Old 04-21-2013, 05:50 PM   #15556
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,424
Originally Posted by Blakebird View Post
HH is a compound, EBC is a brand.
What are you doing in here Mate ? Shouldn't you be drooling over old airheads or Nortons
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is offline   Reply With Quote
Old 04-21-2013, 09:54 PM   #15557
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,476
I occasionally click on the wrong thread here and there
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 04-22-2013, 04:33 PM   #15558
DR350seKING
Oddometer: 68
what style of bulb for tach?
does anyone know what number of bulb goes in the back of the tach?
mine is out.
would it also be the same bulb for the turn indicator on the dash.
also how would I put pictures on when i try to insert image it asks for a URL but mine are saved to the computer and will not come up
in my other post i said there was 100072 miles it should be 10072 (my bad)
DR350seKING is offline   Reply With Quote
Old 04-22-2013, 05:15 PM   #15559
2old2Bbold
was 2bold2getold
Oddometer: 1,838
mine is out.
You will need put your pics on a photo hosting site and link them to your posts. Here's the procedure.... http://www.advrider.com/forums/showthread.php?t=919
2old2Bbold is offline   Reply With Quote
Old 04-22-2013, 05:21 PM   #15560
Anonawesome
Scenic Rider
Anonawesome's Avatar
Oddometer: 1,319
mine is out.
Not sure exactly what kind but yes it is the same as the indicator bulb.
Anonawesome is online now   Reply With Quote
Old 04-22-2013, 05:40 PM   #15561
_CJ
Retrogrouch
_CJ's Avatar
Oddometer: 1,743
Built a new exhaust this weekend......
http://advrider.com/forums/showpost....3&postcount=24
Access to public lands is a right, not a privilege.
_CJ is offline   Reply With Quote
Old 04-22-2013, 09:01 PM   #15562
Rich667
Rich667's Avatar
Oddometer: 178
Damn! nice job on the exhaust. when i looked at the first picture I thought it was an aftermarket pipe.
Rich667 is offline   Reply With Quote
Old 04-22-2013, 09:48 PM   #15563
boardforever
boardforever's Avatar
Oddometer: 212
I just wanted to show some love for Kientech's durable marker lights, was riding trails last weekend and went down pretty hard twice, not bad enough to hurt but hard enough that it definitely would have done away with the cheap turn signals I was running. Jesse's signals are not only in place but undamaged, well made and worth the money.
1999 DR350SE
2006 Kawasaki ZZR600 [sold]
boardforever is offline   Reply With Quote
Old 04-23-2013, 07:23 AM   #15564
culliganman
92 dr 350s
culliganman's Avatar
Oddometer: 185
92 DRs 350 with cv carb
Ready to pull my hair out!
Bike is running very lean, happened all of a sudden have had the carb apart 3x to no avail, boots look good you could eat off the carb its so clean. What are the odds the timing chain jumped? I do notice a air blast,poof type sound when starting it that seems new if that makes a difference not a backfire its coming from the motor somewhere.
culliganman is offline   Reply With Quote
Old 04-23-2013, 07:47 AM   #15565
dbarale
Squiddly slow
dbarale's Avatar
Oddometer: 1,296
Hole in the diaphragm? Valve clearance? Cracked intake boot? Do you have a vacuum activated petcock?
dbarale is offline   Reply With Quote
Old 04-23-2013, 07:53 AM   #15566
culliganman
92 dr 350s
Oddometer: 185
Raptor petcock, diaphragm looks good,no cracks in boot. working on valves today but not so off as to cause the issue i'm having.
Old 04-23-2013, 08:27 AM   #15567
Zane Neher
Zane Neher's Avatar
Oddometer: 163
So, bike's been slipping since Ive had it (6 months) and finally picked up and EBC lkit with springs, steel and fibers.
Hasn't been bad but you can tell when you start off hard or try and wheelie.
But now I've been looking for a write up before I screw something up but can't find one and the online manual I have just says measure stuff.
Is there a write up or a certain way the plates go in?
I've got them soaking in oil as we speak.
I assume since I can't find a write up it's a stupid easy job?
Also, could I tip the bike sideways and keep the oil in since I just did a change last week and the girlfriend is at work right now so Ill be stranded.
Zane Neher is offline   Reply With Quote
Old 04-23-2013, 08:38 AM   #15568
haggeo
haggeo's Avatar
Oddometer: 913
i have those same lights, first thing i bought for my bike.
When the facts change, I change my mind. What do you do, sir? John Maynard Keynes
Faced with the choice between changing one's mind and proving that there is no need to do so, almost everyone gets busy on the proof." John Kenneth Galbraith
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane. Marcus Aurelius
haggeo is offline   Reply With Quote
Old 04-23-2013, 09:05 AM   #15569
MrPulldown
MrPulldown's Avatar
Oddometer: 3,391
Not to talk smack, but I think the Durable marker light is a little over engineered. The addition of a metal plate to mount a flush mount turn signal is jsut added weight. Why not jsut buy some flush mouted turn signals and mount them on the fender.
I am jsut barrowing this picture form a couple of post back.
Or if you are using the stock lamps, you can mount the turn signals directly on the tail lamp. This is a very elegant solution. This is the way I have mine mounted. I have dropped my bike 30+ times and have never broken a turn signal.
MrPulldown is offline   Reply With Quote
Old 04-23-2013, 09:18 AM   #15570
MrPulldown
MrPulldown's Avatar
Oddometer: 3,391
Is the on-line manual the factory one. Chapter 3-40 has a couple of pages of discription. 3-27 is where is says to measure stuff. KEEP READING. If you do not have the FSM. You can find it on Benders Site:
http://thisoldtractor.com/gtbender/dr350.htm
The CLymer (?) manual also has several pages discribing the procedure.
Here is another write up: Good one with alot of pictures. http://www.maximum-suzuki.com/forums...2452#msg892452
The job is not stupid easy, but fairly straight forward. Are you chaning out the thrust washers. The spacer gave me a hard time as I could not remove it.
Yes you can lay the bike on its side tyo work on the clutch and keep the oil in it. Or you can drain it into a tub and reuse?
MrPulldown screwed with this post 04-23-2013 at 10:06 AM
Times are GMT -7.   It's 06:59 AM.
