Old 04-15-2013, 10:13 PM   #166
mint julep
mint julep's Avatar
Oddometer: 185
Hey guys, just wondering for those installed.
I'm awaiting my unit to arrive and going over the installation process.
Over on the instruction pics on page 3, slide #4 and #8 show a hole.
Do I need a dremel to cut away at parts of the plastic?
I don't have a dremel, so would a drill bit work?
Haven't taken off the light to have a look at what I'm dealing with yet.
Thanks in advance.
Dave
mint julep is offline   Reply With Quote
Old 04-15-2013, 10:19 PM   #167
pilot3 OP
Oddometer: 402
Thanks in advance.
Dave
Dave,
I used a dremel tool but there were a few guys who just used a small file. It's not a hole you're making but a small notch. When you see the wire, it should make sense.
Anyone else with some other ideas they used?
p3
pilot3 is offline   Reply With Quote
Old 04-15-2013, 11:15 PM   #168
ttime4four
ttime4four's Avatar
Oddometer: 240
Originally Posted by pilot3 View Post
Dave,
p3
I've got a Dremel (actually an air powered tool similar to a Dremel) -- but I chose to use a small file as to have a little more fine control.
A rotary tool with a rasp bit would work, but it can get away from you. I've made previous attempts at shaping plastic and, if you are not careful, the bit can bite and jump on you.
You are trying to make a notch about a 1/4-3/8" wide and a little over 1/8" deep to accomodate the lead going to the light. The lead coming out of the center of the light housing and your notch will be in the center of the top of the light opening.
'14 KTM 690 Enduro R
'06 Husaberg FE450e (Oregon Plated)
ttime4four is offline   Reply With Quote
Old 04-16-2013, 04:36 PM   #169
mint julep
mint julep's Avatar
Oddometer: 185
Ok thanks for the info guys.
So, I just need to make a groove to make way for the cable pass or sit when unit in place.
I have a file, so when I take brake light off, I'll see what needs to be done.
Looking forward to this. ;)
Cheers,
Dave
Old 04-19-2013, 08:56 PM   #170
mint julep
mint julep's Avatar
Oddometer: 185
Kudos and thanks to P3.
I just installed my tail light and it was easy peasy!
The great install instructions helped along the way.
Great kit. Light is bright, easy plug and play.
Filing the arch for wire to sit snug was easy, but I don't think I filed enough and had a gap which I then ran a bead of silicone due to my OCD.
I also dropped the light mount screw into the bottom well. PITA to retrieve, so be careful.
Very impressed and stoked to have it installed.
Cheers,
Dave
Old 05-05-2013, 06:25 PM   #171
elifino
RDWHAHB
elifino's Avatar
Oddometer: 23
Current Group Buy??
If there is a current Group Buy going I would be interested.
Doug
'12 Tiger 800XC
'08 WR250R
elifino is offline   Reply With Quote
Old 05-12-2013, 11:52 PM   #172
pilot3 OP
Oddometer: 402
New group starting
Hey everyone,
Life settling down a bit so I am ready to start another batch. Between the thread and PM's, here is who I have interest from:
grawrimo
bikergirl4ever
Powerranger
OregonTIger
kylerichards
RedST
elifino
Grover6
I'll PM everyone and will plan on closing this on the 20th so I can order parts then. Anyone else interested can PM too.
p3
pilot3 screwed with this post 05-13-2013 at 07:10 PM Reason: added inmate
Old 05-18-2013, 09:47 AM   #173
pilot3 OP
Oddometer: 402
Ok, for the next order I've confirmed:
OregonTiger
Grover6
Poweranger
These inmates I've still not heard from other than indicating they want a light:
grawrimo
kylerichards
RedST
elifino
Check PMs please.
p3
Just updated. Thanks PowerRanger!
pilot3 screwed with this post 05-18-2013 at 09:57 AM
Old 05-18-2013, 10:05 AM   #174
Poweranger
Oddometer: 730
Thanks for making these!
Poweranger is offline   Reply With Quote
Old 05-21-2013, 06:53 PM   #175
pilot3 OP
Oddometer: 402
Confirmed inmates
OK the order went in. Confirmed buyers are:
Poweranger
OregonTiger
Grover6
It usually takes 2 weeks for me to get all the parts, get them assembled and shipped back out. I'll keep it updated.
p3
Old 05-22-2013, 07:06 PM   #176
Grover6
Oddometer: 181
Thanks pilot3!
Grover6 is offline   Reply With Quote
Old 05-23-2013, 05:53 AM   #177
Meteos
Meteos's Avatar
Oddometer: 69
Question too late?
Poweranger
OregonTiger
Grover6
p3
I just found this thread last night. Is it too late for me to place an order?
Thank you!
Meteos is offline   Reply With Quote
Old 05-24-2013, 12:10 AM   #178
pilot3 OP
Oddometer: 402
Thank you!
I'll PM you tomorrow.
Old 05-24-2013, 05:25 PM   #179
Vzuke
Vzuke's Avatar
Oddometer: 145
Pilot3, HELP!
I'm working on a project bike for the wife. I turned a Honda CRF250L into a Supermoto.
I ordered a nice fender eliminator kit from Yoshimura but the LED tail light did not do it for me. Yes, it looks great at night even on an over cast day but in bright sun light it doesn't have enough fire power.
I was going to try and put a RADIANTZ cluster inside the tail light like I did with my Suzuki DRZ Edge2 light but I couldn't find any that would fit inside. The other problem with the Yoshi light is the lens is glued on. So taking it apart without destroying it could be a problem.
What I was wondering is if you have a selection of housings to choose from? If not that's cool, I will just get the same one you made for the Triumph.
My plan is to order a Radiantz black license plate frame that has LED across the top for tag illumination then mount one of your lights in place of the Yoshi light.
Next I'll have to try and find some good LED turn signals. The ones I purchased had the same problem as the tail light, need more POWER!
Thanks in advance.
-Dana
Vzuke is offline   Reply With Quote
Old 05-25-2013, 04:23 PM   #180
pilot3 OP
Oddometer: 402
Latest UPDATE
OK the first half of the order included the following paid buyers:
Poweranger
OregonTiger
Grover6
I was told lead time on the light heads was 2-2.5 weeks, so I hope to have these shipping out on Monday 6/10.
I PM'd the following inmates with their requested info:
cr9101
meteos (PAID)
Vzuke
If everyone is paid, I will get this half ordered on 5/28 and hope to be shipping that group on Monday 6/17.
p3
pilot3 screwed with this post 05-26-2013 at 12:17 PM Reason: status change
Times are GMT -7.   It's 01:37 AM.
