Old 04-08-2013, 04:05 PM   #7711
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 395
Originally Posted by elsalvadorklr View Post
hey that was fast!!!!!!!!!!!!!!!!!
thanks
I was wanting to know specifics on the topend oil feed pipe and what dimensions you made your new one out of when you were testing the oil flow sensors and switches etc...
thanks!!!!!!!!!!!!!!!!
Ups ,that was 2 years ago .
I cut the original in two halfs and add T-Piece to the Pressure switch .
Don't remember to messure it .
I go to the Hardware shop , drop it on the Desk and ask for a T and Pipe in the same diameter .
Thats all i remember , Sorry
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 04-08-2013, 04:24 PM   #7712
mcma111
mcma111's Avatar
Oddometer: 12,920
Christian,
Oil pipe on the way Tuesday.
S 'n SF
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-08-2013, 04:43 PM   #7713
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Did you bugger up your oil pipe somehow Christian?
'87 XR600R, 17's and fully black
deejay_xr is offline   Reply With Quote
Old 04-08-2013, 04:46 PM   #7714
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by mcma111 View Post
Christian,
S 'n SF
STEVE HOLD OFF MINE IS FIXED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
the reason I asked was that I remembered schrauberklaus actually modified his
I had a shope zinc solder it
no leaks
thanks man
elsalvadorklr is offline   Reply With Quote
Old 04-08-2013, 04:48 PM   #7715
elsalvadorklr
southern xr rider
Oddometer: 4,154
thats something no worries
do you remeber the size of the internal pipe?
the more I think about the more it seems that internally the pipe is no bigger than 1.5mm
THATS where the pressure is caused on startup
thick oil will not flow thorugh it
I tested this while off I couldnt even get it to move yet somehow while the engine gets hot and the oil thins you start to get flow
do you remember any of this klaus?
thanks
Old 04-08-2013, 05:39 PM   #7716
Captain115
Captain115's Avatar
Oddometer: 287
Originally Posted by Dino3310 View Post
It's been a while and i finally got the Pig out for a weekend into the 'Tongariro national park'.... 2 days of Brraaappp Brappppp
Nice pics there, looks like some great places to ride! Is it like here (or Queensland anyway) that you're meant to have a registered bike to ride the national parks since it's technically a 'public road'?
Also to the various suggestions about the mark in my XR's head. It can't be the choke plate because I took it out and replaced it with the billet version only a couple of months ago, and the stock plate was still completely intact. Could've been dirt as someone mentioned...or maybe parts of the piston when the 630cc kit detonated in the past?
Shouldn't matter too much though right? Might be odd heat build-up or something but I guess as soon as it's carbon up it won't matter anyway.
Next questions:
1) Loctite...what do you loctite in an engine...and which type? Ie, Red loctite (223 or whatever it is) on certain nuts etc? I looked through Steve's build but didn't notice any so matter it isn't done at all? I've just been caught offgaurd by the vibrations from this big thumper and watched as 4 or 5 external bolts came loose and disappeared into the bush.
Don't want that happening inside my new motor!
2) Does anyone have photos of a ventura rack mount? I cannot for the life of my figure out where the L brackets bolt to??? XR650L should work the same too, if you have a pic of that?
Cheers,
John
Captain115 is offline   Reply With Quote
Old 04-08-2013, 06:17 PM   #7717
joexr
Oddometer: 3,773
no leaks
thanks man
Make sure you can blow thru it at least . It's real easy to solder a small tube like that closed.
Old 04-08-2013, 08:06 PM   #7718
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,635
anybody have any GOOD late model tranny's for sale? Might as well grab the whole thing.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 04-08-2013, 09:26 PM   #7719
mcma111
mcma111's Avatar
Oddometer: 12,920
Now what??
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-08-2013, 11:09 PM   #7720
Dino3310
Oddometer: 673
Cheers,
John
Hi John
a lot of the riding to the tracks were via metal public roads so we where all plated, the 42nd traverse area is 4x4, quad, mountain bike areas so anything goes, come winter where going to trailer there in full offroad get up for a weekend of trail bash heaven.
i got a ventura mount on mine but mine was welded on, you can just see it next to my tool holder in the photo
Dino3310 is offline   Reply With Quote
Old 04-09-2013, 06:30 AM   #7721
Schrauberklaus
***ifyer
Oddometer: 395
thanks
The minimum Temperature for my Engine is in the workshop with the Aircon full running at 22 degree
No problems with the Oilflow as long as the Pump is not dry .
Air in the pump however cause a delay up to 95 second on my Pump tests bevor the Oil flow .
And thats not kickstart time thats a spinning oilpump at idle speed submerged in 20W50 at 22 degree .
The Pipe is intern 2,5 mm if i remember correct
Klaus
Old 04-09-2013, 07:41 AM   #7722
elsalvadorklr
southern xr rider
Oddometer: 4,154
flow at top banjo or lower banjo?
thanks
Old 04-09-2013, 08:53 AM   #7723
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,635
Now what??
My other 600 Motor. 88-. Going to update the tranny. THIS motor I'm sure will need work.
Old 04-09-2013, 09:43 AM   #7724
deejay_xr
deejay_xr's Avatar
Oddometer: 496
Got some brackets welded up to the subframe this afternoon to add a pair of passenger pegs
Xr briefly caught fire
I'll post a picture once I have the brackets cleaned up and painted and the pegs mounted
Old 04-09-2013, 10:03 AM   #7725
mcma111
mcma111's Avatar
Oddometer: 12,920
Don't jump the gun just yet. I have that trans in my $200.00 XRL motor that I haven't opened up yet. It may be good. Well except for the counter shaft.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 06:31 PM.
