Old 04-22-2013, 09:02 AM   #16891
Shibby!
Oddometer: 1,658
Originally Posted by hontri View Post
Finally! the snow receded enough to let me get to one of my favorite fishing lakes. no fish but good ride.
Damn!
This was my day yesterday!
Looks like prime riding out there in Summerland!
We're doing Koocanusa in two weeks. That's about as good as it gets around here. Whoops... Lots of whoops...
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 04-22-2013, 11:36 AM   #16892
LVCJT
LVCJT's Avatar
Oddometer: 236
Originally Posted by crypto666 View Post
Try a heavy duty tripod head built for 40-60lb cameras mounted to the bars with a M249 SAW and about 200 rounds of ammo. That should work.
You might be able to get a MK19 on there, but they are pretty bulky and you wouldn't be able to carry much ammo.
If you really want trick, get that eyeball tracking aiming system used in Apaches so you shoot everything you look at.
2.5" rockets can be nice in a target rich environment.
Wonderful critic of a fellow inmates choices. ghead:
Sent from my MB855 using Tapatalk 2
LVCJT is offline   Reply With Quote
Old 04-22-2013, 01:24 PM   #16893
jules083
jules083's Avatar
Oddometer: 3,895
Originally Posted by 1bigrn View Post
Big game season is a long way away. But I need to start making plans now.
I need to mount a long-gun to my xr650r for travel down fire roads and some open dirt trails.
Any ideas? Anyone find a solution?
I have a rack that bolts on the rear rack of my klr and seems like it would hold a gun sturdy. The previous owner used it to go trap shooting, I never have. I'll be home next Sunday and take some pictures. You can have it if it will work for you.
All typos and misspellings blamed on my phone.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is offline   Reply With Quote
Old 04-22-2013, 03:30 PM   #16894
jm-2008
jm-2008's Avatar
Oddometer: 512
[QUOTE=1bigrn;21230238]Big game season is a long way away. But I need to start making plans now.
Depending on what you call a 'Long Gun' found the best option was to sling mine over the shoulder when chasing porkers in the black soil plains country in NSW
Main issue there was the bolt handle, to avoid discomfort it needed to be slung over the left shoulder.
Never managed to build/test them but have seen handlebar mounted bracketts used on quads.
Would need straps/bungees to hold the item in place, much better riding through scrub as it wont get snagged as easily.
JM-2008
jm-2008 is offline   Reply With Quote
Old 04-22-2013, 03:32 PM   #16895
jm-2008
jm-2008's Avatar
Oddometer: 512
[QUOTE=Shibby!;21242573]Damn!
Looks like a thermostat is a definite requirement there!
JM-2008
Old 04-22-2013, 08:24 PM   #16896
brp2004
Orygun
brp2004's Avatar
Oddometer: 200
Sling goes over one shoulder and over your head.
brp2004 is offline   Reply With Quote
Old 04-23-2013, 07:07 AM   #16897
crypto666
Oddometer: 1,277
I strap mine to my pack vertical. I can't see any safe way of putting it on the bike without serious risk of destroying it in a crash.
I also remove the optics and pack them away if the rifle has QD mounts.
crypto666 is offline   Reply With Quote
Old 04-23-2013, 12:17 PM   #16898
Shibby!
Oddometer: 1,658
[QUOTE=jm-2008;21245112]
Originally Posted by Shibby! View Post
Damn!
JM-2008
Actually nobody really uses T-stats here. It's normally pretty slow, technical riding. That picture is about the most wide open it gets. That being said a bike would likely benefit from one, but come summer you'd be wanting to take it out to help that little bit with coolant flow.
Not entirely sure if it was plugged vent lines, freezing air filter, or icing carb but there were times when the jetting would feel off. I know my sled had carb heaters I'd have to turn on in that 0 to -5 temp range and it would clear things up right away. This is my first few winter rides so I'll have to trouble shoot that next fall.
Winter riding in the right snow conditions is a blast though! So much fun! Better yet, clean gear, clean bike. Add gas and go ahead!
Old 04-23-2013, 02:03 PM   #16899
1bigrn
Oddometer: 199
I'm looking to travel down 100k of fire roads at stupid speeds. Not an ideal solution.
1bigrn is offline   Reply With Quote
Old 04-23-2013, 02:10 PM   #16900
bamfslap
Oddometer: 205
When I grab the clutch basket and rotate it left/right, it has some play. Is that normal?
bamfslap is offline   Reply With Quote
Old 04-23-2013, 02:15 PM   #16901
crypto666
Oddometer: 1,277
Get a back pack that you can strap the gun in vertically. I'll post a picture tonight of my setup. That's is the safest way I have found. Most of my guns would never ride with me on a bike; they cost more than the bike.
Like this, but mine is even more basic and can't be drawn without taking the pack off: http://www.eberlestock.com/Tactical%20Master.htm
If you are planning on having something for a quick draw, well I would forget that idea. There is no quick draw with a long gun on a bike, unless its sawed off shotgun like the terminator.
Having the gun mounted to the bike is not an ideal solution in my opinion, there is no good way to do it that I know of.
Old 04-23-2013, 02:16 PM   #16902
crypto666
Oddometer: 1,277
Yes, but how much?
Old 04-23-2013, 02:47 PM   #16903
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,391
Scabbard mounted to the forks? Would be a lot easier with USD forks, but would work with conventional forks if you built stand-off so the forks wouldn't crash into the scabbard on compression. I've thought about how I'd want to carry a gun on a bike and that's how I'd do it.
jesusgatos is offline   Reply With Quote
Old 04-23-2013, 02:53 PM   #16904
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,622
Ordered a michelin T63 130/80-18. Looking for something with a little more life than the Dunlop 606.
I need reassurance I made the right choice.
Jayrod1318 is offline   Reply With Quote
Old 04-23-2013, 03:10 PM   #16905
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,622
http://www.advrider.com/forums/showthread.php?t=623453
Some options
Times are GMT -7.   It's 09:53 PM.
