Old 04-20-2013, 06:57 AM   #3826
J.Johnson
J.Johnson's Avatar
Oddometer: 85
Originally Posted by MasterMarine View Post
So what is the best pipe guard to get? I want to get a full coverage model that covers as much of the stock head pipe as possible so I don't melt my expensive gear or sensitive skin so easily. Most of my older stuff has melt marks in it already from my KLX and its Big Gun headpipe.
I have prowled thru this thread but it is so hard to sort out who has what. My 500 EXC is on its way to the dealer so I am trying to get the goodies for it before it arrives.
Thanks for your input!
I wrap my header on all my bikes with header wrap. Keeps from melting pant Leah's and such. The kids appreciate it also.
Sent with this high tech chingadera!
“This is your life, and it’s ending one minute at a time.”
J.Johnson is offline   Reply With Quote
Old 04-20-2013, 10:51 AM   #3827
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Originally Posted by bill1960 View Post
I'm looking at getting the E-line carbon fiber header pipe guard.
http://www.elineaccessories.com/ecom...2/mpg500e.html
Would be interested to hear from those that have used one.
I think this is the carbon guard I have. To be honest I just grabbed it off the shelf at my dealer and then removed any labels. So far so good. A few minor dings but has protected the pipe well and it's easy to clean.
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 04-20-2013, 12:27 PM   #3828
thumperB
thumperB's Avatar
Oddometer: 99
Question
Anybody know the correct torque for the front sprocket bolt? Its not spec'd in the manual...
thumperB is offline   Reply With Quote
Old 04-20-2013, 02:16 PM   #3829
Hueychief
FNG
Hueychief's Avatar
Oddometer: 77
Not sure if this is correct, but Pg. 108, 7th from the bottom: Screw, Engine Sprocket M10 60Nm (44.3 lb/ft).
I replaced my front with a 14 and IIRC that sounds about right.
Waterboarding Works
KTM 500EXC
Hueychief is offline   Reply With Quote
Old 04-20-2013, 02:30 PM   #3830
thumperB
thumperB's Avatar
Oddometer: 99
Ahhh... that's it! Thanks. Helps to look at the right page...
Old 04-20-2013, 06:14 PM   #3831
SoilSampleDave
Oddometer: 2,158
Torque it down till it strips, then back it off a 1/4 turn. Works on any bike.
"Comparison is the thief of joy" - TR (the good Roosevelt)
'08 530EXC
SoilSampleDave is offline   Reply With Quote
Old 04-21-2013, 08:13 AM   #3832
Enduro Outlaw
Enduro Outlaw's Avatar
Oddometer: 27
Originally Posted by yzedf View Post
Got down n dirty the other day!
14/48 gearing is on the way, need to slow down those rocky 2nd gear descents
Install a tusk oversized rotor and a new pair of ebc pads and your good to go.. The tusk oversized rotor is a must have for this bike.
I'm gonna have to be taking your car today. See I have some top secret clown business that supersedes any plans that you might have for this here vehicle.
Enduro Outlaw is offline   Reply With Quote
Old 04-22-2013, 08:52 AM   #3833
Bengt Phorks
Oddometer: 255
Thx for the info, I'll contact the vendor.
Looking at the respective website specs, (advmonster and BD) they both use four Cree XM-L T6 LEDs, and claim 3600 lumens, but have different housings
http://stores.intuitwebsites.com/hst...off/Detail.bok
http://www.bajadesigns.com/ProductDe...mNumber=497051
Interesting that the BD draws 42watts and the ADVmonster only 28w, which suggests some difference.
Here is a link to a picture of the headlight. Click on this link to get to the headlight post: 2767
This link shows the light pattern and power of the ADVmonster lights: 3095
Bengt Phorks is offline   Reply With Quote
Old 04-22-2013, 01:55 PM   #3834
tujacov
Oddometer: 8
I was asking some time ago about the carbon fiber exhaust guard as below.
As you can see it covers nearly all pipe, it is perfect. And yes, I have it also, finally I found it! Here: http://carbonoracing.com/
For 500 the right guard is PE 510 and the price was 65.74 € plus the freight
tujacov is offline   Reply With Quote
Old 04-22-2013, 02:06 PM   #3835
wsmc831
wsmc831's Avatar
Oddometer: 804
Are they supposed to be superior to e-line? i would think it would keep things hotter the more it covers the header.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 04-22-2013, 02:28 PM   #3836
psyco
Motard Madness
psyco's Avatar
Oddometer: 63
Need some help from you guys , I have a 13 500 exc and the front end is shaky as hell at higher speeds . Feels like I need a damper , the front end gets real loose and feels like it wants to tank slap me at any moment . Any help from you guys would be greatly appreciated , I have searched on here and nothing has come up . I'm trying to keep from having to put a damper on but if that is what it takes so be it .
psyco is offline   Reply With Quote
Old 04-22-2013, 02:36 PM   #3837
team ftb
Befuddled Adventurer
Oddometer: 1,761
The 500's have very little trail built into these chassis and that gives them wonderfully light steering manners......at the expensive of rock steady stability. Lower the forks in your fork clamps to where they are at the top of the fork tubes (not fork caps) and ride it again and see if it's better for you. Not sure if you just took it for a spin on the street and no dirt. The stock front tires get caught in the rain grooves on the freeways and pull the front wheel all over the place, leading to the handlebars wagging in your arms.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 04-22-2013, 02:52 PM   #3838
bobfab
bobfab's Avatar
Oddometer: 1,497
i dont see any wheel weights on the front. Perhaps a bit of a balance issue also?
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 04-22-2013, 04:48 PM   #3839
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,044
[QUOTE=psyco;21244712]Need some help from you guys , I have a 13 500 exc and the front end is shaky as hell at higher speeds . Feels like I need a damper , the front end gets real loose and feels like it wants to tank slap me at any moment . Any help from you guys would be greatly appreciated , I have searched on here and nothing has come up . I'm trying to keep from having to put a damper on but if that is what it takes so be it .
First you need to have your suspension adjusted for your weight and riding style.
Including having the right springs front and rear. The tire pressures correct and
have checked the steering head bearing for play.
Then start adjusting the forks in the triple clamps.
If you get ahead of your self and don't do the basics first
you can find solutions that are less than optimal.
It's possible that you will not be able to have the suspension
work perfectly in all conditions.
I'm just starting to work through the suspension on a new 500xcw
But on my 690 e I could get the bike to work well at speed on the road
but with those settings it was hideous in the sand washesIi'm riding in S,Az.
Max
Da oggi la strada
é senza limiti
MAXVERT is offline   Reply With Quote
Old 04-22-2013, 05:18 PM   #3840
Element_6
Oddometer: 16
Max
I know you need to change out the rear springs but is it a requirement to change out the front? I ask as I am outside the 'optimal' envelope for the stock set up. So far I haven't changed the springs as the stock bike is already so much better than my skill level, would I benefit from these changes (using it more as an adventure tourer).
On my bike I get a low frequency wobble above about 100km/h (60mph) but this is dependant on wind conditions, being less noticable on still days. I never get any shake so if you are getting that then maybe it is balance as people are pointing out
Element_6 is offline   Reply With Quote
Times are GMT -7.   It's 03:41 AM.
