Old 04-22-2013, 05:04 PM   #76006
procycle
procycle's Avatar
Oddometer: 2,324
Originally Posted by refokus View Post
... I left the snorkel out when I put the airbox back in. Thats it......
Stock main, stock pilot, shim the needle up .030"
As long as you are not cutting open the airbox you don't need anything else.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 04-22-2013, 05:09 PM   #76007
refokus
Just Learning
refokus's Avatar
Oddometer: 2,458
Jeff, what is the stock main and pilot. I bought this bike recently (and have ordered many items from procycle recently) and I am sure the previous owner was in the carb and I am not sure what the stock sizes of jets are.
Now, if I was to open up the air box what jets should I use and I want to put the extended fuel mixture screw in. Does the kit on your site cover all jets? When looking at the picture, I did not see the pilot jet.
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 04-22-2013, 05:33 PM   #76008
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,930
I've become what I hate...a throttle bliper! Help me stop the madness!
DR just started not wanting to idle down when coming to a stop. Quick blip of the throttle and it settles down. Thought throttle blade was sticking and figured after the first time that would be it. Nope. I even tried using the push/pull on the throttle and it wont idle down. Blip works every time... WTF?
Going to pull the carb off and give it a good cleaning. Any suggestions on a probable cause?
I swear I will sell the f*!@er if I have to blip the throttle all the time
Mongle is offline   Reply With Quote
Old 04-22-2013, 05:40 PM   #76009
procycle
procycle's Avatar
Oddometer: 2,324
Main 140
Pilot 42.5
If you open up the airbox you need a jet kit because you have to change the needle to compensate for the loss in airbox restriction. The jet kit doesn't include a pilot jet. There has never been a need to run anything other than the stock pilot.
Old 04-22-2013, 05:47 PM   #76010
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,854
OK, I got my DR on the road with the new suspension from Cogent and some other new components this last Saturday. The suspension worked really good, the carb needs some attention. I will be ordering new jets, fuel mixture screw for this and give the carb a good cleaning. I need some advise on what jets to get. Here are the details; FMF Q4, and I left the snorkel out when I put the airbox back in. Thats it......so, I am looking for some good insight here on what to get ordered up (Pilot, Main, etc). Thanks in advance
Oh one more thing. I live in the Phoenix but I head north quite often and I will be heading to Colorado this year as well.
I have the Q4 on my 530 KTM,its way louder then one would think,if you like noise it's the 1 to get.
Then when the packing blows out it will echo off the canyons.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-22-2013, 05:51 PM   #76011
Mtn Man
Mtn Man's Avatar
Oddometer: 210
Rigerimer help ...
Hey man, hang in there and take a shot at he two inmates ideas. I know you have a line screwed up going to the carb so maybe between the three things you will be up and running for Pickett!
Might want to reach out to MX Rob or Procycle about the carb issue we discussed. Rob is the best and makes the pumper carb I have on my bike.
Footnote :
Should not have bought blue, they don't run as well!
Mtn Man is offline   Reply With Quote
Old 04-22-2013, 05:51 PM   #76012
refokus
Just Learning
refokus's Avatar
Oddometer: 2,458
I'll run my Q4 until the packing goes to hell then I will put the stock muffler back on....
Old 04-22-2013, 06:33 PM   #76013
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I forgot ... are you running the stock BST40 Carb? If so ... PM Derek.
My old Carb did the same ... slide/Jet needle was worn out (apparently).
I just bought a whole new Carb. This might be it, not certain, but when the slide and Jet needle begin to wear you can get off idle stumble and stalling going down to idle. YMMV.
Just a thought.
Old 04-22-2013, 06:37 PM   #76014
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,930
Just a thought.
Stock-ish BST40
Forgot about the whole needle wear. I do have an aftermarket needle (PC kit); I will have to check the tube it runs in. I think Derek has mentioned not liking aftermarket needles due to wearing that tube.
Old 04-22-2013, 06:40 PM   #76015
Indytriumph
Indytriumph's Avatar
Oddometer: 33
I have done most of that, what I have left is the suspension and motor rebuild. I am debating if it is worth it.
A good riding buddy did about 90K on his Wee Strom, lots of Mexico off road. His bike got very loose and sloppy feeling (when compared to brand New Wee Strom) But before he sold it he went though and replaced most all the bearings (steering head, swing arm, link and wheel) and refreshed suspension, front and rear (Wilbur shock). The bike was transformed, steered better, more stable, better handling. The motor and mechanicals never had any problems. AFAIK, his bike is still on the road and doing fine.
Indytriumph is offline   Reply With Quote
Old 04-22-2013, 06:43 PM   #76016
Adv Grifter
Oddometer: 6,128
Stock-ish BST40
yea, its that stinkin' tube. My needle looked OK but the slide and tube showed a bit of wear. Does not take much to affect smooth running.
Could also be a bit of water in float bowl. Drain it for luck. Maybe a dose of Sea Foam or Techron? Also, re-check fuel/air screw setting (mine vibrated OUT) and reset idle speed.
Good luck!
Old 04-22-2013, 07:56 PM   #76017
bluegroove
Motorcycle junkie
bluegroove's Avatar
Oddometer: 444
Sargent seat to sell
anybody want one? I have an extra. I put a bunch of pics of it here:
http://www.toughguards.com/temp/forsale.htm
Please PM me if interested. thanks
Former Mechanic in Honda and Kawasaki Dealer (eons ago). 38 yrs. of riding and racing dirt and street.
bluegroove is offline   Reply With Quote
Old 04-22-2013, 08:07 PM   #76018
bluegroove
Motorcycle junkie
bluegroove's Avatar
Oddometer: 444
hmm.. maybe I wasnt' sposed to post it here? It's in the flea market now. Just thought I'd let you guys know 'cause it's a DR650 item.
Old 04-22-2013, 08:49 PM   #76019
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
Seat
PM sent
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Old 04-23-2013, 03:00 AM   #76020
rand0mlychrisUK
rand0mlychrisUK's Avatar
Oddometer: 28
This UK Ebay Shop is breaking a '98 DR for parts and flogging them, might be useful for any of you guys.
Breaking DR650 for Spares
Thought it might be of use
Chris
'96 DR650SE in the snow...
rand0mlychrisUK is offline   Reply With Quote
Times are GMT -7.   It's 08:29 PM.
