Old 04-24-2013, 12:14 AM   #76036
BergDonk
BergDonk's Avatar
Oddometer: 3,925
Originally Posted by deathu View Post
Guys,
I just finished rebuilding the top end of my '98 DR650, and I have this weird carb/jetting(?) issue I can't seem to find an explanation for: when the bike is warmed up, after idling for more than a minute, for example when waiting at a stop light the engine has an hesitation or sometimes just stalls as I try to take off or even blip the throttle in neutral. Sounds to me like running too rich at idle (am I right?). It happens ONLY if the bike idled for some amount of time, like a few minutes. It doesn't happen if it only idled for a few seconds.
I am using the stock BST40 carb with stock components, here is a list of the components I recently replaced (all with brand new stock, OEM parts):
- ALL orings
- pilot jet
- needle jet
- jet needle (6F19)
- plastic spacer under the needle E-ring
- diaphragm
- throttle valve (slide)
- throttle valve guide (with equiv. KTM part, as Suzuki doesn't seem to sell this separately)
- pilot screw (currently set to 1.5 turns out)
The OEM Mikuni #140 main jet is installed ( I did not replace this one) and also I have a new OEM pilot air jet but I wasn't able to get the current one unscrewed from the carb body, it's stuck and seems to just break instead of coming out.
The needle E-ring is installed in the 3rd (standard) position.
I'm using a GSXR 40F0 pipe, with the stock exhaust header, and stock un-cut airbox, the snorkel is also installed. The air filter is a K&N, just cleaned and re-oiled.
Given the carb is clean and float height adjusted properly, what could cause this rich running at idle? I mean in the stock form, the DR650 is known to run a little bit lean. What strikes me is that even with my bone-stock configuration (apart from the exhaust) I have a rich condition and don't understand why... I'm running out of ideas... any help or suggestions would be highly appreciated.
LE. if it matters, we can't get pure gasoline here in Europe. All gas we can get has at least 5% ethanol.
I had a similar issue with my BST40 that I chased unsuccessfully by leaning off the pilot. Fixed it with an FCR. Upon subsequent reflection, I decided it may have been a fuel enrichener aka choke problem. Maybe?
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is online now   Reply With Quote
Old 04-24-2013, 05:14 AM   #76037
deathu
deathu's Avatar
Oddometer: 77
I was thinking about the enrichener as well, that's why I replaced the plunger.
Another thing I omitted to say is I'm using the IMS tank with the locking gas cap. Often when I take off the cap, I can hear the hissing sound and see the tank collapse a little bit, as the pressure is released. Maybe this pressure that builds up in the tank can affect the mixture as well?
deathu is offline   Reply With Quote
Old 04-24-2013, 05:34 AM   #76038
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 928
neutral switch
Is there any down side to completely removing the neutral switch? I have ridden dirt bikes my whole life and dont need a switch to tell me its in gear or not.
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is online now   Reply With Quote
Old 04-24-2013, 06:13 AM   #76039
frecks
frecks's Avatar
Oddometer: 246
Does anybody know what size of bolts the Acerbis handguards use to clamp on to the handlebars? I apparently lost all four of the bolts and I need to replace them before my ride this weekend.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Andrew
2006 Suzuki DR650 (dirt + supermoto)
2010 Triumph Street Triple R
frecks is offline   Reply With Quote
Old 04-24-2013, 06:17 AM   #76040
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,860
That's a good question.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 04-24-2013, 06:59 AM   #76041
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 923
Down side? Not really, I've ridden road bikes and dirt bikes for years without them and though each transmission has its own quirks you quickly learn the feel of it snicking into neutral and then don't even think about it as long as you ride that particular bike. I think neutral lights are more comforting to beginner rider and just a habit for most long term riders.
New Mexico, not really new, not really Mexico.
Carl Childers is offline   Reply With Quote
Old 04-24-2013, 08:10 AM   #76042
Rumlover
Ed
Oddometer: 707
If you do, make sure you also remove the plunger and spring behind the switch.
Check out this article by Elden Carl
http://www.topgunmotorcycles.com/ti_...e/tinov06.html
It's an old article, but the bike hasn't changed much and he carries a little more credibility then I do.
Rumlover screwed with this post 04-24-2013 at 09:10 AM
Rumlover is offline   Reply With Quote
Old 04-24-2013, 08:23 AM   #76043
8gv
Oddometer: 2,521
Is there a requirement to have a neutral light for a bike to be street legal?
If you were to sell it or change states, a close inspection by the DMV/MVD/RMV may reveal its absence.
8gv is offline   Reply With Quote
Old 04-24-2013, 08:40 AM   #76044
mill
mill's Avatar
Oddometer: 49
Originally Posted by Baldy View Post
Great idea. I'd love to see a compelling list of add-ons rated with stars, kinda like we did with book reviews. Once we've got some concensus on all the best products, I'll make a list like that.
Baldy
The neutral switch he is referring to is the neutral safety switch, and has no effect on the indicator light. This switch is only to prohibit the bike from starting if it is in gear and the clutch safety switch is not engaged.
mill is offline   Reply With Quote
Old 04-24-2013, 08:41 AM   #76045
Rumlover
Ed
Oddometer: 707
Worth checking out if you plan on selling the bike or letting others ride it. Of course modifying the clutch switch, side stand switch, non stock brake lights, etc might also be a problem.
Old 04-24-2013, 08:50 AM   #76046
mill
mill's Avatar
Oddometer: 49
Hhhmmm, I could be wrong in regards to his reference. Probably am considering I tend to be wrong quite often
Old 04-24-2013, 09:39 AM   #76047
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,730
Chain roller removal...why? Cuz I said so!
Fuel tap change? To what? Why? Not necessary, but if you do, Yamaha Raptor tap about $20, that's what I use.
Neutral safety switches? Absolutely. The kickstand one cuts the engine when landing off jumps or crossing logs.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 04-24-2013, 10:08 AM   #76048
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Bummer, sorry to hear of the stalling and hesitation. I would try again to get that Pilot Jet out. Maybe soak it with something? Get a really good screw driver on it ... and apply pressure. Also, try tapping on it a few times to break loose the corrosion. It may help.
Other than that ... I don't have a clue. Since you replaced every part in the Carb ... you can only hope they are all correct parts and that you installed them correctly. (which it sounds like you DID!)
I had similar problems a few years back. I found the Mikuni parts were expensive ... I just bought a near new BST40 from an inmate here.
I swapped in my Dyno Jet Needle and 155 main jet (open air box) and has been perfect since.
Best of luck tracking down the problem!
Old 04-24-2013, 10:27 AM   #76049
bross
Where we riding to?
bross's Avatar
Oddometer: 4,699
This week I'm picking up a 2008 DR650 which is stock. I'm sure I'll be doing plenty of "improvements" over time to prepare it for my adventures. Until then I'd like to do whatever is needed to prevent getting stuck or blowing up the engine. This is my first priority.
What I think I know:
Neutral position switch loctite? Where?
Can I get some clarity on the above and whatever really matters that I don't know?
Some of us don't think it's necessary, and here's info for the leave it alone crowd.
http://www.topgunmotorcycles.com/cp_...e/cpnov06.html
http://www.topgunmotorcycles.com/cp_...e/cpaug07.html
Old 04-24-2013, 11:31 AM   #76050
8gv
Oddometer: 2,521
Originally Posted by Rusty Rocket View Post
As far as jumping a DR650 goes...
I have been getting pretty good at jumping on top of my bike as it tries to crush me. That is on a KLR250. I believe this to be an even more important skill for a heavier bike. I've never been too proud to abandon ship when needed.
Intentionally jumping it?
Times are GMT -7.   It's 08:21 PM.
