Old 04-13-2013, 06:24 AM   #13051
Drozit
Drozit's Avatar
Oddometer: 71
I have done it on two dr's with a long nose multi grips with a rug and obviously tank off.
You will be ok .
I do comfortable 550 km even on sand , never heard of any one doing 720 ..good on you
It must be the different carburettor .
Drozit is offline   Reply With Quote
Old 04-13-2013, 06:59 AM   #13052
Sleepy John
Grumpy Adventurer
Sleepy John's Avatar
Oddometer: 3,731
You will be ok .
Just did the sums. Broken Hill to Cobar with a side trip out to White Cliffs and back, 651 k's. This was the leg where we learnt the trick of blowing into the breather tube. My boy thought $1.73 a litre was too pricy in Wilcanna.
110 kph posted speed. We may have been a few kph above this. The screen fitted to the DR makes quite a difference with fuel economy if you are travelling at speed.
SJ
Sleepy John
'10 R1200GSA Big Pig, '10 DR650SE Piglet
Don't shoot... It's only me!
Women and cats will do as they please, and men and dogs should relax and get used to the idea.
Sleepy John is offline   Reply With Quote
Old 04-13-2013, 07:15 AM   #13053
gavo
Slacker
gavo's Avatar
Oddometer: 1,796
SJ
Thats good milage if your speedo said 110kph it was closer to 100
gavo is offline   Reply With Quote
Old 04-13-2013, 03:17 PM   #13054
Benz-in-Oz
Benz-in-Oz's Avatar
Oddometer: 187
Originally Posted by CCCC View Post
Still up, gotta say I'm slight scared to try and turn it. I'm likely to break it......
Just did mine last week, I sprayed on "Chemsearch Yield" where the inlet comes out of the carby every time I though of it for about a week before, in the end it went quite easily, if that hadn't worked I was going to try holding a soldering iron against it and hopefully swell the alloy a bit. As others have said the tank is a mongrel to get back on, mine took 35.1 litres to fill from dead empty.
Benz-in-Oz is offline   Reply With Quote
Old 04-13-2013, 03:47 PM   #13055
felixblack1
felixblack1's Avatar
Oddometer: 186
DR650 Fuel inlet turning
http://www.youtube.com/watch?v=7CyCTiB83-I
felixblack1 screwed with this post 04-13-2013 at 03:58 PM
felixblack1 is offline   Reply With Quote
Old 04-13-2013, 04:38 PM   #13056
BergDonk
BergDonk's Avatar
Oddometer: 3,375
Fuel consumption is a can of worms depending on setup. With my previous jetting and FCR, and up to 37 l in the Safari, up to 700 kms and over 600 kms no worries all the time except heavy sand. With the NCVT needle and jets to suit, indications are perhaps another 100 kms, or more, but to be confirmed.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 04-13-2013, 06:10 PM   #13057
Tasmag
Oddometer: 15
Not sure where I read it but I used vice grips on the rim of the inlet (sits hard up against the carb body) and had no trouble. Means that you cant crimp the inlet if it wont spin.
Mike
Tasmag is offline   Reply With Quote
Old 04-13-2013, 09:29 PM   #13058
Sleepy John
Grumpy Adventurer
Oddometer: 3,731
The road sign said 110. In outback NSW the speedo on the German mothership was reading 130-140 matching the GPS. The bloody DR was close behind whenever I stopped. The Deathwings were well past their use-by date when we got back home.
i know what you mean Gavo. It's for our own safety that Japanese speedos ( cars and bikes ) are 10% optimistic. The Europeans can build then so they're dead accurate. I guess that's where all those out of work Swiss watchmakers found new careers.
Sleepy John
Old 04-18-2013, 06:14 AM   #13059
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,460
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 04-20-2013, 04:15 AM   #13060
Starky14
Yowie Bait
Starky14's Avatar
Oddometer: 242
DR650 2012 gear box
Just an question. I heard a strange noise in first gear, on the last ride, but it could have been low static on the radio. That got me thinking, has anyone had issues with the 2012 model and the 3rd gear problem?
Am I also right in thinking the netual thingy has also been fixed in the the 2012 model?
I would be unstoppable if not for Law Enforcement and Physics!
Starky14 is offline   Reply With Quote
Old 04-20-2013, 04:24 AM   #13061
Andy_P
Oddometer: 448
When I replaced the clutch in my 2012 model, the NSU screws were gone and in their place was some hex head bolts
Not sure about the 3rd gear issue. I have only done 6000km on my dr, and I have had no issues other than burning out the clutch doing stupid hill climbs.
“The purpose of education is not to validate ignorance but to overcome it”
― Lawrence M. Krauss
Andy_P is offline   Reply With Quote
Old 04-20-2013, 04:35 AM   #13062
robmoto
robmoto's Avatar
Oddometer: 3,835
If it was a doof doof sound just change stations and she will run smooth again .
I ride alone and not a KTM in sight .
Menace Racing supported by Robmoto Industries
robmoto is offline   Reply With Quote
Old 04-20-2013, 05:46 AM   #13063
Andy_P
Oddometer: 448
I decided to get stuck into the DR today after my crash. I put some protaper bars on it to replace the bent factory bars. Do you guys drill the aftermarket bars for the switch block locating pins, or just cut of the locating pins on the switch block?
Old 04-20-2013, 06:20 AM   #13064
usi
Complete kook
usi's Avatar
Oddometer: 53
I used an angle grinder on the locating pins, A dremel would have been more suitable
usi is online now   Reply With Quote
Old 04-20-2013, 06:36 AM   #13065
Andy_P
Oddometer: 448
Lucky I have a dremel!! The problem I have now is I cant ride (thanks to the stack), so not sure on the best bar position. I am loathed to drill the bars, just in case I dont like where they sit.
Do the switch blocks stay where they should be when you hacked the locating pins off?
Times are GMT -7.   It's 09:33 PM.
