Old 04-18-2013, 05:28 AM   #1
jon_l OP
jon_l's Avatar
Oddometer: 3,303
tool found in car
This morning, I found a tool in my car that I can't identify. Fuzzy cell phone pic:
It is heavy on the nuts end, and steel as tested with a magnet. The only writing on it is "vanadium". End opposite the nuts is hollow, with machined recesses on the inside walls. It is 3-1/2" long x just over 3/4" dia.
I had tires installed last weekend, so am wondering if it may have been left in the car by a tech at the tire shop.
Any help identifying this?
Thank you.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 04-18-2013, 05:35 AM   #2
TopDeadCenter
TopDeadCenter's Avatar
Oddometer: 353
That would be a socket for anti theft lug nuts. Check the lug nuts and you may find a funny looking one on each wheel. This socket should match it.
I tend to get rid of the "theft proof" lug nuts. They can cause more problems than what they are worth. Besides, the determined wheel theif has the tools to cercumvent this.
The 80's GM sedans had this same type of tool for their hubcaps as well.
TDC
I wear a helmet in public! Yeah!
GS850GLX
DR350SE
TopDeadCenter screwed with this post 04-18-2013 at 05:41 AM
TopDeadCenter is offline   Reply With Quote
Old 04-18-2013, 07:52 AM   #3
engineman
engineman's Avatar
Oddometer: 343
I have this exact tool in my shop. It's for spline drive lug nuts. You may want to check if you have any of them installed
Sent from my SCH-R530U using Tapatalk 2
engineman is offline   Reply With Quote
Old 04-18-2013, 04:05 PM   #4
jon_l OP
jon_l's Avatar
Oddometer: 3,303
Thanks, it does seem to fit the lug nut. Is this something I should have for changing a flat? Or did the tech just leave it by mistake?
CBF1000 & PCX150
Old 04-18-2013, 04:29 PM   #5
threadkiller
Semi-feral Pappy
threadkiller's Avatar
Oddometer: 1,792
You should have one in your tire kit.
threadkiller is offline   Reply With Quote
Old 04-18-2013, 04:30 PM   #6
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,139
You only need it if you want to remove the wheel...
Just messin' with ya. If they added a different type of lug nut, you should also check to make sure your lug wrench will fit everything. It could be a problem if you have a factory wrench with only one size. I had to buy a 4-way "star" for that, and the fact that I went to a deep dish wheel, so my factory wrench wouldn't reach the lug nuts before hitting the tire.
High Country Herb is offline   Reply With Quote
Old 04-18-2013, 04:30 PM   #7
MotorradMike
MIL-TFD-41
MotorradMike's Avatar
Oddometer: 1,018
Are all the lug nuts identical?
Do you have a tool in the trunk that fits them?
As stated, there are usually 4 'special' nuts which can only be engaged with a special tool.
It's an anti-theft deterrent.
Edit: Actually, I think I should've said it is a theft deterrent, anti-theft device.
Mike
So far, everything that has surprised me has been completely unexpected.
BMW R1100RS
MotorradMike screwed with this post 04-18-2013 at 04:37 PM
MotorradMike is offline   Reply With Quote
Old 04-18-2013, 04:46 PM   #8
mike
mike's Avatar
Oddometer: 3,314
It may be one nut on all the wheels, or all the nuts on all the wheels that that socket fits. I've seen em both ways. Dont lose it or first time you have a flat youll be calling a tow truck/
as stated above, make sure you have a lug wrench that fits that socket. the factory wrench usually dosent fit it.
2003 ZRX 1200R
mike is offline   Reply With Quote
Old 04-19-2013, 03:13 AM   #9
jon_l OP
jon_l's Avatar
Oddometer: 3,303
Good advice, thank you all. I'll dig out the lug wrench and see whether it fits the new wheels.
CBF1000 & PCX150
Old 04-19-2013, 09:57 AM   #10
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,026
I'd just take it back to the tire shop. The tech SHOULD be very grateful that you returned it. Usually they have to buy & supply their own tools.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 04-19-2013, 12:33 PM   #11
mike
mike's Avatar
Oddometer: 3,314
Why would the tech have a socket that only fits the OP's car? Those sockets only fit the nuts that come with them.
http://www.gorilla-auto.com/
2003 ZRX 1200R
Old 04-19-2013, 12:41 PM   #12
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
It might be the op's socket out of his tool kit. Lots of techs will fish them out then leave them for you to put back.
Danjal is offline   Reply With Quote
Old 04-19-2013, 04:06 PM   #13
Joe
Debaser
Joe's Avatar
Oddometer: 1,749
They are for Tuner nuts for mag wheels. Do you have 2 sets of wheels?
Joe is offline   Reply With Quote
Old 04-21-2013, 04:51 AM   #14
jon_l OP
jon_l's Avatar
Oddometer: 3,303
Well I agreed with Dave in WI, and went back to the tire shop. The guy thanked me, said the tool should stay in the car for when I need it, and that they have lots of them. In fact, he gave me a 2nd one, so I put one in the trunk with the OEM lug wrench (which it fits), and put the other one in the glove box for the mechanic to use for my next brake or bearing job.
Thanks for your feedback all.
CBF1000 & PCX150
Times are GMT -7.   It's 01:27 AM.
