Old 04-09-2013, 05:41 AM   #226
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 344
My 73 two-shoe drum Eldo doesn't have that additional part. There's just the fork-top nut (plug in the parts book 1250-4500) that threads into the fork tube.
Life's too short.
F_Sahms is offline   Reply With Quote
Old 04-11-2013, 01:44 AM   #227
England-Kev OP
Oddometer: 3,574
My old guzzi does not have what you would call a proper oil filter, just a gauze in the sump. so I am thinking of adding two diesel inline fuel filters to the head feed pipes. one on each side to keep the oil pressure the same to both heads.
Now normaly according to my research filters are usualy fitted on a return line to the oil tank, but as the Guzzi doesn't have an oil tank, I therefore have no return line, so would fitting in a feed line cause problems, or is the return line thing just to stop debris reaching the oil tank as I suspect.
This is what I am thinking of fitting...
http://www.ebay.co.uk/itm/PETROL-DIE...ht_1415wt_1075
What do you all think?
England-Kev is offline   Reply With Quote
Old 04-11-2013, 06:20 AM   #228
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,899
Hey Kev this issue has been round and round and most of the guys riding theses bikes any distance would tell you that the factory setup with no filter is ok as long as you keep the oil changed often and clean the sump.
As far as adding filters they should be on the output or pressure side of the oil pump, but if you were to add externally then I would be concerned about extra places that could leak high pressure oil and if not caught quickly could mean big trouble for your new engine...just my $.02
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Old 04-11-2013, 08:18 AM   #229
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 344
I wouldn't, but it's your bike. Where the loops need an oil filter is in the feeds to the mains and rod bearings, not the little amount of oil that lubes the rockers.
You can convert the old blocks to add a filter, but it's a lot of machine work.
Drop the sump, clean the screen and pressure relief valve, and thereafter just change the oil often. These things go a long way without a real oil filter.
Life's too short.
Old 04-11-2013, 11:20 AM   #230
nick949eldo
Oddometer: 955
Are you going to put a couple of hundred thousand miles on that bike? If so, it might be worth it - but probably not. I wouldn't bother.
The PO had put an external filter on my Eldo. On one trip I limped back from the Gaspe Bay with oil pissing out of the connectors. Its just one more potential source of leaks and road damage. My other roundfins are just fine without!
Nick
nick949eldo is offline   Reply With Quote
Old 04-11-2013, 11:40 AM   #231
England-Kev OP
Oddometer: 3,574
just asking questions my friends, we don't learn if we don't ask....
Old 04-11-2013, 11:51 AM   #232
nick949eldo
Oddometer: 955
Kev,
I hope that didn't come across as snotty - if it did, it certainly wasn't intended. I asked a similar question over on Wildguzzi early in my Guzzi life.
Nick
Old 04-11-2013, 12:04 PM   #233
England-Kev OP
Oddometer: 3,574
not at all Nick, no worries mate just thinking out loud really, as I wait to get time at the lock-up
Old 04-14-2013, 02:58 PM   #234
England-Kev OP
Oddometer: 3,574
Hey Nick, that 750S rocks man, I see one of those in my future
Old 04-21-2013, 09:18 AM   #235
England-Kev OP
Oddometer: 3,574
Just a short bimble on my Guzzi...
Just to warm it up so I could change the oils, and find the stripped threads left by a previous owner, that now need sorting out. Luckily they were only on a level screw, and not a drain plug.
I now have a new oil leak, after curing all the others, this time from the distributer, I guess there is an oil seal or o-ring at the base where it goes into the block.
Old 04-21-2013, 10:23 AM   #236
davebeef
Buffoon
davebeef's Avatar
Oddometer: 250
There is only so many places that oil can leak from Kev and you're fairly workin your way through them. Every one cured mate is a winner. Wish I could get started on the Ambo but must get the rest of the fleet ship shape first. Out on this years maiden voyage on the B33 today. God I love big British singles!
DB
'70 Moto Guzzi Ambassador
'81 BMW R100
'81 MZ 250/1
davebeef is offline   Reply With Quote
Old 04-21-2013, 04:37 PM   #237
eldomike
Who Cares
eldomike's Avatar
Oddometer: 926
Takes a gasket.....Can't believe you are fretting over a few oil leaks on the Guzzi....you ride Brit bikes also don't you
Photobucket http://tinyurl.com/oebr5yk
eldomike is online now   Reply With Quote
Old 04-22-2013, 10:01 AM   #238
England-Kev OP
Oddometer: 3,574
I am calling this bike the Exxon Valdez, it is embarasing, I have greenpeace following me everywhere I go
Old 05-11-2013, 08:48 AM   #239
England-Kev OP
Oddometer: 3,574
At last work and life have eased off a little, and I was able to drag the Guzzi from the lock-up, and take it for it's annual MoT (Ministry of Transport) road worthiness test. and it passed without any advisories. Way to go little guzzi.
Old 05-12-2013, 06:07 AM   #240
England-Kev OP
Oddometer: 3,574
Do any of you know the "New" length of fork springs ?
I have finally managed to get my fork legs out, all I need to do now is make a tool to undo the seal holders? if any of you hve such a tool, could you post a picture or two with measurements please.
Times are GMT -7.   It's 05:54 PM.
