Old 04-18-2013, 09:30 AM   #16
NomadicOne
Oddometer: 30
Originally Posted by Reaver View Post
Ahh, you're in Tranna now. If you can wait Sask Battery has a good deal but if not then you'll know how much the battery should be. We'll be getting two of these.
http://saskbattery.com/ecommerce_180.htm
Thanks a lot bud, that price is nearly $40 cheaper vs. what EasPennCanada is offering so I will be patient and wait for shipping from Saskatchewan.
NomadicOne is offline   Reply With Quote
Old 04-18-2013, 05:55 PM   #17
TegRacer324 OP
Oddometer: 11
Okay so finally got back to it tonight.
Read the voltage at the battery. Reads 12.57 when sitting and 10.8 when cranking so I would say the battery is most likely not the problem.
Took the plug out of the fuel pump controller. Would get a momentary 12V when turning the key at the plug. Pulled the FPC out and read it at the plug to the pump. Only getting 2.3-2.5V when I turned the key.
I then used some jumpers to go directly to the pump from the battery. Could hear the fuel pump turn on when I did this.
Unfortunately I didn't have access to my friend's f800 tonight but I'm pretty sure at this point it's the FPC.
TegRacer324 is offline   Reply With Quote
Old 04-18-2013, 06:08 PM   #18
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,081
Thanks for the update. If you jumped the pump from the battery then start it! Assuming the connections are secure. It never hurts to have a spare FPC so it may be easier to just get a new one. The GF and I ride the Twins so I carry an extra one just in case.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 04-18-2013, 06:44 PM   #19
TegRacer324 OP
Oddometer: 11
Well I hooked my jumpers back up and after a few seconds and a little throttle it fired right up! Looks like I'll search around for an FPC tomorrow.
Old 04-18-2013, 06:53 PM   #20
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,081
Originally Posted by tah1800 View Post
I've seen cleaning the FPC bring one back to life too.
Yaknow, I just can't take you seriously with that avatar.
Times are GMT -7.   It's 06:22 AM.
