Old 04-20-2013, 06:29 PM   #1
Dorito OP
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,378
Zumo 660-Show Campsite as POIs?
Normally, if I mark something as a "favorite" on the Zumno 660, it will label/mark that location on the screen as I ride anywhere near it. I want to do the same thing with campsites for an upcoming trip. Basically, I want to display the track, and also see where the nearest campsite will be.
I am thinking that I could use a POI loader, but what is the easiest/preferred one? Obviously, these campsites are only going to "favorite" for a short duration. Is there a swanky way to keep all these in their own "favorites" file?
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 04-21-2013, 06:08 AM   #2
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,169
I have used the Garmin POI Loader, and it has worked fine: http://www.garmin.com/us/maps/poiloader
POI-Factory has a lot of camping files. Perhaps one would suit your needs: http://www.poi-factory.com/taxonomy/term/35
You can have multiple custom POI files on your device. As you upload a POI file to your GPS, one of the dialog boxes lets you give the file a name. Simply give each custom POI file a unique name that makes sense to you. I think the default name in the text box will be something like "Custom POI" but you could change that to "Campsites" for example.
ETA: Here is the dialog box where you can name your POI file whatever you want. I have put an orange box around it.
HTML code is Off
Times are GMT -7.   It's 08:46 PM.
