Old 04-23-2013, 08:56 AM   #76021
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by SoPaRider View Post
Also read a post that claimed the later model DR's now come with allen head screws already installed, anyone else found this to be the case?
Thanks,
Jeff
Sorry Jeff, can't help with bolt size. And yes, I too have read several reports here on this thread on newish DR's stating current NSU bolts are Allen head ... and that they in there fairly tight. Suzuki don't torque them down because the NSU unit is PLASTIC. Loc Tite is your friend. Safety wire it if you like ... but I'm confident Loc Tite is adequate, IMHO.
Old 04-23-2013, 10:29 AM   #76022
sunthechip
Oddometer: 136
Oil level
Hi,
I checked my oil level today. I warmed the bike up for a few minutes, shut the engine off then checked through the sight glass. With the bike vertical, the level was hovering about 2 mm above the lower mark in the sight glass.
Could this have caused any engine damage? I changed the oil 1000 miles ago with 2 quarts of oil and a new filter.
Also, the bike has a small leak opposite the side of the cam bore plug - near the spark plugs. This is probably where some of the oil went. I am going to fix this soon.
Thanks.
sunthechip is offline   Reply With Quote
Old 04-23-2013, 11:06 AM   #76023
procycle
procycle's Avatar
Oddometer: 2,407
As long as the oil is above the minimum you are completely safe. That's what the minimum line is there for.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 04-23-2013, 11:48 AM   #76024
sunthechip
Oddometer: 136
Thank you. Procycle is awesome btw
Old 04-23-2013, 02:35 PM   #76025
Thumper Dan
Oddometer: 328
Mojave Shock
Has anybody tried the new Mojave Shock from Procycle..........probably not as they've only just started selling them.
I spoke to their staff and I'm slightly confused about what the Mojave Shock offers. Staff member said it only has damping control but no compression but has Cogent's new internals (shaft etc all new). Where as the exchanged one (if I sent my stock shock to cogent) has damping and compression. To tell you the truth, I don't understand the two and maybe confusing myself.
Anyway, I'm sure the Mojave has to be an improvement over stock.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 04-23-2013, 04:03 PM   #76026
procycle
procycle's Avatar
Oddometer: 2,407
The Mojave shock has adjustable rebound damping but the compression damping is fixed. There is no prevision to adjust the compression but it could be changed by altering the valve shim stack. This is pretty common for non-reservoir shocks as there is no place to actually put the compression adjuster. The internals are the same as Cogent's 'shock shaft assembly". It's the same stuff that Cogent puts inside their reworked shocks (which ProCycle has also).
Old 04-23-2013, 05:45 PM   #76027
8gv
Oddometer: 2,478
What to do first...
This week I'm picking up a 2008 DR650 which is stock. I'm sure I'll be doing plenty of "improvements" over time to prepare it for my adventures. Until then I'd like to do whatever is needed to prevent getting stuck or blowing up the engine. This is my first priority.
What I think I know:
Neutral position switch loctite? Where?
Chain roller removal...why?
Fuel tap change? To what? Why?
Neutral safety switches?
Can I get some clarity on the above and whatever really matters that I don't know?
8gv is online now   Reply With Quote
Old 04-23-2013, 06:17 PM   #76028
mdrauh
mdrauh's Avatar
Oddometer: 63
Hi,
Thanks.
oops, wrong thread altogether... nevermind.
mdrauh screwed with this post 04-23-2013 at 06:19 PM Reason: wrong number
mdrauh is offline   Reply With Quote
Old 04-23-2013, 07:01 PM   #76029
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,841
Originally Posted by Mambo Dave View Post
Emmbeedee, do you happen to have an exact size for that cotter-pin / pin you're using (if it fits in without makign the castle nut slots larger)?
Old 04-23-2013, 07:04 PM   #76030
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,791
I caught yer post there.
Originally Posted by Emmbeedee View Post
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 04-23-2013, 07:08 PM   #76031
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,841
You're quick!
Old 04-23-2013, 08:37 PM   #76032
Adv Grifter
Oddometer: 6,128
I would go to index thread and start reading. It's all there and very well layed out.
http://www.advrider.com/forums/showp...2&postcount=32
Old 04-23-2013, 08:54 PM   #76033
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,880
Originally Posted by mill View Post
And yes...I will be interested in one of your rebuild kits and "fuel enrichment" plungers to take with me upon my return in July. I will be sending you an email soon. Thank you for your condescending "tone"
Regards
Dick
sorry,
but thats funny
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp is offline   Reply With Quote
Old 04-23-2013, 09:50 PM   #76034
ER70S-2
ER70S-2's Avatar
Oddometer: 6,935
Relax, unless you ride the DR like a 125cc motocrosser, you'll never hurt it.
Neutral position switch loctite? Where? Neutral safety switch?
Same thing. All you'll ever need to know about the NSU.
http://www.advrider.com/forums/showp...7&postcount=15
Because (one of the most reused photos on the internet):
I dunno, still using my stock vacuum petcock at 45,314 miles. There is just no way that I'm going to remember to turn the petcock off every time I park the bike for the night.
It's almost summer here, there's nothing more important.
MBD, that just about covers it.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 04-23-2013 at 09:59 PM
ER70S-2 is online now   Reply With Quote
Old 04-23-2013, 10:45 PM   #76035
8gv
Oddometer: 2,478
Thanks guys!
Times are GMT -7.   It's 03:02 PM.
