Old 04-05-2013, 10:21 PM   #4111
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,019
Originally Posted by RideWithMe View Post
Cruz, your getting mixed up with old Transalps
Is it true you and Tim have got a buy one get one cheaper Strom deal.
Would have to be a buy one get one free deal.
Wonder what yours weighs compared to Andy's?
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 04-05-2013, 10:40 PM   #4112
Hoots
Hoots's Avatar
Oddometer: 1,452
Originally Posted by chrisamberely View Post
yah I hear what you are saying, so maybe 'rideability was a better word to use. I found mine was better on the back wheel after its slimming routine.
I reckon it just took some of the weight off the butt end and there was less of a trend to slide out under power when doing tight hillside turns up the single trax stuff.
It also helped its turning no end, the butt slides around real nice when u get on the gas - kind of nicely controlled. Doesn't seem to push into corners so much when the speeds up either.
Hard to think of a better bike on open fire trails ...
Hoots is offline   Reply With Quote
Old 04-06-2013, 12:23 AM   #4113
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,783
With or without rider
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 04-07-2013, 03:59 AM   #4114
chrisamberely
USMC. (retired).
chrisamberely's Avatar
Oddometer: 140
I'm using mine on tite single trax more and more. I backed off the steering stops til they were non existent, haven't had any problem on switch backs at all.
I find it likes to steer with the butt end, but as I said, the work I've done seems to aid that. I rode guymcfly's just a few days back. He took an extra 10 lbs or so off of his and like he said, his dry weight is the same as the new wrf 450 wet! And he'd trade the extra mass for the long service schedule and its just like having a monster mx bike!
chrisamberely is offline   Reply With Quote
Old 04-16-2013, 12:39 PM   #4115
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,070
Upgraded my previous radio only hard wired comms to the full Starcom Advance Unit so I can have music and phone as well as UHF, hard wired so no batteries to charge like on a Bluetooth set up. Got it through Dale (DMME) on the forum, great service as always.
Fitted the Bulkhead connector on the Dash for easy connect/disconnect.
Made up some light protectors out of some Perspex “keep it simple” they work.
Don't Tempt Fate Taunt It, Right Here Right N0W
KTM 690 EVO 1 Rally Raid Build Thread
KTM 690 EFI Idiots Guide
KTM 690 Troubleshooting Guide
El Ponkin screwed with this post 04-16-2013 at 11:58 PM
El Ponkin is offline   Reply With Quote
Old 04-17-2013, 03:02 AM   #4116
fatbloke49
fatbloke49's Avatar
Oddometer: 77
Comms
I did the same except I went for the Bikecomm Wireless bluetooth unit. I don't mind charging the unit up as I wont be doing the APC everyday.
Got Mine from Dale at DMME also
It's great, UHF and phone cut the music out when someone talks. Can still walk around the bike with your helmet on and still hear whats going on. Actually, you can walk about 15-20m away from the bike and you can still hear whats going on.
Nearly set the bike up for the APC, last on the things to do is re-grease the swingarm and linkages, Install new tyres.
Got the dash all sorted out,
  • 4 x 12v mini fuse holder
  • 1 x 12v from accessories
  • 1 x 12v direct
  • Switch for accessories (just encase I need the power to start the bike I can switch off things drawing power.
  • UHF installed
  • Iphone with handlebar mount and hardwired for charging
  • GPS unit hardwired with ram mount
  • Bikecomm unit all installed
  • PTT bracket made up on the handlebars
fatbloke49 is offline   Reply With Quote
Old 04-17-2013, 12:38 PM   #4117
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,070
Did you hardwire the Radio, I have a UH720SX hardwired but it is only 2 watts, I want to upgrade to a 5 watt which will allow me to use a good remote GI aerial to get good range but don't want charging hastles and most have warnings about they won't work whilst charging or you can't leave them on-charge. May end up going to a remote head car unit like the GME TX3520.
Andy
Old 04-18-2013, 05:25 AM   #4118
fatbloke49
fatbloke49's Avatar
Oddometer: 77
Dash
Andy
No, I haven't hard wired the UHF as I cant find a battery eliminator for the uniden UH078 5w. I did however have a look at the 240v charger for the batterys and the input to the charger is 12v, so I was thinking of unplugging the 240v supply and wiring in a 12v male cigarete lighter end and charge up the spare battery as I ride in the tank bag. If that makes any sence!!
1 battery usually does a one day ride anyway but usually carry the second one as a spare.
Old 04-18-2013, 01:58 PM   #4119
podge NT
Podge NT
podge NT's Avatar
Oddometer: 2,286
You can get a 12v charger for the UH078. The 240 needs 240 in then it reduces to 12 so I dont think it would work the way you plan.
http://share.findmespot.com/shared/f...1IWs2Hg87TZcsW
Plan, what plan, there is no plan
podge NT is offline   Reply With Quote
Old 04-19-2013, 12:55 AM   #4120
El Ponkin
Bloodrunner
El Ponkin's Avatar
Oddometer: 2,070
Am I right in saying you can't use it whilst its charging ?
Old 04-19-2013, 12:59 AM   #4121
sir phily
sir phily's Avatar
Oddometer: 356
That's the way i have been running mine i just run 12v into the back of the charger with my spare battery in my tank bag,
charges while I'm riding then the next day swap them over,
worked fine for a 3 week ride a few months ago.
Cheers Phil
sir phily is offline   Reply With Quote
Old 04-21-2013, 12:23 AM   #4122
fatbloke49
fatbloke49's Avatar
Oddometer: 77
I think your right Andy, It doesn't transmit while charging.
Looks like ill have to make the 12v car charger do for charging the spare, even thou it's designed for the whole radio with the battery attached
Old 04-21-2013, 12:31 AM   #4123
podge NT
Podge NT
podge NT's Avatar
Oddometer: 2,286
No, if you get the UH078 NB then you can transmit while charging
Old 04-23-2013, 01:42 AM   #4124
ktmpunter
freefall guru
Oddometer: 73
transmits while charging OK
[QUOTE=podge NT;21234062]No, if you get the UH078 NB then you can transmit while charging
My UHO76 charges while riding, you can get the correct charger that plugs on the bottom and runs from a cig lighter outlet, El Ponkins familiar with my set up......worked fine in the first APC and all other rides. I also rigged up the desk top charger with a cig plug and can use that as well.
Bought I high gain ariel from Prestige Electonics and get extra distance on that.
All run via my Autocom and into the helmut
PM me if you need help....
cheers
Catman
If you can ride it in, you can ride it out.....
ktmpunter is offline   Reply With Quote
Old 04-28-2013, 03:27 AM   #4125
Hrspwr Hero
wipe off 50 or.....
Hrspwr Hero's Avatar
Oddometer: 76
Just thought I would share my experiences with latest mods to my 690.
1. Leo vince slip on & akro map. This is like dropping to a 14t sprocket! You gain so much more down low. No more slugging. Much more responsive and more hp I'm sure. Also makes an awesome note without the bung up it
2. Swapped out rear spring for a 92n/mm. Before this the arse would squat so badly under power, so very difficult to float the front over holes etc. also front would pop up too easily if you tried to get moving on a steep hill. Now it will power wheely with ease and still manages to make good headway up the steep stuff. Great for getting both wheels off the ground too!!!!
Hrspwr Hero is offline   Reply With Quote
Times are GMT -7.   It's 09:08 PM.
