Old 04-07-2013, 05:19 PM   #451
RSinBC
Oddometer: 214
Wiring
I ran a dedicated set of wires up forward. 30a fuse at the battery, then into a fuse block.
From there you have separate fused circuits to each of your accessories, and can run smaller gauge wire to each.
The fuse block I used has a built in relay, so when the bike is off so is the power to the accessories. I used the stock fan circuit to switch the relay. No dead battery because you forgot to turn something off.
RSinBC is offline   Reply With Quote
Old 04-09-2013, 04:42 AM   #452
Gimme 2
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,142
Fuel filter.
anybody using extra inline filters . And is there a alternative filter to replace the one used in the tank?
Gimme 2 is offline   Reply With Quote
Old 04-09-2013, 06:28 AM   #453
justlookin
Oddometer: 270
Headlight Power
Jason,
The yellow wire connected to the push - pull switch is the main power wire coming forward. I am assuming the small Brown and White wires you are looking at are to the headlight and the White wire is connected to the other side of the switch making it the hot and Brown is ground.
justlookin is offline   Reply With Quote
Old 04-09-2013, 08:16 AM   #454
Jason Abbott
Long time Idaho rider
Jason Abbott's Avatar
Oddometer: 670
Thanks, I think I have it sorted now. The Lynx fairing has a dedicated run to the battery and extra pigtails for switched and unswitched power. I tied into those for the accessories and hardwired the push/pull switch shut since I'm using the Sicass light kit. I'll do a write-up later for others thinking of combining those kits on the XC-W.
Originally Posted by justlookin View Post
Jason, the yellow wire connected to the push - pull switch is the main power wire coming forward. I am assuming the small Brown and White wires you are looking at are to the headlight and the White wire is connected to the other side of the switch making it the hot and Brown is ground.
Photo ride reports: http://trailimage.com/ _
Jason Abbott is offline   Reply With Quote
Old 04-16-2013, 09:04 AM   #455
Jason Abbott
Oddometer: 670
Oil overfill
I guess everyone is out riding.
I idled my bike about a minute with too much oil expecting things to settle in the sight glass. Shouldn't have been a lot too much since I still can't see where I deviated at all from the manual. But anyway, after draining to the right level and about 15 more minutes of riding, still some oil smell from the exhaust and a curl of white smoke when I shut off.
Worry or don't worry?
Old 04-16-2013, 06:40 PM   #456
KrustyKustom
Lets Go....
KrustyKustom's Avatar
Oddometer: 640
How much too much....1/2 a liter or 100ml?
Should not be a big deal if you did not rev the hell out of it. Get a measuring cup for changes, easy 1.5liters.
Krusty Kustom,
Houston Texas
2013 KTM 500exc
KrustyKustom is offline   Reply With Quote
Old 04-17-2013, 09:30 AM   #457
Jason Abbott
Oddometer: 670
Cool. Had to be closer to the 100ml. Rode about an hour last night (pictures!) and the symptoms seemed to go away so I guess it's all good. Thanks for the answer.
Old 04-17-2013, 08:30 PM   #458
Gimme 2
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,142
Check your airbox, pretty sure the over flow comes in just below the intake throat there will be oil sitting in the btm of the airbox and spatter.
Oil is'nt bad but it can foul plugs and carbon build up becomes a problem i suppose if its a constant.
Old 04-20-2013, 04:08 PM   #459
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,043
Drank The Orange CoolAid
The dealer here in Tucson gave me a deal I couldn't turn down.
Thanks to the info here I went with the XCW.
This scoot will be replacing my 300 and my 690, so it will be doing dual sport as well as
single track rides.
A couple of the wrenches at the dealer who ride 530's have had to replace their counter shafts.
They suggest a cush drive at the rear.
This just confirms my experience with a 525 and a Honda xr 650 r, both of which ate sprockets
and chains when dual sported ( ridden on the street )
Anyone had a cush drive wheel built for your 500 ?
I'm thinking a Rad hub.
Twist it, Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 04-20-2013, 06:00 PM   #460
Gimme 2
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,142
single track rides.
Twist it, Max
I'm building one ATM . Ktm hub, as its rubbers last.
Old 04-20-2013, 08:14 PM   #461
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,043
Which KTM cush drive hub fits the 500 ?
Max
Da oggi la strada
senza limiti
Old 04-24-2013, 08:29 AM   #462
c.vestal
Rally On
c.vestal's Avatar
Oddometer: 4,893
Max
I think the 640 ADV? I have one, I am not 100% sure of it's source.
Edit: confirmed, my hub on my 500 is from a 640.
c.vestal is offline   Reply With Quote
Old 04-24-2013, 08:41 AM   #463
LukasM
Oddometer: 5,426
Max
The cush hub used on any 620/625/640/660 LC4 will fit, NOT from the 690 however!
Husaberg FS570 also has the same cush hub if you are looking for a supermoto wheel, comes with a nice tubeless rim.
Old 04-29-2013, 05:31 PM   #464
jonb
Montana Adventurer
jonb's Avatar
Oddometer: 284
Fuel pump for second tank..
Where are people buying their EFI pumps?
I am considering buying the Acerbis and would love to swap the stock and the 5.3 out really quickly but not if the pump costs an arm and a leg.
Anyone found a less expensive pump source?
Thx.
JB
jonb is offline   Reply With Quote
Old 04-29-2013, 05:57 PM   #465
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,043
Thx.
The problem you face is that you need the whole assembly, not just the pump itself.
Those of us who own the 690 have been dealing with faulty pumps and
KTM's policy of only selling the full assembly at a very high price, same for the 990 bikes.
Pumps are available that fit the 690 and the 500 from California Sport Bike
for a little over $100.
To fit out a tank with the full assembly will run around $300 from Munn
or if you have the KTM Talk Team price you will get it for about $270.
That's close to the price of the tank.
Max
Da oggi la strada
senza limiti
Times are GMT -7.   It's 07:02 PM.
