Old 04-17-2013, 10:41 AM   #1
motoracer51 OP
Oddometer: 639
950 Adventure valve clearance question - What would you do?
First time checking the valves on my 2006 950 since I bought it last year.
Bike has 18K miles on it, not sure of the valve check history.
From my understanding the recommended valve clearances should be:
Intake : .10-.15mm
Exhaust: .25-.30mm
All intake and exhaust on front and rear cylinders are measuring .102mm on the intake and .254mm on the exhausts.
I know this is within spec, but do you guys think I should re-shim the valves to get to the loose end of the recommendations?
Thanks!!
motoracer51 is offline   Reply With Quote
Old 04-17-2013, 11:25 AM   #2
SS in Vzla.
Totally Normal? I'm not!
Oddometer: 1,181
It's in-spec. Leave as is, go out and ride.
The shims come in 0.05mm increments. If you re-shim, you will be out of spec.
Yes, you can always grind a shim down to push your clearance more towards the middle of the ideal gap, but I'd leave it alone... It is within spec.
SS. '98 BMW F650 / '06 WR250F / '07 KTM 990 Adv
Caracas, Venezuela
SS in Vzla. is offline   Reply With Quote
Old 04-17-2013, 11:26 AM   #3
motoracer51 OP
Oddometer: 639
The shims come in 0,05mm increments, so re-shimming would put you out of spec. I guess if you really wanted to, you can always grind down the shims to put them within spec more towards the middle of the tolerance, but I'd leave it alone...
I think that's what I was figuring. Not really wanting to make custom shims.
Old 04-17-2013, 12:09 PM   #4
Orangecicle
Orangecicle's Avatar
Oddometer: 2,447
My exact issue this year. All but the front exhausts were barely in spec on the tight side. Left them alone. I reshimmed just the front exhaust, which was tight.
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is online now   Reply With Quote
Old 04-17-2013, 12:18 PM   #5
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Not broke. Don't fix it
S
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 04-17-2013, 09:01 PM   #6
Pete156
I love to eat!
Pete156's Avatar
Oddometer: 1,440
Ride it
530 EXCR
950 ADV S
1000 CBR
200 KDX
___________________________________
humans are the stupidest people on earth
Pete156 is offline   Reply With Quote
Old 04-17-2013, 10:12 PM   #7
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,933
Shim it to the loose end, even if it's a little loose. It will run much better.
"Son, you can't do both"
Old 04-18-2013, 06:36 AM   #8
motoracer51 OP
Oddometer: 639
Just an update.
I shimmed the intakes to the loose end of the recommendations, and left the exhaust alone.
Beginning to put the bike back together. Been sitting, apart, since last July.
I hope I remember where everything goes.
I still have a Facet fuel pump to install, jet kit with remote idle mixture screws, starter torque limiter, and water pump seal and impeller to change out.
Old 04-18-2013, 03:58 PM   #9
bigkuri
bigkuri's Avatar
Oddometer: 724
Originally Posted by motoracer51 View Post
Just an update.
Good man - your valves would have been too tight otherwise... Loose is good.
---------- Current Bike: 2006 Honda XR650R ------------
bigkuri is offline   Reply With Quote
Old 04-28-2013, 06:25 PM   #10
KnowFear
Oddometer: 70
slightly loose outside of spec...
I have a similar question, for a 2006 950:
Front cylinder...
Inlet clearances were .11 and .13 (I'm going leave them alone).
Exhaust clearances are .31 and .32 -- I am very tempted to leave them alone.
Any recommendations?
"Go soothingly on the grease mud, as there lurks the skid demon." (Honda rider manual, 1962)
KnowFear is offline   Reply With Quote
Old 04-28-2013, 06:27 PM   #11
Motomedic
Motomedic's Avatar
Oddometer: 2,468
For the record, Harley V-rod shims come in smaller increments...
(and yes, they are the appropriate diameter )
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is online now   Reply With Quote
Old 04-28-2013, 06:56 PM   #12
kingrj
kingrj's Avatar
Oddometer: 409
Intake : .10-.15mm
Exhaust: .25-.30mm
Thanks!!
Ride that bitch!
kingrj is offline   Reply With Quote
Old 04-28-2013, 08:22 PM   #13
KnowFear
Oddometer: 70
Originally Posted by kingrj View Post
Ride that bitch!
Agreed. But you responded to the original post, not my question. Do you have an opinion on the .31 and .32 observed clearances? Thanks in advance.
Times are GMT -7.   It's 12:03 PM.
