Old 04-22-2013, 12:38 PM   #6076
byways
byways
byways's Avatar
Oddometer: 2,257
Thanks, brother!
byways is offline   Reply With Quote
Old 04-22-2013, 01:26 PM   #6077
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,745
Originally Posted by MacNoob View Post
I would like to keep all my fingers....
http://www.team-bhp.com/forum/motorb...ain-stand.html
Stupid happens.... even accidental stupid!
http://www.justanswer.com/health/169...straw-eye.html
.... I'll probably continue to use drinking straws and oil my chain with the motor running but will recommend that most people refrain from both.
West - "Oeste Sanchez"
RideAbout is offline   Reply With Quote
Old 04-22-2013, 04:16 PM   #6078
viper770
viper770's Avatar
Oddometer: 589
i finally got the stickers off my new 2013 klr650
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 04-22-2013, 04:22 PM   #6079
bdcorrigan
bdcorrigan's Avatar
Oddometer: 648
That's Darwinism to it best. I didn't say clean, I said lube, as in with a can of spray lube with a straw on the nozzle. Sorry if I wasn't clear on that.
bdcorrigan is offline   Reply With Quote
Old 04-22-2013, 05:40 PM   #6080
astrolump
astrolump's Avatar
Oddometer: 868
Originally Posted by bdcorrigan View Post
that's darwinism to it best. I didn't say clean, i said lube, as in with a can of spray lube with a straw on the nozzle. Sorry if i wasn't clear on that.
a straw?.....you'll poke your eye out!
HEY. did you see something fall off my bike? I mean other than me.
"They see me coming on my KLR......They hide their daughters and their PBR......
I'll take the beer,no time for girls......Got a date in the Forest, chasing squirrels. "
astrolump is offline   Reply With Quote
Old 04-22-2013, 05:44 PM   #6081
byways
byways
byways's Avatar
Oddometer: 2,257
Way better-looking! But I dunno ... to blend in with the asphalt to that extent seems kinda risky.
Still ... I love the look!
Old 04-22-2013, 05:50 PM   #6082
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,877
Originally Posted by KamikazeKLR View Post
I'm glad I don't have issues like that on mine. the previous owner did all the hard work for me
I wish I could help you but I'm not sure what causes that problem.
So here is MY question to add... Leaving in just about a week for the big trip, what's a list of things I ABSOLUTELY NEED to check on both bikes before leaving? I've done the basics like oil changes, check the chain, install farkles..
And another.. does anybody live in the northern states (North Dakota, Minnesota, so on..) that would like us to stop by for a little meet and greet, maybe even a ride?
1. Cables. Make sure there are no frayed cores and that they are well lubricated. If you can, carry a spare of each.
2. Check brake pad thicknesses - easy with a flashlight.
3. Check coolant levels in the rad and puke bottle.
4. Check fuses and have spares - install with dialectric grease.
5. Take spare light bulbs.
6. What sort of battery is in the bike? If a wet cell, make sure the water levels is up and the terminal are tight.
7. Check the brake fluid levels. If not changed in the last 2 years, change them.
8. Go over each and every bolt on the bike. Loctite any you find loose.
9. Can you repair a flat on the road and do you have the tools to do that?
10. Chain lube ofr on the road?
11. Make sure you have fun!
Tsotsie is offline   Reply With Quote
Old 04-22-2013, 06:36 PM   #6083
XDragRacer
Oddometer: 3,188
Adding to previous recommendations above:
For Generation 1 KLR650's, if you plan on any night riding at all, I strongly, STRONGLY recommend you consider the IPF "FAT BOY" H4 headlight bulb:
http://www.tpimotorcycleparts.com/on...category_id=45
You can use this bulb as a direct replacement alone, or enhance its outstanding perfomance by adding a relay harness. A tremendous improvement over OEM lighting, with consequent safety aspects for both low and high beams.
I'd suggest you install this bulb, and carry the OEM for a spare--or, if you can afford it, carry another FAT BOY.
If any water crossings deeper than 10" appear likely, the "Tee mod" is essential.
Handguards may protect your control levers; spare levers on-board not a bad idea.
Wishing you a safe and enjoyable ride!
XDragRacer screwed with this post 04-22-2013 at 06:45 PM
XDragRacer is offline   Reply With Quote
Old 04-22-2013, 06:50 PM   #6084
CallMeBoog
hi functioning idiom
CallMeBoog's Avatar
Oddometer: 6,277
Hey folks.
I recently moved up to KLR - I traded a buddy an 09 sherpa for an 08 KLR.
Anyway, I had the tank off today, and noticed this tube coming out of the head. the hose on the end had burned off, and there was a bunch of soot on the end of the pipe. What is it, and where is the hose supposed to go??
Don't Ride With Nate!
CallMeBoog is offline   Reply With Quote
Old 04-22-2013, 07:20 PM   #6085
the borg
the borg's Avatar
Oddometer: 106
Originally Posted by LilGreenBooger View Post
Hey folks.
That is the Air Induction System. You either need to hook it back up or remove it and block off the port and the vacuum port on the carb.
the borg is offline   Reply With Quote
Old 04-22-2013, 07:25 PM   #6086
CallMeBoog
CallMeBoog's Avatar
Oddometer: 6,277
hook it back up to what? where does this go? I'm not having any luck searching
Old 04-22-2013, 07:33 PM   #6087
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,019
Hey I like the FAT BOY bulb idea,Any issues with powering it,I ride at night a lot and your correct Gen1 is sketchy in the dark.
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Old 04-22-2013, 07:35 PM   #6088
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,019
Oh and Viper it looks really good,but wear some HI VIZ.
Old 04-22-2013, 08:14 PM   #6089
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,276
Thanks, I have been debating it and have only removed the stickers on the panels under the seat. That looks really mean. Now just get off my lazy ass!!
"I refuse to tiptoe through life only to arrive safely at death" '13 Tiger 800XC, '14 Street Triple, '00 KLR 650(finished project), and 2010 Honda NT700V wife's.
Drunk_Uncle is offline   Reply With Quote
Old 04-22-2013, 10:50 PM   #6090
D_A
D_A's Avatar
Oddometer: 1,280
It provides a source of fresh air into the exhaust system to help finish the combustion process. In short, it's pollution/emissions gear. The other end of the hose should have been connected to the filtered side of the air box or the carby somewhere. If you decide to remove it make sure to block off both ends, one at the head the other at the air source, or it will run like crap.
D_A is offline   Reply With Quote
Times are GMT -7.   It's 05:21 AM.
