Old 04-18-2013, 07:48 PM   #16876
slickwill
Exhiled
Oddometer: 209
Riveted on my DID. I have a clip on my XR100 but speeds are much lower and the penalties for a failure are much lower.
Sent from my DROIDX using Tapatalk 2
slickwill is offline   Reply With Quote
Old 04-19-2013, 02:04 AM   #16877
medisyn
Oddometer: 149
How in the hell did this happen to my chain? http://i.imgur.com/SVTHQ1h.jpg
I am so glad it did not break on me. I wonder if the chain has been like this since I bought the bike and I didn't notice....
What would you guys recommend for me as a replacement? I was thinking an RK or DID chain. I have SM wheels with I think a 15t front and like 44t rear sprocket. I will be replacing those as well. Which brand do you guys like?
Also are there any "while I am in there" parts I should get?
medisyn screwed with this post 04-19-2013 at 07:51 AM
medisyn is offline   Reply With Quote
Old 04-19-2013, 08:08 AM   #16878
bigtrailie
Rough idle
bigtrailie's Avatar
Oddometer: 680
Magnesium repair???
I managed to punch a small (1/8") dent into the very bottom of my clutch cover. This dent is allowing a fine mist of oil to leak out when the bike is running. Anyone tried a sure-fire way of fixing this (i.e. J-B weld)? I'm wondering if it could be tig welded - but for some reason, welders I've spoken with seem to be warry of the magnesium material this is cast from.
Need my knees in the breeze through the trees.
'04 KTM 950 ADVENTURE (black) - '05 Honda XR650R (plated) - '97 Honda XR600R (plated) - '99 Honda Valkyrie Interstate (joy rides with my wife and kids)
bigtrailie is offline   Reply With Quote
Old 04-19-2013, 08:48 AM   #16879
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 169
Magnesium is easy to weld, A magnesium rod is used, Clean and carbide clear the weld area then weld.
clean with a clean stainless brush if a re-pass is necessary.
You don't need structure just a fill, Magnesium is very porous and a good paint coat can help that.
Painting magnesium is a different subject so ill spare you the details.
If you go the JB route cook your cover to 250 degrees after around 15 minutes remove from oven then upon cooling through the 140 range apply epoxy it will get very runny but re apply to fill after it cools more
magnesium will hold moisture and you need to cook it out or you will get weak adhesion
Hope that helps
FlyGuy is offline   Reply With Quote
Old 04-19-2013, 08:49 AM   #16880
crypto666
Oddometer: 1,346
I really cannot believe that did not cost you a crank case. Crazy stuff.
Which chain is that?
crypto666 is offline   Reply With Quote
Old 04-19-2013, 09:16 AM   #16881
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,197
I've had a clip link on the 650 for about 7K of hard riding, it held up fine. I'm no fan of one type or another, the chain came with that link so I used it. I've had it apart a few times also.
The rivited type is definately more secure, given a choice I'd pick that type if it came with the chain I was buying. Ya gotta remember, dirtbikes never had riveted ML for many years, it never stopped anyone from riding the hell out of 'em.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 04-20-2013, 02:50 AM   #16882
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,435
the ol girl copped a flogging today
Sean-0 is offline   Reply With Quote
Old 04-20-2013, 09:17 AM   #16883
1bigrn
Oddometer: 212
how to mount rifle to xr
Big game season is a long way away. But I need to start making plans now.
I need to mount a long-gun to my xr650r for travel down fire roads and some open dirt trails.
Any ideas? Anyone find a solution?
1bigrn is offline   Reply With Quote
Old 04-20-2013, 09:28 AM   #16884
medisyn
Oddometer: 149
I cant remember, I would check but I am in europe for 3 months. It was a japanese name brand. It may have been D.I.D.
Old 04-20-2013, 10:20 AM   #16885
LVCJT
LVCJT's Avatar
Oddometer: 241
Find yourself a saddle scabbard and mount it on the airbox side of the bike.
Sent from my MB855 using Tapatalk 2
LVCJT is offline   Reply With Quote
Old 04-21-2013, 06:47 PM   #16886
EduardoMas
Spartan Overlander
EduardoMas's Avatar
Oddometer: 414
Straightening the rear fender on an XR650R
All XRRs have the rear fender tilted to the left and mine was no exception.
While the XRR is an all purpose, no bling ride, the crooked fender just looks a tad… abandoned.
With a “C” clamp, I straightened the fender and further tilted it to the right by lifting towards the rear rack. (wish I could post pics). I placed a 1500 watt room fan heater on top of the rear wheel, blasting up at the fender. I also heated the stressed areas around and in between the mounting screws with a heat gun.
After about 20 minutes the fender was sprayed with cold water and when the clamp was removed the fender stayed bent a touch to the right, but way straighter than before.
The straight fender just makes the whole bike look a lot better… you know, for a dirt bike.
Just sharing…
Eduardo
XR650R
KTM300
Simplicity is the ultimate sophistication.
EduardoMas is offline   Reply With Quote
Old 04-22-2013, 07:13 AM   #16887
hontri
Global Bummer!
hontri's Avatar
Oddometer: 304
Finally! the snow receded enough to let me get to one of my favorite fishing lakes. no fish but good ride.
hontri is offline   Reply With Quote
Old 04-22-2013, 07:30 AM   #16888
crypto666
Oddometer: 1,346
Try a heavy duty tripod head built for 40-60lb cameras mounted to the bars with a M249 SAW and about 200 rounds of ammo. That should work.
You might be able to get a MK19 on there, but they are pretty bulky and you wouldn't be able to carry much ammo.
If you really want trick, get that eyeball tracking aiming system used in Apaches so you shoot everything you look at.
2.5" rockets can be nice in a target rich environment.
Old 04-22-2013, 09:02 AM   #16889
Shibby!
Oddometer: 1,660
Damn!
This was my day yesterday!
Looks like prime riding out there in Summerland!
We're doing Koocanusa in two weeks. That's about as good as it gets around here. Whoops... Lots of whoops...
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 04-22-2013, 11:36 AM   #16890
LVCJT
LVCJT's Avatar
Oddometer: 241
Wonderful critic of a fellow inmates choices. ghead:
Times are GMT -7.   It's 12:21 PM.
