Old 04-11-2013, 08:18 PM   #46
AlsoRan
Lone Trail Of Dust
AlsoRan's Avatar
Oddometer: 401
There are many to decide on but my top three "urgent" items would be:
1. AF-1 Re-flash
2. Skid plate to protect the oil filter - I went with SW Motech but there are several good ones.
3. Tires - ended up with K60's
Also, not urgent but someone suggested the Yamaha blinkers. If you don't like the originals these are an excellent replacement. Fits to bike with no hassles. Just make sure to buy a relay as well.
2012 Yamaha Super Ténéré
AlsoRan is offline   Reply With Quote
Old 04-11-2013, 08:25 PM   #47
CottonTop OP
Rider
CottonTop's Avatar
Oddometer: 60
Originally Posted by pluric View Post
I scrapped the OEM plate for an Altrider plate, engine guards and rack. Good quality stuff.
Still bent the bash plate up, just didn't have to worry about the sump mount of the OEM.
And pluric makes 3 - done! Altrider Skid Plate it is...
Super Tenere
CottonTop is offline   Reply With Quote
Old 04-11-2013, 08:27 PM   #48
CottonTop OP
Rider
CottonTop's Avatar
Oddometer: 60
1. AF-1 Re-flash
Wow, the AF-1 Re-flash makes that big a difference? $500 bucks time you pay shipping and ins., must be worth it.
Super Tenere
Old 04-11-2013, 08:40 PM   #49
AlsoRan
Lone Trail Of Dust
AlsoRan's Avatar
Oddometer: 401
It was worth it and I know that I waited too long to get it done. It really smoothed the bikes power through the full range. Made "T" mode more usable especially. For me it has been the best mod so far.
Old 04-11-2013, 09:04 PM   #50
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,567
Crash bars are on my list. My friend RoyQ recommended the GIVIs. Says you can still get the side panels off if needed. I have had good results with GIVI gear in the past so I will likely give them a try.
Thanks for the input guys. Keep it coming.
Oh Lord! There's your first problem. Hiya Roy
This
Later,
Michael
"If I can't pass at a reasonable speed I do it unreasonably." - jdmetzger
Anticyclone is online now   Reply With Quote
Old 04-11-2013, 09:47 PM   #51
techgeek
Oddometer: 148
have you tried the clutch mod?
Have you tried the clutch switch mod yet? It can be done and removed in a flash, and is nearly free. Many have reported it's a better return on investment than the ECU reflash.
For my S10, I also added heated grips, skid plate, bags, crash bars, lights and an air horn.
If I had to pick only 3 of the above.. I'd pick grips, bags, and the horn first.
I might choose differently if I rode more often on rugged terrain than in cold weather.
So far I'm really liking the bike. Going back and forth to it from my R1200GSA causes a lot of confusing emotions, but I love 'em both!
techgeek is offline   Reply With Quote
Old 04-11-2013, 10:23 PM   #52
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,794
I would do it again in a heartbeat. Seems like the one common complaint on the Tenere
is the fueling. The reflash completely solves that. The clutch mod frees up the lower
three gear restriction and helps on the off idle hiccup. It's the KLR approach to the real
problem of an EPA pleasing fuel map.
The reflash solves all fueling issues.
pluric is offline   Reply With Quote
Old 04-12-2013, 08:28 AM   #53
RocketJohn
Hook em' Horns!
RocketJohn's Avatar
Oddometer: 11,330
Finished my heated grip install last night... did my Yamaha LED turn signals while I was there... 9pm-2am taking my time, but it all worked no issue. The Yamaha heated grip kit is very well thought out, in my honest opinion.
RocketJohn is offline   Reply With Quote
Old 04-12-2013, 07:36 PM   #54
CottonTop OP
Rider
CottonTop's Avatar
Oddometer: 60
The stock T mode seems very anemic; like I coked the bike twice on take off... I never coked my Strom once in 5 years. In S the issue is gone. I wonder what Yamaha's intended use of T was??? Anyway the AF-1 Mod is on my list now.
Super Tenere
Old 04-12-2013, 07:40 PM   #55
CottonTop OP
Rider
CottonTop's Avatar
Oddometer: 60
This
I followed that crazy son of a gun around north GA one spring on a 3 day trip. White lines, yellow lines, signs of any type do not apply to my man RoyQ. If you are going to ride with Roy make sure you have a clean change of underwear with you - you may need them... Hi Roy
Super Tenere
Old 04-13-2013, 06:39 PM   #56
CottonTop OP
Rider
CottonTop's Avatar
Oddometer: 60
The first upgrade item arrived today. GIVI 22" touring screen. Props to Competition Accessories for the quick service. Ordered on 4-9-13, arrived today, and free shipping. Now to get it installed.
Super Tenere
Old 04-13-2013, 07:47 PM   #57
CottonTop OP
Rider
CottonTop's Avatar
Oddometer: 60
The new GIVI screen is on - test ride in the morning.
And a holdover from the Strom. My Alaska Leather sheepskin; don't leave home without it.
Super Tenere
Old 04-17-2013, 06:47 AM   #58
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,836
Clutch switch mod / fuse, #1
Everything else is personal preference.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 04-18-2013, 05:58 AM   #59
bmac
Oddometer: 328
1) Madstad windscreen adjustment bracket with Powerbronze shield. Also have the winglets
2) Corbin seat: best mod by far
3) Yamaha Heated Grips
Luggage of some sort. There are a lot of choices.
bmac is offline   Reply With Quote
Old 04-19-2013, 03:01 AM   #60
Kenbike
Oddometer: 692
My picks
1. Complete Arrow exhaust
2. Power Commander V with Dyno tune
3. Windshield replacement and adjustable bracket
And lots of money for gas and tires
Current Bikes: 2014 BMW GSA, 2010 Vespa 300 Super scooter ( hers), 2012 Vespa 300 Super (his)
Kenbike is offline   Reply With Quote
Times are GMT -7.   It's 08:22 PM.
