Old 04-20-2013, 06:18 AM   #16
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,291
Originally Posted by Cataract2 View Post
Has anyone tried this one?
Well first off, that's only the bottom half. That doesn't include the MC attachment part and looking at Northern Tool, I don't see it listed.
Also, unless they juts aren't showing it as the bottom half looks identical to the HF version, it doesn't have the extended feet that probably make it more stable when bolted down, but even more than that, one of the feet as the bottom half of the bead breaker on it so that is strange.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is online now   Reply With Quote
Old 04-20-2013, 03:47 PM   #17
ggrimes2
Oddometer: 36
Wicked MC tire Changer
www.nomartirechanger.com
I've used one of theirs for many years. This is a basic tire changer made for motorcycle's by motorcycle riders. This has all the features you might need and the price if pretty good. A lot of clubs get together and buy one as a group item.
I now own a small "ranger style" car tire changer that came with the motorcycle attachments. It was made in China and as arrived it was a POS have a friend who's a machinist and we redesigned or fixed all the issues. If I had to pay someone the cost would have been more than the changer was worth. Many is the time I wish I still had the "no mar" manual changer.
If you wish to go into a semi-auto type changer go on-line and see what greg smith has to offer. The sell a lot of bottom end made in China item but they back products and have some quality control checks which insure you don't get total crap. The changer's they sell look just like the one I purchased but they work out of the box which is more than mine did.
ggrimes2 is offline   Reply With Quote
Old 04-23-2013, 02:06 PM   #18
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,313
First off, big thanx to JimVonBaden and BlueLghtning for putting together and sharing the "how-to-use" tutorials.
I bought a HF tire changer and motorcycle adaptor a few years ago, promptly losing the (useless) directions, and have been pondering in fear and ignorance on how to actually use this device. Now I have knowledge, confidence and need to spend more money on blocks and a mount/demount bar.
Incidentally, I was wondering if anyone had used the "lower half" to actually change a car or truck tire?
HapHazard is offline   Reply With Quote
Old 04-23-2013, 02:22 PM   #19
BlueLghtning
Oddometer: 5,291
I changed a 12" & a 14" trailer tire on the main HF unit. I never tried with any kind of car or truck tire though.
Old 04-23-2013, 03:27 PM   #20
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,479
So I watched the video on the Nomar, to change a dirt tire. He uses regular tire spoons to mount and remove the tire, and the device simply holds the wheel in place. Am I missing something? How is that $450 better than the milk crate I use? If it removed and seated the tire easier I could see the benefit. Maybe that's just a dirt tire issue?
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 04-23-2013, 03:52 PM   #21
tntmo
Oddometer: 515
I've changed a lot of car/truck tires with the HF changer. It takes a bit of practice but once you're used to it you can change them pretty quick.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 04-23-2013, 04:05 PM   #22
victor441
victor441's Avatar
Oddometer: 972
I don't have the Nomar but did make my own low $$$ tire changing fixture and having the wheel firmly secured and at waist level makes all the difference, tire changes are much easier. A bead breaker like their attachment is a great help too, especially on big stiff tubeless radials, also made my own from scrap. Those tools along with real tire mounting lube (Ruglyde) and some zip ties (learned to use them in another thread here) have made the whole process relatively easy and eliminated pinched tubes completely. Anyway, IMHO if you change tires fairly often it is well worth buying or building some tools for the job (and much easier on your back too ;-)
victor441 screwed with this post 04-23-2013 at 04:13 PM
victor441 is offline   Reply With Quote
Old 04-23-2013, 04:10 PM   #23
troidus
Oddometer: 15,435
I've mounted nine car tires with mine. Mounting is the cheap part at the tire shop, though--balancing is the expensive part that I can't do at home.
troidus is offline   Reply With Quote
Old 04-23-2013, 05:48 PM   #24
richarddacat
abnormal character
richarddacat's Avatar
Oddometer: 3,452
I'm thinking along the same lines as you, making my own. I'm curious how you secure the rim to keep it from moving?
The idea I have is similar to yours but I was gong to put slots in the base board and run two tie down straps around the spokes through the slots in the base to keep the wheel from twisting on me.
As far as breaking the bead I've found that leaving the wheel on the bike and breaking the bead with a c-clamp has worked pretty good.
Your fab jobs look great
I also use a mixture or liquid body soap and mineral oil for a tire lube.
* 05FJR/88K75c/97M3 *
Mid-TN Tag Riders
richarddacat is offline   Reply With Quote
Old 07-02-2013, 11:25 PM   #25
watchmen
watchmen's Avatar
Oddometer: 247
While searching for alternatives, I found this thread.
Has anyone tried this tire changer? At a quick glance it seems like it has everything you need. I wonder if anyone on here has tried it, I hate to be the first guinea pig.
http://www.ebay.com/itm/Tire-Changer...2be125&vxp=mtr
2000 R1150GS
1994 DR350R
1978 XL125
watchmen is offline   Reply With Quote
Old 07-03-2013, 02:06 AM   #26
mike54
You don't get me
mike54's Avatar
Oddometer: 13,281
Tire changes are easy.
A genius is the one most like himself. - T. Monk via S. Lacy
Do stand up guys lie?
mike54 is offline   Reply With Quote
Old 07-03-2013, 06:32 AM   #27
rustynut2
Oddometer: 494
too small.....
4" to 16.5" Diameter
Work harder, millions on welfare depend on you.
12 T800XC, 14 DRZ 400s
rustynut2 is online now   Reply With Quote
Old 07-03-2013, 06:56 AM   #28
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,503
Originally Posted by rustynut2 View Post
too small.....
I thought that at first too, but I think that is the rim width limitations. I could be wrong as the ad isn't clear. Message the seller. Since it advertises for motorcycles, and almost no motorcycles have under a 17" wheel, I am hopefull.
Otherwise it looks like an OK unit for the price.
Jim
Old 07-03-2013, 02:16 PM   #29
MaestroPNW OP
Me!
MaestroPNW's Avatar
Oddometer: 95
too small.....
I arrived at the same conclusion - judging by the measurements on the pictures, 16.5 looks to ne realistic.
MaestroPNW is offline   Reply With Quote
Old 07-03-2013, 06:34 PM   #30
lesman
Live easy, Brake Hard
lesman's Avatar
Oddometer: 671
My Latest HF ad had a tire changer in it.
Les
Obsessive compulsiveness always trumps good sense.
lesman is offline   Reply With Quote
Times are GMT -7.   It's 06:38 AM.
