Old 04-22-2013, 10:02 PM   #34951
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 4,703
Originally Posted by Gryphon12 View Post
Does anyone actually read this thread before posting???
WR250R Rake/Trail: 26.7 / 4.37"
WR250X Rake/Trail: 25.3 / 2.99" - they are supposed to be different, but only due to wheels - no need to "slide in triples" unless you want 250R geometry off road on a 250X.
WR250R wheel base: 55.9"
WR250X wheel base: 56.1", due to different sprockets ONLY
WR250R GC / Travel f/r: 11.8" / 10.6" / 10.6"
WR250X GC / Travel f/r: 10.4"/ 10.6" / 10.6", due only to wheel diameter and tire profiles.
Suspensions are the SAME including internal valving; initial settings are different.
Transmission gear ratios are IDENTICAL (unlike SMS 630 / TE630).
Forks, frame, and swing arm are identical. Front brake rotors are different, of course.
Sprockets change the wheelbase measurement?
Isn't wheelbase measured from the center of the hubs?
Currently in learning mode as I picked up a practically new '12 R this past Friday. Had it in the bed of the truck the entire CoTA MotoGP weekend.
Hope there's room for one more inmate on this thread.
I'm going to use it to fart around dirt and gravel roads around here, basically motorized hiking. My GS is too much of a pig and my skill level low. The KLR is ok but I wanted something lighter. We'll see how this goes. Was going to dual sport the KDX but I think this WRR will fit the bill.
I do need to figure out the wheel thing as I want to swap SM and DS wheels quickly. Am thinking of having SM wheels laced to WRR hubs.
A drunk driver killed someone I love
WeazyBuddha is online now   Reply With Quote
Old 04-22-2013, 10:06 PM   #34952
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,128
And now for something completely different.
http://advrider.com/forums/showpost....postcount=3256
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is online now   Reply With Quote
Old 04-22-2013, 11:53 PM   #34953
Gryphon12
Gryphon12's Avatar
Oddometer: 1,325
Yep. Use a bigger rear sprocket and the same length chain and the center-to-center hub distance will change slightly. A bigger sprocket will force the rear hub very slightly forward with the same length chain. Two-tenths of an inch isn't much - it's the same swing arm, but different rear sprocket.
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 04-23-2013, 04:52 AM   #34954
eemsreno
Oddometer: 933
That is some great ridding!!!
Wish it was closer.
eemsreno is offline   Reply With Quote
Old 04-23-2013, 05:28 AM   #34955
Red Sand
Red Sand's Avatar
Oddometer: 296
Am I the only one who rides 72 miles of mostly paved roads just so I can play in the dirt?
At this point, I don't have a trailer or truck or friends who are willing/able to take me.
Doing this, I don't think a rear D606 will last very long so I'm considering alternatives.
~ ~ ~ ~ ~ 2014 Triumph Scrambler ~ ~ ~ ~ ~
~ ~ ~ ~ ~ 1983 Yamaha XT250 ~ ~ ~ ~ ~
Red Sand is offline   Reply With Quote
Old 04-23-2013, 05:41 AM   #34956
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,907
MT43 Pirelli rear is my tire of choice for my WR-R with 22K miles after trying numerous other brands/styles. Like riding on velcro. I get around 3K from a MT43 and it works about as well at the end of its tread life as when new. $30 less than a D606 too.
For the front I've just switched from D606 to the MT21 Pirelli. I liked the D606 a little better, but it's directional and when I turned around after cupping began it adversely affected handling. The MT21 isn't directional so I hope to be able to get two rear MT43s rears to one MT21 front. We'll see.
GSBS is offline   Reply With Quote
Old 04-23-2013, 08:44 AM   #34957
ilyaon
Oddometer: 92
I'm in the process of buying WRR. Could you share what was your OTD price if you've bought one recently.
Or if you know what is the dealer mark up should be?
Thank you.
ilyaon is offline   Reply With Quote
Old 04-23-2013, 09:13 AM   #34958
WeazyBuddha
Oddometer: 4,703
Ah, right dat
Old 04-23-2013, 10:48 AM   #34959
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,128
I don't trailer my WR much, and dirt roads are 20-30 miles away. Only tried three so far on the WR: Stockers, Kenda 270 and Shinko 244. Like the Shinko's the best so far, and the price is cheap enough I don't have to run them bare before I change em.
Old 04-23-2013, 11:00 AM   #34960
Crazy_Dave
Back'in it in
Crazy_Dave's Avatar
Oddometer: 583
Yep I really like the Shinko 244's on my WR. I get around 3k outa the rear tire with lots of road riding.
It’s easier to apologize then it is to ask permission.
01 R1-01 CBR929-08 WR250R-92 DR650 (24-7 365)-07 F650GS-05 200 EXC-03 450EXC
Crazy_Dave is offline   Reply With Quote
Old 04-23-2013, 11:04 AM   #34961
bradluke0
Oddometer: 191
Hi all ! Thanks for all the info regarding suspension set-up on my friend's X converted to R off road bike . Knowing the the forks and shock springs and length are the same makes it a lot simpler . Does he need to pull the shock to set the preload?? thx again guys.......brad
bradluke0 is offline   Reply With Quote
Old 04-23-2013, 11:30 AM   #34962
Rainshadow
Oddometer: 370
Reading through longer threads is very educational, and not just for information on a specific bike. In reading (over several months) this thread, and the huge DR650 thread, and the Super Tenere thread (just those three), I've learned more about old technology, new technology, other bikes, accessories and mods, riding techniques, maintenance, planning for trips, and fixing things in the field, than I have anywhere else in the past 10 years.
While I agree with this totally in theory, trying to read this thread from start to finish is like the sentence of Sisyphus pushing that damn giant boulder uphill forever. I've spent all my free time for days on end reading the Mega thread only to realize afterwards that the thread had grown by more pages than I'd read. If I took a day off, fugetaboutit, it grew by multiples of what I could skim in a day. Since I have a job and family, reading the entire thread from start to finish is impossible.
That being said, it's easy to use google to search for specific info within the thread. The link is posted every time you get a "D'oh!" message from the search engine. Just open the link, change the search parameters in the example and cut/paste it into your search engine. Easy peasy...
Rainshadow is offline   Reply With Quote
Old 04-23-2013, 11:34 AM   #34963
skierd
Wannabe Far-Rider
Oddometer: 2,911
I used to ride about 100 miles each way to get to a good dirt play ground, the D606's lasted just fine. I typically got 4000 miles out of a rear, but have stretched as much as 7500 out of one.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 04-23-2013, 11:42 AM   #34964
WeazyBuddha
Oddometer: 4,703
I believe the rotor and brake components are a bit better on the X vs. R.
With that in mind, has anybody laced DS wheels to the X hubs to benefit from the better brakes?
I'm tempted to lace R hubs to SM wheels to be able to switch back and forth quickly but am wondering if there is anything to gain from doing it as I describe above, DS wheels on X components.
Old 04-23-2013, 11:50 AM   #34965
Torontorocko
Ordinary Average Guy
Torontorocko's Avatar
Oddometer: 36
did you miss this from the last page?
Originally Posted by Mr. Fisherman View Post
Fine, lets make this easy...
X mode...
R Mode
2012 WR250R
Torontorocko is offline   Reply With Quote
Times are GMT -7.   It's 10:04 PM.
