Old 04-09-2013, 04:44 PM   #1
graniterover OP
Oddometer: 37
No electrical power
2006 950 Adventure
Battery was dead (wouldn't hold a charge). Ordered a new one. A neighborhood kid has been helping me with some small projects. He put the new battery in and accidentally grounded the wrench on the aluminum plate above the battery.
No ignition, no power.
The ignition fuse (10amp) seems fine. With a tester there is no power to the fuse that I can see. Of course, at the same time, the battery on my multi meter died so I was only using a test lamp.
Either way, the manual has the power from the battery going to the 10amp fuse, then to the ignition.
Any suggestions on what I should test for next?
Thank you in advance. Hoping to get this going by Saturday so I can ride!
Mark
graniterover is offline   Reply With Quote
Old 04-09-2013, 04:59 PM   #2
spafxer
spafxer's Avatar
Oddometer: 2,635
30 amp main fuse down next to the battery.
Teach the kid how to install a battery safely too. He could have been really hurt
spafxer is offline   Reply With Quote
Old 04-09-2013, 06:09 PM   #3
graniterover OP
Oddometer: 37
Thank you for the quick reply.
Both 30 amp fuses looked good. To be certain, I went to the store and bought a box, installed two new ones, and.... nothing.
Going to go poke around the starter relay with a test light.
Old 04-09-2013, 06:25 PM   #4
graniterover OP
Oddometer: 37
Wouldn't the power have to go through the ignition regardless of the power to the starter relay switch?
I mean, the schematic shows a line from the battery to the ignition switch.
I bet I blew that. I don't see a fuse before the power gets to it, only a 10 amp after.
Old 04-09-2013, 07:58 PM   #5
spafxer
spafxer's Avatar
Oddometer: 2,635
With a voltmeter it is easy to follow the 12 volts from the battery through the 30 amp fuse up to the steering head area. There is a copper piece that goes bad between the battery cable bolt and 30 amp fuse holder. (the second 30 amp fuse is a spare)
What I'm not sure of is, if the kid was shorting out the battery at the battery there is no fuse protection there.
The key switch has been known to go bad, but the ass u mption is this is related to the battery install, right?
Old 04-09-2013, 08:48 PM   #6
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,113
Originally Posted by graniterover View Post
2006 950 Adventure
Mark
Is the battery still good according to your test light? If so, I would suspect a terminal or a cable immediately around the battery, current shouldn't have traveled through many other places if the key was off at the time.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 04-09-2013, 10:59 PM   #7
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
if the battery was momentarily shorted + to frame (-) at the battery the fuses will be just fine. I would go through all of the termination points of the major cables. A volt meter will help with the diagnosis, otherwise you will be doing a lot of chasing your tail.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 04-10-2013, 05:50 AM   #8
graniterover OP
Oddometer: 37
Working from home today. Bike is 20 feet away. I'm sure no one will notice as I fix it!
Old 04-10-2013, 10:29 AM   #9
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 524
Curious here... For future reference, what did you find and what did you do to fix it.
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 04-10-2013, 10:33 AM   #10
graniterover OP
Oddometer: 37
Had to go in to work. Got as far as pulling the bike out of the garage.
Old 04-13-2013, 08:28 PM   #11
graniterover OP
Oddometer: 37
Thank you everyone for helping me. Finally got a few minutes to address this.
The previous owner had put an aux fuse box on the bike. It was so well done that I did not realize the MAIN stock + wire was not connected, but was in fact shoved behind the battery by my clever helper. I saw the aux wire and mistakenly thought it was the main stock wire.
Full disclosure: my friend Steve found the problem.
I think I'll take the whole bike apart soon so I know what goes where when future things crop up.
Old 04-13-2013, 08:32 PM   #12
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 2,896
Yep. I've done that before.
Orangecicle is offline   Reply With Quote
Times are GMT -7.   It's 01:15 AM.
