Old 04-27-2013, 02:51 PM   #1
ktmMike OP
roadscout
ktmMike's Avatar
Oddometer: 1,227
Question KTM 530 EXC Speedometer WS
Does anyone know how to re-program the WHEEL SIZE (WS) function on a stock 2011 KTM 530 EXC Speedometer?
I can't find this procedure in the KTM owner's manual, but from past experience, that doesn't mean anything.
I had 2 early KTM 950 Adventures with Speedometers I could re-program for WS, but that info wasn't in the manuals either.
Thanx
SOLUTION ON POST #5. Thanx Knobbythrower and B-Rod.
KTM MIKE . . . . . . . KTM EQUIPPED SINCE 1999
three 640's (sold), two 950's (sold),
530 EXC Supermoto, 690 SMC, 990 SM-R
ktmMike screwed with this post 04-28-2013 at 06:35 AM
ktmMike is offline   Reply With Quote
Old 04-27-2013, 03:42 PM   #2
Knobbiethrower
ADV in ADK
Knobbiethrower's Avatar
Oddometer: 1,261
Press and hold the "o" button on the right until the screen changes and you are able to select different functions on the top and bottom of the readout.
-Press the "o" button to switch from function to function (i.e. A1, S1, WS)
-Select the WS option and use the "+" and "-" buttons on the left hand side to change the overall wheel size
Knobbiethrower is offline   Reply With Quote
Old 04-27-2013, 07:47 PM   #3
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,935
You have to disconnect the speedo from the loom 3 pin connector before you can access the WS.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is online now   Reply With Quote
Old 04-28-2013, 05:33 AM   #4
ktmMike OP
roadscout
ktmMike's Avatar
Oddometer: 1,227
Thank you, but I just tried this method, and WS never came up as an option to choose.
I will now attempt B-rod's method.
Old 04-28-2013, 06:27 AM   #5
ktmMike OP
roadscout
ktmMike's Avatar
Oddometer: 1,227
Yes, that was one of the missing steps!
Now I will be able to switch to supermoto wheels, retaining a "reasonably" accurate speedo.
Here's the whole procedure as I just wrote it into my manual:
Measure circumference of newly mounted tire in mm. (I use a plastic metric Tailor's tape measure to do this).
Remove fairing if necessary.
Disconnect Speedo from harness at 3 prong connector.
Press o to light up display.
Press o repeatedly until H appears.
Hold o down for 3 to 5 seconds.
Press o repeatedly, switching from funtion to function, until WS blinks.
Press + .
Wheelsize appears in 4 digits which corresponds to mm of circumference of mounted tire.
Press + or - until new circumference is reached.
Press o.
Do nothing for 20 seconds, and the new setting is stored automatically.
Thanx Knobbythrower AND B-Rod
Mike
ktmMike screwed with this post 04-28-2013 at 07:17 AM
Times are GMT -7.   It's 12:15 PM.
