Old 04-13-2013, 08:44 PM   #121
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
Originally Posted by craydds View Post
I heard once that some guys would fill the tank with water, put it in the freezer, and the expansion would pop out all the dents. Sounds kinda crazy, but... who knows?
I was checking that TT500 tank for leaks with air pressure,I accidently gave it too much of an air squirt and the whole tank spread and cracked in a second,useless now.
I would be careful with it,they want a couple hundred for an average one on ebay. If it was steel a hot-stick gun would be the ticket for pulling dents.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-13-2013, 08:52 PM   #122
craydds OP
craydds's Avatar
Oddometer: 1,160
Well, I bought a tank on eBay - http://www.ebay.com/itm/1976-Yamaha-...ice-AHRMA-/200 - don't want to destroy my old tank, but I will have a back up. Maybe I should just sand my old tank, paint it and run it as is. I diid find a tank from Clarke - http://clarkemfg.com/yz250125-7476-s...ity-p-244.html - might work???
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 04-13-2013, 08:55 PM   #123
craydds OP
craydds's Avatar
Oddometer: 1,160
That link above to eBay doesn't work, will try to fix it.
edit: will try this link - http://www.ebay.com/itm/1976-Yamaha-...ice-AHRMA-/200
edit again: can't find a way to show the tank, need my young boys here to show me how to do this stuff.
ABC #12947
'75 R90S
craydds screwed with this post 04-13-2013 at 09:00 PM Reason: no workie
Old 04-19-2013, 05:15 AM   #124
craydds OP
craydds's Avatar
Oddometer: 1,160
success
Went to O'Reilly's:
Puller:
Forks were too long (or the bolt was too short, take your pick):
No threads on the flywheel, all rusted out. Yes, that is JB Weld, tried to pull the flywheel but no luck with the old puller:
Wedged forks into slots so they wouldn't slip out, used the old puller center piece to center the steering wheel puller bolt, heated the flywheel to SMOKING HOT:
A lot of torque on the puller, a few sharp blows with a hammer, and the flywheel popped loose:
ABC #12947
'75 R90S
craydds screwed with this post 04-19-2013 at 05:45 AM Reason: pic
Old 04-19-2013, 05:39 AM   #125
craydds OP
craydds's Avatar
Oddometer: 1,160
yucky
The flywheel was rusted onto the crank shaft, nasty:
I hate dirt and rust:
Sad:
When I first pulled of the external magneto cover, the interior was full of water and dirt:
Knew I had to get that flywheel off and clean things up:
Better now:
Going to put this old flywheel back on, but the threads on the other side are shot. I know now that I can pull if off again whenever necessary, will apply a good dose of anti-sieze when I put it back on:
Ordered an new woodruf key from my local Yamaha shop, should arrive next week. Will lap that shaft and the flywheel internal bore so they are shiny and smooth, and apply a coat of anti-sieze:
ABC #12947
'75 R90S
Old 04-19-2013, 01:30 PM   #126
Valleyrider
I Survived The '60s
Valleyrider's Avatar
Oddometer: 1,865
9.9 You lost a tenth of a point for lack of description on the cleaning process! Nice job.
http://www.flickr.com/photos/14934865@N07/
'07 1250 Bandit, '06 650 VStrom, '78 SR500E
'68 Yamaha DT1, '78 TT500 and no money
http://www.flickr.com/photos/48000856@N06/
Valleyrider is offline   Reply With Quote
Old 04-19-2013, 03:47 PM   #127
craydds OP
craydds's Avatar
Oddometer: 1,160
Lots of Berryman's carb cleaner, Grimeout detergent, scrubbing, phosphotic acid ( "naval jelly" ), wire brushing, and SODA BLASTING. and I am still NOT done...
Been working on wheels today, more to come.
ABC #12947
'75 R90S
craydds screwed with this post 04-19-2013 at 03:47 PM Reason: s
Old 04-19-2013, 07:38 PM   #128
Valleyrider
I Survived The '60s
Oddometer: 1,865
Nice job!!
Racing the TT for the first time tomorrow... weather permitting!!
Old 04-19-2013, 07:48 PM   #129
Scootern29
Scootern29's Avatar
Oddometer: 510
Show the wheels my man. Mine are a little tarnished, and I don't think I will polish them out.
Scootern29 is offline   Reply With Quote
Old 04-29-2013, 05:18 AM   #130
craydds OP
craydds's Avatar
Oddometer: 1,160
Cleaning up the old rear:
Old front:
Shiny front:
Clean rear brake:
New tires:
ABC #12947
'75 R90S
Old 04-29-2013, 05:29 AM   #131
craydds OP
craydds's Avatar
Oddometer: 1,160
out of sequence, but this is the old dirty rear wheel:
Close up, rear, and the front was in the same dirty state:
Got new All Balls wheel bearings/seals and new tires. More to come...
ABC #12947
'75 R90S
Old 04-29-2013, 06:44 PM   #132
Scootern29
Scootern29's Avatar
Oddometer: 510
Lookin good. I have been waiting for you to post. I thought you got lost or something?
Scott
Old 04-29-2013, 08:16 PM   #133
craydds OP
craydds's Avatar
Oddometer: 1,160
Scott
Several projects going on, been working on my son's XR200. Slowly working on the YZ, making some pictures. Then, it's hard to find time to get a few posted here. I am going to quit eating, sleeping, etc., big waste of time, could be working on motorsickles.
ABC #12947
'75 R90S
Old 05-03-2013, 07:51 AM   #134
craydds OP
craydds's Avatar
Oddometer: 1,160
more wheels / tires
Spoke nipples were RUSTY. Cleaned them up as best I could. Notice crack in wheel, had a few cracks in both wheels. I so much want to send them to Woody's for new rims and spokes! But, it is cost prohibitive for now, just going to run them as is. May be later on I will pick up a set of wheels off eBay and get them rebuilt:
New front tire:
New rear rubber:
High tech motorcycle lift:
Progress!
Ready to MOTO:
Rolling chasis. Ready for a Briggs & Statton lawn mower engine:
ABC #12947
'75 R90S
Old 05-04-2013, 01:05 AM   #135
MartinPetren
Swedish Adventurer
MartinPetren's Avatar
Oddometer: 371
It's coming out really nice! Hope you get to ride it soon
Martin Petrén
WallStreetBikes
MartinPetren is offline   Reply With Quote
Times are GMT -7.   It's 03:11 AM.
