Old 02-15-2013, 10:16 AM   #31
ramon
weezin' the juice!
ramon's Avatar
Oddometer: 1,129
I say spend the $2100, I doubt you'll regret it. I always start with fixing the suspension first, then farkle away after that. I think front and rear Ohlins shocks for my K1300s, came to about $2300 and it was money well spent. I say go for it!
"...if you don't like the price then move on because I don't give a shit...it's my bike and I will sell it for whatever I want." Craigslist SF posting
ramon is offline   Reply With Quote
Old 04-06-2013, 09:20 PM   #32
curvecrazy
Oddometer: 4
Originally Posted by SnappNBrrap View Post
if you want to tear up the corners you probably dont want an FZ1. it just has a really long wheelbase and doesnt feel super flickable. ive heard if you put a taller tire on the FZ it is a little better and balances out speedo error and helps the MPGs a bit. but it is a rocket out of the corner, guaranteed.
The VFR800 is my pick for the best all round motorcycle period but its all preference.
Not really. In stock form it may be somewhat what you describe. Sure. Do a couple cheap mods to it such as different dogbones on the rear suspension, shock rebuild with heavier 10wt oil and cutting the front springs down and installing longer spacers to stiffen the front end and you will end up with a bike that is higher in the rear by an inch or so with better road feel all around and Yes, it will then do corners for sure. Will an outright sportbike beat you in a roundabout? Well, sure, if he is on supersport tires and you are on sport tourer's LOL. No, seriously, that happened to me. And he claimed superiority of his gsxr as the reason when the truth is I let him go cause there was no point taking the sport touring tires [michelin pilot road 1's] past the point of adhesion while he's running it out on top notch squishies. I mean, I just let off a little and right behind him still until he peeled off onto the straight and then I am going by on one wheel! Ha ha. Long bike. Don't handle? LOL You just need to set it up right. There are no peg feelers on mine. Ground right off and into the end of the peg like eons ago. Over 60K miles on her now and still rippin. My commuter. My stunt bike. My go to bike. My do it all bike. I'll say this. You have to be determined and skilled to leave a properly set up FZ1 skillfully piloted on good rubber but even on sport touring tires. Good brakes. Good engine once you clean up the carb. They are sensitive to air filters so keep that clean or replace it every so often if you want it to rip right. Headlights are all that outstanding. fwiw Bike is all day comfortable too. Enjoy.
curvecrazy is offline   Reply With Quote
Old 04-07-2013, 02:27 AM   #33
richarddacat
abnormal character
richarddacat's Avatar
Oddometer: 3,452
cont. -
Love the Traxxion upgrade, and only did the forks, rear shock was rebuilt not long ago.
Great improvement, riding on "tighter" rails, feels lighter, no more brake dives, falls right into place at every curve and it even ignores rain grooves.
Besides the Russell, this is the second best improvement I've made to the bike.
* 05FJR/88K75c/97M3 *
Mid-TN Tag Riders
richarddacat is online now   Reply With Quote
Old 04-07-2013, 10:17 AM   #34
SimpleSimon
Aspiring advrider
SimpleSimon's Avatar
Oddometer: 3,399
You should also factor in the depreciation hit you are going to take on selling the bike. Have you looked at other options like Ohlins, Racetech?
5f? Is that like riding down a 90 degree cliff face into a lake of fire? I thought 4f was bad. Abdelhub
"Assembled Spectator Scoring With Incriminating Photographic Evidence" or A.S.S.W.I.P.E. - Granparacer
SimpleSimon is offline   Reply With Quote
Old 04-07-2013, 07:53 PM   #35
rockmurf
IBA #31100
Oddometer: 324
I don't think I read anything about rider training to improve your bikes capabilities. I had the traxxion fork and shock upgrade done to my 06 fjr and it was an improvement but my stock stuff had 50k miles on them. I also had an 06 fz1 because I too wanted something lighter to flick around. Hated the 06 fz1, bad/hard suspension and totally uncomfortable. FJR is in my opinion one of the best motorcycles out there. It is almost the total package. Canyon carver maybe not but I know some people, check the fjr forum, that really haul ass on theirs. There is no perfect bike and it is man's mission in life to pursue that unobtainable goal. Have fun and ride safe.
rockmurf is offline   Reply With Quote
Old 04-08-2013, 08:28 PM   #36
curvecrazy
Oddometer: 4
No problems with resale value if you pull off the upgrades. The shock can be switched right back out with the oem unit. The aftermarket sold seperate. In fact I just bought a Penske 8983 for my FZ1 that was exactly that situation. It's on the 01 FZ1 now and seems to be head and shoulders over the stocker. Its got ride height adjustability too so I went back to the stock dogbones and raised the rear instead via the shock. Only put 100 miles on her before work but big difference is apparent. The old shock had too light of a spring, was maxed out on the damping and likely due to the too light spring was wallowing around quite a lot. This shock put an end to that. Just literally put it on, set the static sag around 30-35mm and set compression and rebound in the middle of their respective ranges. Ended up clicking in two more clicks of compression and its working pretty good right now. Got the proper recommended spring supposed to be in the mail soon but, heh? Its working pretty good with a spring listed as 25# too heavy. I'm thinking it will only get better.
Old 04-09-2013, 07:00 PM   #37
gixxersteph
gixxersteph's Avatar
Oddometer: 623
I agree about money well spent on suspension, however the Ohlins route on my K1200S did not yield the same result that you encountered. Too bad because I liked the bike, except for its suspension.
I have spent money on several other bikes and agree that here the benefits of your hard earned cash are most noticed. If you love the FJR spend the dish and really enjoy the bike. Let me know when I can sign up for a test ride when it is done.
gixxersteph is offline   Reply With Quote
Old 04-09-2013, 08:59 PM   #38
ramon
weezin' the juice!
ramon's Avatar
Oddometer: 1,129
Originally Posted by superkram View Post
Hello all,
Love my '06 FJR1300A, I've added 12K miles in 7 months of ownership, including a 5,500-mile trip to Calfornia and back over the holiday break. Pros: fast, comfy, good looking. Cons: fat, heavy.
Now, the FJR is a great bike, and it's probably more capable than my skill levels. However, I find myself wanting something lighter and easier to carve corners with. Should I plunk down the money for a full Traxxion suspension with AK20 cartridges and a new rear shock? Would I still be dealing with the on/off characteristic of a shaft-drive mid-turn?
Or sell it and go for another sport-tourer (2nd gen FZ1, VFR800 VTEC) or a sport-bike with hard-luggage and LSL/Spiegler handlebars? Recently rode a Bandit 1250 with Givi luggage, wasn't impressed with handling. Loved a Gen1 FZ1, prob would love an Gen2 FZ1 with suspension & hard luggage.
After three pages of replies, what was your final decision
Old 04-15-2013, 07:32 AM   #39
superkram OP
Church parking lot rider
superkram's Avatar
Oddometer: 155
Still struggling to answer that one. Just got my tax refund.
"When the going gets weird, the weird turn pro." - Hunter S. Thompson
Now: 2009 K1300S, 2001 R1150GS
superkram is offline   Reply With Quote
Old 03-03-2015, 10:25 AM   #40
superkram OP
superkram's Avatar
Oddometer: 155
I think I'm gonna sell the R1100RS and CB350 for a down payment toward finding a nice used K1300S.
For a year now, I've been moving an R1150GS around the western US for fly/ride trips, and keeping it with various friends between trips. Not bringing the GS home anytime soon, but I'm ready to get a newer/nicer bike than the R1100RS for daily use and slab.
Old 03-03-2015, 10:53 AM   #41
eatpasta
Lawnmower Target
eatpasta's Avatar
Oddometer: 10,882
My vote is for add to the stable. If you like the FJR, keep it! If it does nearly exactly what you want just find the bike that does exactly what you want and use that bike on that day.
My dream is eventually to have that perfect 7 bike garage that covers every niche of the spectrum from hardcore dirt, to track bike. So my perfect garage might be something like KTM525, XR650L, 1150GS, FJ-09, FJR, Speed Triple, S1000. I doubt ill ever get there but a man can dream, right?
We shall not cease from exploration, and the end of all our exploring will be to arrive where we started and know the place for the first time.
T. S. Eliot
Originally Posted by Burnszilla
I was SO high, I could have hunted duck with a rake
Originally Posted by VxZeroKnots View Post
MX stuff isn't my cup of tea, but falling down the side of a mountain is
eatpasta is offline   Reply With Quote
Old 03-03-2015, 07:02 PM   #42
Dave W.
Oddometer: 204
06 vfr800
Below is my 06 VFR800.
I was a DIE HARD Honda worshiper so eventually bought one.
I found it to be one of the most over hyped-under performing bikes I'd ever ridden.
Sound= 9 out of 10- with 2 Brothers exhaust
Power 4 out of 10
Brakes 7 out of 10
Comfort = 6 out of 10
Fuel Economy 4 out of 10
Touring = 5 out of 10
Weight = 5 out of 10
Looks = 9 out of 10
Good luck in your search, but I would be stunned if a VFR800 was the answer to your question.
Dave W. is offline   Reply With Quote
Old 03-04-2015, 07:47 AM   #43
superkram OP
superkram's Avatar
Oddometer: 155
Power 4 out of 10
Brakes 7 out of 10
Looks = 9 out of 10
My sentiments exactly. I *LOVE* the looks, size, and sound of the 6th-gen VFR800 but disappointed with the fuel economy for its size and power output. To be fair, I'm 6'0 and 275 lbs with gear, there was no way I cd get 40+ MPG at sustained 75-90 slab speeds with the VFR800. Others may think fuel economy isn't an issue, but for the frequent high-speed slab riding I do for my daily commute and weekend trips, it's a factor.
Anyway, I announce this thread dead. I sold the FJR1300 in June 2013, had a -an '06 DL1000 for 10K miles until March 2014 (better in tight twisties, but still crappy economy on highway), an '07 Bandit 1250SA for only two months (great motor/size/weight, didn't like handling), then reached near-nirvana on my R1100RS with 115K miles in May 2014, not counting the 10K miles I've added since. The RS has great weight, balance, handling in twisties, comfort, and economy at speed.
Old 03-04-2015, 08:55 AM   #44
eatpasta
Lawnmower Target
eatpasta's Avatar
Oddometer: 10,882
OP if you havent ridden on of these, you need to. It may satisfy quite a lot of things for you
T. S. Eliot
Old 03-06-2015, 11:10 AM   #45
See red
See red's Avatar
Oddometer: 145
Good points, keep 'em coming.
The power and smoothness of the FJR are fantastic on the open road. With tax season, I can afford a Traxxion suspension and maybe a new Givi V47 top case to match the FJR's angular looks. But will I be happy? Does anyone else bitch in the morning and wish they had something lighter/narrower for commuting?
Or am I just a whiny, overfed, overpampered dolt?
FJR is a great bike, the one s.t. that is better all around for me would have to be NOT made anymore lol! I would look for a futura
My son is my angel, and I am his armor.
See red is offline   Reply With Quote
Times are GMT -7.   It's 05:02 AM.
