Old 12-03-2012, 12:37 PM   #106
ElRod
4<2
ElRod's Avatar
Oddometer: 294
Originally Posted by Spark01 View Post
Finally the crank case breather came in (K&N 62-1110) and i installed it with a self made bracket to the rear throttle body:
Hose routing:
I just received a UNI UP-123 crankcase filter to route away from inside the CPR also. I do not notice in the photos the PCV valve anywhere. Is it needed if not going into the CPR box? If not i will simply cap it in place.
ElRod is offline   Reply With Quote
Old 12-04-2012, 03:20 AM   #107
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
i removed the check valve, that one is just in place to prevent/reduce oil vapors sucked out of the crankcase by the intake.
When you route a breather outside the airfilter there is no need for the check valve any more. And it gives you also a improved breathing surface of 200%.
Hose diameter is 15mm and the check valve connection diameters is only 7,5mm, and with a breather you get the full 15mm diameter
'10 990SMT
Spark01 is offline   Reply With Quote
Old 12-08-2012, 05:17 AM   #108
ElRod
4<2
ElRod's Avatar
Oddometer: 294
The UNI filter has a tab with a hole in it on the bottom for mounting which I used to attach it to the bracket for the MAP sensor. I left the PCV valve attached to the CPR's baseplate and capped it along with a hose clamp. Should have gotten the baseplate without hole for the PCV. Oh well, the reason I did this is that I could hear the ball in the PCV valve "clacking". Annoying. I'll see how messy or not this is going to turn out later.
CCB2 by a99flash, on Flickr
Old 12-08-2012, 09:09 AM   #109
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,806
Are you guys worried about water getting into the engine with those breather filters? I'm not sure how that could happen but would it be a possibility?
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 12-08-2012, 09:13 AM   #110
ElRod
4<2
ElRod's Avatar
Oddometer: 294
Sure, there is the possibility but in my case no. If I'm in that deep I've already screwed up!!!
Old 12-08-2012, 09:29 AM   #111
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,806
I agree, getting that deep in standing water would be a problem for me too. What about water spray during a normal crossing? Or a spill while crossing? I guess that could effect the air filter too. I've not done any deep water crossings with the CPR yet. For that matter I've not ridden in rain either so I've not been able to take a look at secondary water affects. I like getting the breather vent out of the air box, just wonder about how high the vent should be mounter and if its better to include the PCV valve inline.
Moto-Treks
Old 12-08-2012, 10:09 AM   #112
ElRod
4<2
ElRod's Avatar
Oddometer: 294
One of the reasons for a PCV valve, in that it is one way is so that in the event of a backfire through the intake tract it doesn't blow back into the crankcase. Being outside the airbox should be of no consequence in that regard. However, without it you could ingest water, but being at the same level as the throttle bodies I see no benefit. If I were planning on doing a lot of water crossings I'd stay with the stock airbox.
Old 04-15-2013, 05:50 PM   #113
DuctTape
Oddometer: 351
Hi guys.
While I'm waiting for my Safari tanks from CJ I decided to install one of these on my 11 990.
I'm also running the Remus 2-1 and was wondering other then the map (Sounds like moto-treks is included in the download from CPR and should get me close) if there was any new developments I should know about?
Thanks for your time.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 04-15-2013, 07:00 PM   #114
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,806
Originally Posted by DuctTape View Post
Hi guys.
Buy a new rear tire or two
Moto-Treks
Old 04-27-2013, 02:39 PM   #115
chrisf14
chrisf14's Avatar
Oddometer: 206
Crank Case Breather
I think most people that put this filter system are looking for power. Well I no that cool air is power. So running the crank case breather into the air box to me is crazy. Your bike is trying to breath in 200 degree air. No power there!
As for water crossing. NO WAY! I live in Costa Rica and to get to point A to point B I cross rivers. 21,000 miles and no water in my engine. The crank case is pushing air out. Not suck air in.
Dropping it in a deep river? Hell your already screwed. And yes water is going to go in. But the only difference is the other way may take about 3 seconds longer. If it's not air tight then water will get in.
Rode KTM 990s Adventure thru.
USA-48 states
Central America-Mexico, Guatemala, Belize, El Salvidor, Honduras, Nicaragua, Costa Rica, Panama.
Africa-South Africa, Lesotho, Swaziland.
chrisf14 screwed with this post 04-27-2013 at 05:35 PM
chrisf14 is offline   Reply With Quote
Old 04-27-2013, 08:59 PM   #116
DuctTape
Oddometer: 351
CPR installed and Map loaded.
I'm waiting on my K&N filter to get here and I'm just going to leave the hose where it's at and tie the K&N to the frame in front of the CPR where the prefilter on the stock box sat.
I did a lot of watercrossing, mud slinging and rain riding and the prefilter didn't pass water so I don't expect the CPR nor K&N will be a problem. Oil repels water, engines run in 100% humidity and with the addition of the CPR Prefilter I have no worries.
2010 Ducati 1198S
Old 04-28-2013, 02:34 AM   #117
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,355
is it possible to buy the baseplate only.
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 04-28-2013, 07:18 AM   #118
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,055
Is the base plate off a 950 the same as a 990 one?
Just wondering.
rossguzzi is online now   Reply With Quote
Old 04-28-2013, 08:23 AM   #119
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,073
Definitely not.
There i a difference of 1cm in relative distance. The 950 holes need to be closer to each other by 1cm on the symmetrical axle of the motorbike.
Cheers.
gefr is online now   Reply With Quote
Old 04-28-2013, 10:46 AM   #120
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
Hose routing:
the last ride i did, the engine was lightly spitting oil through the breather.
so the balance shaft seal is most likely shot.
so a crank case breather is also easy for detecting these problems
'10 990SMT
Times are GMT -7.   It's 08:02 AM.
