Old 04-11-2013, 10:17 PM   #1
Two Moto Kiwis OP
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,805
External Shock Preload Adjuster For 950 SE
Good afternoon gents
Looking to get something like this for our SE, our preload for two up with house and contents is fine but when I am single with no house and contents the spring preload is too much.
This is all I can find but it does not make mention of the bigger bikes.
Any input from someone who has done this or something similar or does Ohlins or others make something that will fit.
http://www.slavensracing.com/shop/sh...wpktm-by-xtrig
Cheers all.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 04-11-2013, 10:52 PM   #2
mousitsas
mousitsas's Avatar
Oddometer: 2,749
It is a 2 minute job to change the preload, loose the allen bolt, grab spring turn spring, finish.
But yes, it would be nice to have one. The powerparts catalogue has a preload contraption you can fit to the SM, but the shock bodies have different diam. and so it does not fit the SE.
Old 04-11-2013, 11:06 PM   #3
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 3,805
We have our "extra" subframe for the luggage which make that whole grab and turn a little (lot) harder.
We have the SM shock in our SE to lower it for me so we might be in luck, thanks for pointing it out
Old 04-11-2013, 11:48 PM   #4
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 3,805
Thanks mousitsas
Ok, found this one
http://www.ktmtwins.com/ktm-990-adjuster
Do any of you suspension wizards know if this will fit the 950 SM as that is the shock we have in the SE.
Many thanks Andi
Old 04-12-2013, 06:30 AM   #5
mookymoo
Mookish Mook
Oddometer: 4,391
I'd be a bit wary about this kind of add-on - it could ruin the threads on your shock.
Basically, the thread isnt going to be 100% tight like with the OEM with the lock-bolt.
Therefore theres a risk of any minute movement (with a bit of grit in the thread as a grinding paste) will slowly eat away the thread over time....
As above, taking the weight off the shock, loosening the look bolt and turning the spring by hand (the spring binds with the adjustment ring - thus turning the ring) is pretty quick and easy
mookymoo is offline   Reply With Quote
Old 04-12-2013, 07:22 AM   #6
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,128
Theres hydraulic preload adjusters from WP, and a company in Holland is making them aftermarket for all sort of bikes now. perhaps you can get something like that local? than its a 10 second job.
I never use it though, would just as easily get rid of the one on my 950 shock if i could.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 04-12-2013, 10:07 AM   #7
renogeorge
Oddometer: 1,365
When I looked into the KTM Hardparts adjuster, it did not fit the SM shock.
FWIW
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 04-12-2013, 12:35 PM   #8
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 3,805
FWIW
Cool at least I know I can eliminate that then, will look into the hydraulic adjusters.
I liked on old Ohlins setup that sat between the collar and the spring and the unit did all the work not the shock body threads
Old 04-12-2013, 02:29 PM   #9
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 3,805
This looks like a good option but I can't find anywhere abut fitment.
http://www.wpsuspension.be/EN/road.html
or
http://www.moto-racing.co.uk/item--W...eload+Adj.html
Anyone used these before?
Will email KTM shop and see what they say too.
Old 04-12-2013, 10:26 PM   #10
D K
Oddometer: 466
The company in Holland is Hyperpro and the guy you need to talk to is Bas.
They make some of the best suspension stuff out there and pricing is very reasonable.
Plus the guys are all bike fanatics and KNOW what they're talking about.
My $.02
D
'13 EC300 Racing
’07 950SE - sold
’08 950SE - sold
’09 FE570 - sold
D K is offline   Reply With Quote
Old 04-13-2013, 10:21 AM   #11
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,128
I did not know hyperpro had it as well but yeah, that's a great company.
Can't think of the one I meanth before but they make the whole line of touratech shocks as well. It's a new supplyer in the suspension business, very active in electronic suspension.
Old 04-13-2013, 11:01 AM   #12
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 3,805
Have contacted Hyperpro to see what they say, let ya know what happens.
Times are GMT -7.   It's 10:50 PM.
