Old 04-28-2013, 12:05 PM   #31
Kommando
Kommando's Avatar
Oddometer: 7,378
Originally Posted by indypup View Post
A little get off while riding in Wayne NF yesterday. I think I had too much air in front tire. I've had a problem of the front end washing out for a while now so any advice from you guys would be appreciated. I do have the forks lowered/pulled up in triple tree about 3/4" and rear shock preload to the max. I'm thinking I have too steep steering angle now. I'm leaning toward suspension setup as problem. :(
If suspension setup and body positioning is good, try running a grippier tire in front than in back. I run an aggressive sand knobby in front and a milder K270 in the rear. The front end carves better in the soft stuff than the rear. I just get my weight forward, turn in, and steer with the gas. The front end carves and the back end comes around and drives it out of the corner.
Kommando is offline   Reply With Quote
Times are GMT -7.   It's 12:11 AM.
