Old 04-20-2013, 10:47 AM   #1
2TICKLASSIC OP
Oddometer: 30
Question one cylinder takes a min to fire up
Hi There
My Suzuki T500 is taking about a good minute to fire up one of the cylinders when I first start it in the morning, after about a minute the other cylinder fires up and then the bike runs fine . I have brand new iridium plugs in it. I'm wondering if this could be a point or condenser problem. I would just like someones opinion before I go in and inspect for point and condenser problems.
Thanks Steve
2TICKLASSIC is offline   Reply With Quote
Old 04-20-2013, 11:14 AM   #2
joexr
Oddometer: 3,773
Check the choke linkage. My '77 had one dual tower coil and CDI so both plugs fired every 180 degrees.
Old 04-20-2013, 11:52 AM   #3
2TICKLASSIC OP
Oddometer: 30
checked linkage (functional)
Old 04-20-2013, 06:38 PM   #4
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,690
Check to see that the enrichener circuit on that carb is clean and getting fuel. You can check for spark at the plug when cold, but this sounds more like a carb problem.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 04-27-2013, 08:40 PM   #5
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,612
My Kawasaki Mach III does this periodically, usually if I set the timing up with a dial gauge it goes away.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Times are GMT -7.   It's 02:10 AM.
