Old 04-17-2013, 02:48 PM   #75871
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Originally Posted by TRAVELGUY View Post
The stock spacers weigh about 5 pounds each. ????
I haven't weighed my stock spacers but have had them in my hands several times and they don't come close to 5 lbs. Mine are steel pipe are yours solid lead billet?
I may have exaggerated it a little. It's probably no more than 4. :)
Suffice it to say they're far heavier than necessary.
Old 04-17-2013, 02:54 PM   #75872
ER70S-2
ER70S-2's Avatar
Oddometer: 6,288
oops, 205'd
A tiny exaggeration for effect. I doubt they weigh any more than 4.5 pounds each.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 04-17-2013, 03:27 PM   #75873
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,148
Originally Posted by procycle View Post
Actually, the stock springs are progressively wound. The initial spring rate is .38 kg/mm and the final rate is (I think) .44 kg/mm. The spring transitions out of the soft rate at about 7.5" of compression.
That's what I get for going from memory.
the amount of preload that you will be able to get into the fork probably won't help with the dive problem enough.
Fork springs are fairly reasonably priced for "value received" (bang for the buck).
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 04-17-2013, 03:37 PM   #75874
sagebrushocean
Harris's hawker
sagebrushocean's Avatar
Oddometer: 180
Originally Posted by psmcd View Post
While you're talking forks, I'm finally installing my .47 springs and emulators.
The emulators came with the yellow springs and 4 turns preload. I'm 195lbs plus gear and hope to keep an initial plush/compliant ride while eliminating the wallowing and worse that occurs way too often.
Any thoughts?
I'm the same weight and have the same springs as you. I found 4 turns of preload on the emulators (10W fork oil) to be too harsh for my riding (exclusively street, and the bike is stripped down to 346 pounds wet). I'm at 3 turns now, and that is pretty good. If I ever go back into my forks I'd probably back off another 1/4 to 1/2 turn, so your estimate of 2.75 turns sounds about right to me. Offroad riders and those with heavy payloads may have a different view.
2008 DR650SE supermoto
2009 CRF230M
sagebrushocean is offline   Reply With Quote
Old 04-17-2013, 03:40 PM   #75875
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Rusty Rocket View Post
stock springs are .40 Kg/mm. (straight rate) That means that they compress the same whether or not you squeeze them with preload. You will raise your ride height, but the dive should be about the same.
Correction:
Stock DR650 springs are progressive wound springs.
Old 04-17-2013, 03:42 PM   #75876
Rusty Rocket
Life behind "Bars"
Oddometer: 9,148
Originally Posted by Adv Grifter View Post
Correction:
late to the party
2009 DR650
Old 04-17-2013, 06:33 PM   #75877
Minsk99
Oddometer: 56
I have mine at 2.5 turns and its great for street riding. I'm 190 without gear and have an Acerbis 5.3 tank. However, I am going to add 3/4 of a turn as it needs a little more preload for off roading IMO. I actually called Race Tech yesterday and asked them about it and they said that their recommended setting is 4 turns on the yellow spring and that is why they are shipping them that way. Mine also came with 4 turns when I got them a few weeks ago. I'm running .55 springs with them. Really like the set-up a lot.
Minsk99 is offline   Reply With Quote
Old 04-17-2013, 06:48 PM   #75878
mill
mill's Avatar
Oddometer: 47
I know I don't show my face around here much, but that's about to change. I live in Alabama and run around with a member here they call Swamp....
Anyways I have a 1997 DR 650 out in California at my brothers. I had him drop it off at the local shop to do some service work before my recent trip to Mexico on it last week. I do all of my own service work here in Alabama, but I have no choice. Big mistake...
So the bike left me stranded due to carburetor issues that should have been fixed by the shop, and I also noticed a broken pinch bolt on the front forks....how genuine of them. According to the parts fiche, this stud is not replaceable. Does anyone here know if that is true?
I left the bike in Mexico, and plan to go back and pick it up in July to continue towards Panama. I am making a list of parts that I need to have shipped to Mexico in order to prep for the next leg of the journey.
Oh, and here's a photo from the beginning of the 2600 mile trek that I completed in 7 days, haha!!!
mill screwed with this post 04-17-2013 at 07:04 PM
mill is offline   Reply With Quote
Old 04-17-2013, 07:04 PM   #75879
french horn
Just Add venture
Oddometer: 470
Originally Posted by FatChance View Post
When loaded, how much weight do you reckon the rear subframe is supporting with that setup?
Great question, I didn't think of the subframe.
I haven't weighed it but I figure less than 40Kg ... considering a pillion could be 80 or more, my system shouldn't be a problem.
I did however, mount the bags as forward as i could, reducing the strain on the S/F ..... I hope .
cheers
french horn is offline   Reply With Quote
Old 04-17-2013, 07:08 PM   #75880
refokus
Just Learning
refokus's Avatar
Oddometer: 2,432
I picked up a 650 here a few months ago that had a broken stud as well for the pinch bolt. Ace hardware had the #6 double threaded stud and it worked like a champ. I was lucky enough to have just enough of the broken stud sticking out that I got a pair of vise grips on and spun the old broken stud out. Good luck......
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 04-17-2013, 07:24 PM   #75881
french horn
Just Add venture
Oddometer: 470
Looks like you're set up for a nice long ride. Nice tidy set up.
Are those panniers waterproof?
As far as the canvas has a membrane sewn against it and the top (under the flap) has a drawstring .... I used them during my 20yrs service without any ingress ... just gotta keep it a tight package.
You hauling food and cooking pots?
I carry a gas burner and 2 cans of gas, MILL SPEC "pots" (2), eat'n irons, 2 water bottles and assorted food .... no worries.
If going off road at all I would add a pair of Bark Busters and a skid plate.
One light off could ruin your whole day. I agree completely, just gotta save more pennies ... or build some ... but it'll happen.
PS: the stock seat is a one to two hour seat at best. My Corbin is good for 10 hour riding days. You're not wrong there either mate ... I doubt I could mod my seat successfully so .... more saving.
All the best!
Thanks heaps.
Old 04-17-2013, 08:57 PM   #75882
Escaped
Escaped's Avatar
Oddometer: 473
Originally Posted by LexTalionis View Post
My immediate thought was this is a troll.
Lex
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
2006 DR650 54,407 miles
DR650 - Eyes open all of the time
Escaped is online now   Reply With Quote
Old 04-17-2013, 09:00 PM   #75883
psmcd
Oddometer: 954
more perhapsing
Thanks to both of you. Seems one of the Procycle guys was happy with 2.5, Guess we'll each be dialing in to a sweet spot. Anyone out there drill an additional low speed bleed hole to keep them plush with more preload? I wouldn't do this without riding it first with the heavier rear spring also. Just hoping for more competent but still compliant suspension.
psmcd is offline   Reply With Quote
Old 04-17-2013, 09:09 PM   #75884
mill
mill's Avatar
Oddometer: 47
Yep, I've got enough room to get on the broken stud with a pair of vice grips. I'll check Ace locally for the stud. Thanks for the tip. Btw, what year is your DR? I am curious to know if the fork design would happen to be the same. If I know the year, I could cross the entire fork leg on a parts fiche. Like I said, unfortunately the bike is not with me and is sitting in Mexico waiting for my return. I have no way of physically checking to make sure it will in fact thread out.
Old 04-17-2013, 10:13 PM   #75885
Adv Grifter
Oddometer: 6,128
Guys break those pinch bolt studs all the time. You can live with three of them no prob. Do not over torque them. If you work on your own bike in Alabama ... why would a "Carb" problem side line you? It's a simple device. Probably a clogged fuel filter or Pilot Jet or water or dirt in fuel. All doable side of road ... or by any decent Mexican mechanic. Never under estimate just HOW GOOD the Mexicans are with simple motors like the DR. They know their stuff.
I hope you left your bike with someone you trust ... and are paying? If not, ... Bit of a risky proposition, IMO.
Hopefully your bike is well prepped and set up to make Panama and back.
I would not ship parts to Mexico ... they'll get stuck in Customs and you may never get them out. Hand carry them in yourself ... and bring all receipts in case they ask for them. They are real sticklers on this sort of thing. Trust me. (I hide most parts and don't declare anything)
I hope your chain & sprockets are in good shape, hard to source there. Bring spare front sprocket, fork seals, rear brake pads, Carb jets (pilot and Main)tiny in line fuel filter, spare tubes and a rear tire if you need one. (expensive and hard to find good tires and tubes in Mexico)
!que le via muy bien!
Have a safe ride!
Times are GMT -7.   It's 12:26 PM.
