Old 04-23-2013, 04:56 PM   #4111
G600
Oddometer: 461
Originally Posted by JensEskildsen View Post
Regaring Ninja carbs......
Jens, how do you like the Ninja carbs? Big difference?
G600 is offline   Reply With Quote
Old 04-24-2013, 10:21 AM   #4112
JensEskildsen
Oddometer: 1,032
Wide:
I modified the CS-sprocket-cover so I dont have to remove the gearlever when changing sprockets. So yeah, a 5min job aswell.
G600:
I like it, is not a big difference...Well hard to tell anyway. Did the modifying and the jetting over a long period, where it slightly improved from time to time. So I didnt get a big difference just bolteing it up. But it seems better. Also, I got my stock carb tuned in very nicely with a lamdba probe/meassuring-thingy... I actually needed to lean out the mainjets in it. I guess the difference would have been better if I'
ve left the stock carb, well...stock
My bike has almost 120.000km on the stock motor, so compression might be down a bit, which I guess isnt too great with 2x cv carbs. Im sure theese carbs would respond well to an oversize higher compression piston.
Id do it again, I only regret not doing it before i spent a small fortune jetting and dynoing the stock carb.
2003 xt600e 150.000km
1986 xt350 100.000km
JensEskildsen is offline   Reply With Quote
Old 04-24-2013, 12:28 PM   #4113
wide
Oddometer: 390
Cool what did you do to the sprocket cover Jens ??
Honda Transalp 650.. back on the old favorite
XT 600 E... thumping fun but not for motorways
Suzuki DR350... mellow fun but now gone
XR 400 gone
Transalp 600 gone
wide is offline   Reply With Quote
Old 04-24-2013, 03:16 PM   #4114
yamahaman
wannabe bike builder
yamahaman's Avatar
Oddometer: 223
Stock to ninja carb
My stock carbs were not tuned at all. I decided not to waste any time with them and went straight to the ninja carb and I have found there is not a heap of diferance when wide open throttle but there is a huge improvement everywhere else so I am very happy with my change over I just have a little backfiring on deceleration so I will go to a #40 pilot and see how we go
Build it and you will ride
My crazy bike build
yamahaman is offline   Reply With Quote
Old 04-24-2013, 03:48 PM   #4115
thumpthumpthump
Thumpthumpthump
Oddometer: 209
Jens , what was your final jetting on the stock carbs?
thumpthumpthump is offline   Reply With Quote
Old 04-25-2013, 11:08 AM   #4116
bosley1980
Oddometer: 162
Container for first aid kit and tools
Hello ALL,
where I buy something like this
OR THIS
plastic cylinder
please HELP ME?!
THANK YOU
bosley1980 screwed with this post 04-25-2013 at 11:23 AM
bosley1980 is offline   Reply With Quote
Old 04-25-2013, 11:45 AM   #4117
thumpthumpthump
Thumpthumpthump
Oddometer: 209
The DR 650 Suzuki has a tool container like that in the same location.
Old 04-25-2013, 12:11 PM   #4118
thumpthumpthump
Thumpthumpthump
Oddometer: 209
After reading what Jens had discovered from his dyno runs ,I made some changes with awsom results. I am running K&N pods and have had a lot of midrange issues. I am running a 135 in the primary and a 130 in the secondary. I raised the needle all the way in the secondary and wala! Mid range issues are gone. Pulls great from idle all the way to redline. Great throttle response. The exhaust note even sounds different. I still may be running a little rich on top but with summer heat that my be a good thing. Thanks Jen!
Old 04-26-2013, 12:41 AM   #4119
Fred333
Oddometer: 46
Hi Bosley,
go to : ebay.de
type: tooltube
Or: werkzeugfach
or: werkzeugbox
or : werkzeugdose
YouŽll be surprised!
Your footpegs are still great!!!!
Olli
TT 600 36A, 59X, 3SW bastard
Restauration here: http://www.tenere.co.uk/forum/viewtopic.php?f=4&t=82
XT 600 Z Tenere (34L)
Fred333 is offline   Reply With Quote
Old 04-26-2013, 02:29 AM   #4120
KOINZ
KOINZ's Avatar
Oddometer: 34
Originally Posted by bosley1980 View Post
Hello ALL,
OR THIS
plastic cylinder
please HELP ME?!
THANK YOU
You might want to check this adv thread http://www.advrider.com/forums/showthread.php?t=565745
Agri supply tool tubes. I bought two a while back pretty cheap.
KOINZ is offline   Reply With Quote
Old 04-26-2013, 04:32 PM   #4121
steveloomis
Oddometer: 306
Footpegs
Bosley,
I love the footpegs, I haven't gotten the bike finished so have not ridden with them, but they feel great sitting and resting on them. Finish is great, look very strong and durable. I am anxious to try them out.
Steve
84 & 86 ran great in Colorado Sept 2014. Tearing 84 down to hone and inspect cylinder for burning oil. Hopefully new rings will fix.
steveloomis is offline   Reply With Quote
Old 04-27-2013, 11:49 AM   #4122
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
Hello ALL,
OR THIS
plastic cylinder
please HELP ME?!
THANK YOU
I've got an answer I don't think anyone else has given: the second pic is just 4" plumbing pipe (abs or PVC plastic) with one end cap and an unscrewable clean-out end cap. You can make them yourself at the hardware store from parts they have for sale, and make them any length you want.
I've also got a question. What are some opinions on the use of a K&n filter on an otherwise completely stock bike? That's how it came to me. I like the quiet of the stock exhaust and the ease of cleaning and re-oiling of the K&N filter. I know about the performance issue of it needing to breathe easier on both intake and exhaust sides of the engine. Is this stupid? I know about bidegradable-oiled 'no toil' brand filters from a pal who used those on his lot, they are foam, would I perhaps be better off with one of those?
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 04-27-2013, 02:18 PM   #4123
bosley1980
Oddometer: 162
Originally Posted by Fred333 View Post
Hi Bosley,
go to : ebay.de
type: tooltube
Or: werkzeugfach
or: werkzeugbox
or : werkzeugdose
Olli
THANK YOU it is tool tube
Old 04-27-2013, 02:20 PM   #4124
bosley1980
Oddometer: 162
THANK YOU FOR YOUR HELP.
Very useful
Old 04-27-2013, 02:21 PM   #4125
bosley1980
Oddometer: 162
Originally Posted by steveloomis View Post
Bosley,
Steve
And will share photos if you already have done.
When not on here to my mail
Times are GMT -7.   It's 09:16 AM.
