Old 04-12-2013, 08:25 AM   #13036
robmoto
robmoto's Avatar
Oddometer: 3,854
Originally Posted by DRjoe View Post
Best thing ever said in this thread
Glad to help .
robmoto is offline   Reply With Quote
Old 04-12-2013, 09:20 AM   #13037
motolab
motolab's Avatar
Oddometer: 2,622
Originally Posted by gavo View Post
So DR with just bottom of snorkel removed, FMF muffler, Standard carby, needle raised one notch and extra hole in slide (which I may refill) runs well, economy not as good as friends but I need a new needle as mine is wearing at the top.
Worn needle and economy not good point to a worn slide guide, emulsion tube, and perhaps slide.
Go standard new one or does someone have a better one in mind?
Use 6F19.
Regards,
Derek
motolab is offline   Reply With Quote
Old 04-12-2013, 03:39 PM   #13038
duckslider
duckslider's Avatar
Oddometer: 3,191
I put a Yoshimura sticker on my standard pipe.
it's a bit louder now.
duckslider is offline   Reply With Quote
Old 04-12-2013, 04:21 PM   #13039
felixblack1
felixblack1's Avatar
Oddometer: 191
the only performance mod I found that helped with getting from A to B faster was buying it a 990. Worked wonders!
felixblack1 is offline   Reply With Quote
Old 04-12-2013, 06:03 PM   #13040
Tyrepower
Tyrepower's Avatar
Oddometer: 144
I put a Red "Type R" sticker one on mine. Got at least 15 extra HP, at the rear wheel I might add!!And tons of street cred from the pimple faced kids at the milk bar when I thump on by with my Ipod turned up full loud with the bass on max. Fully sick Bro!!!!
My biggest fear is when I die, my wife will sell all my bikes for what I "told her" they cost!!!
It's all good fun until someone gets hurt......... then it's hilarious!!!
Tyrepower is offline   Reply With Quote
Old 04-12-2013, 07:16 PM   #13041
ER70S-2
ER70S-2's Avatar
Oddometer: 6,461
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 04-13-2013, 02:11 AM   #13042
CCCC
Oddometer: 290
Fuel usage
Hi Guys
Got myself a 30L safari tank. Looking for distances you guys can get out of 30L of juice.
The trip I'm planning will have the below type of riding.
- black top at speeds around 100kph
- open dirt roads 60-80kph
Will be doing about 5500km over two weeks. Some of the legs have about 400-450k. Between fuel stops.
Any info will be appreciated
CCCC is offline   Reply With Quote
Old 04-13-2013, 03:39 AM   #13043
Sleepy John
Grumpy Adventurer
Sleepy John's Avatar
Oddometer: 3,730
Originally Posted by CCCC View Post
Hi Guys
Which way is the fuel inlet on the carb pointing? up as original or has it been turned onto its side?
Sleepy John
'10 R1200GSA Big Pig, '10 DR650SE Piglet
Don't shoot... It's only me!
Women and cats will do as they please, and men and dogs should relax and get used to the idea.
Sleepy John is offline   Reply With Quote
Old 04-13-2013, 03:57 AM   #13044
Thumper Dan
Oddometer: 325
Hi Guys
I can comforably get 700km and i'm then thinking about filling up. I've ran it and get about 720 to 730 reserve, but I've only done reserve a couple of times. I've never actually ran it dry, so not sure a total amount of km's. Basically, if I'm in the 600km's on the trip meter, i know my distance is a 100km or so and depending where I am, will watch the various petrol stations pass by, but push it until I'm home anyway.
I run a TM40 carb and standard exhaust. I believe I can run the tank dry, but as the previous poster said, if you have the standard carb, you need to get the fuel lines worked out so you don't get air in them, otherwise you'll have a few/several litres left in the tank.
Hope this helps.
PS: practice taking the tank on and off, as its a pain to get back on. Best when tank is empty but for me, a marathon when full.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 04-13-2013, 04:03 AM   #13045
gavo
Slacker
gavo's Avatar
Oddometer: 1,825
Hi Guys
700ks is bloody good most people I know get under 600 and I've gone on reserve at 520 but at those speeds 550 to 600 would be a safe figure to work on plus the seat will make you stop before that
gavo is offline   Reply With Quote
Old 04-13-2013, 04:09 AM   #13046
Sleepy John
Grumpy Adventurer
Oddometer: 3,730
PS: practice taking the tank on and off, as its a pain to get back on. Best when empty and seems a bit easier.
Milage sounds about right.
I have found that one of those cheap ratchet tiedowns from Supacreep threaded through the front forks and back around the tank can be a big help in positioning the tank to line up the rear bolt holes if you are doing it by yourself. It's easy to cross thread the bolts if you are mucking around trying to push the tank into position and get the bolts started. If the tank won't go on, check that the oil cooler protector hasn't been pushed backwards if you have come off at some stage. It too me a while to figure that one out.
If you find yourself running out of fuel with plenty still in the tank, put a good breath of air into the fuel cap breather tube. This will get you another 10 or 15 k's closer to the servo and you can do it over and over again if you need to. I also do this if the bike has been sitting for a while and is playing hard to strart. Works a treat.
Sleepy John
Old 04-13-2013, 04:20 AM   #13047
CCCC
Oddometer: 290
Still up, gotta say I'm slight scared to try and turn it. I'm likely to break it......
Old 04-13-2013, 04:33 AM   #13048
Thumper Dan
Oddometer: 325
I've read adding heat to it will assist before committing.
Another thing about the Safari, you probably find that you have more than 30 litres. Mine is 34 litreish, but they are commonly known to expand as they age, so this adds distance also.
Old 04-13-2013, 05:08 AM   #13049
Sleepy John
Grumpy Adventurer
Oddometer: 3,730
Mine crimped just a bit. I used a large adjustable spanner and a bit of rag as padding and a quick prayer to the god of speed.
Sleepy John
Old 04-13-2013, 05:12 AM   #13050
Sleepy John
Grumpy Adventurer
Oddometer: 3,730
Just in case you are thinking of updating.
It’s Sweet Season Bonus time from Suzuki motorcycles and dealers around the country have embraced the raft of offers available across the motorcycle and ATV range for the remainder of the financial year.
Suzuki is also catering for its extended family of trail and enduro riders, offering even more bang for their buck with a generous $500* Factory Bonus on Suzuki’s most popular street-legal trail bike, the DR650SE.
Sleepy John
Times are GMT -7.   It's 03:30 PM.
