Is it available for most repairs on the GS?
bobframe is offline   Reply With Quote
Old 04-06-2013, 03:35 PM   #10
JimVonBaden
"Cool" Aid!
Oddometer: 54,622
That is a section of the factory DVD manual. YOu can get them from the dealer.
Jim
Old 04-07-2013, 10:35 AM   #11
mwood7800
Oddometer: 611
This might help. http://advrider.com/forums/showthread.php?t=861093
mwood7800 is offline   Reply With Quote
Old 04-17-2013, 12:50 AM   #12
Kurlee OP
Kurlee's Avatar
Oddometer: 1,929
Got it out! New FD is on and everything will get finished and ready for the road in a few days or whenever I get some time off work while the sun is up.
Times are GMT -7.   It's 07:24 PM.
