Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 49 votes, 5.00 average. Display Modes
Old 04-09-2013, 05:21 PM   #166
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,373
"Finished", for now...
I think the print quality is great!
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 04-09-2013, 05:55 PM   #167
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,168
Very cool. I just realized how lame my sketchup skills are. When are you doing the sketchup tutorial thread?
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 04-09-2013, 06:08 PM   #168
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,373
Sketchucation.
Have fun!
Seriously though... Just keep piddling around with it. I'm lucky in that I have to show 7th and 8th graders how to use it, 3 times a year. You learn fast that way.
-Charles De Mar.
Old 04-09-2013, 06:15 PM   #169
slackmeyer
slackmeyer's Avatar
Oddometer: 3,168
Originally Posted by dorkpunch View Post
Sketchucation.
Have fun!
I've actually been using sketchup since it was first offered for free, quite a few years ago. . . but I just use it for architectural stuff and some furniture design. I've never used a plugin, don't know what I'm missing as far as that goes, and seeing you do the wireframe shells like that is pretty impressive. I'll look at that link . . . .
Zak
ktm
old bmw
others
Old 04-09-2013, 06:59 PM   #170
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,373
The wire frame was surprisingly easy- the hard part was giving it a "thickness". Took a fair bit of time to clean it up and make it manifold- no holes- so it would print.
Have you ever played around on the google warehouse?
-Charles De Mar.
Old 04-09-2013, 08:16 PM   #171
slackmeyer
slackmeyer's Avatar
Oddometer: 3,168
I've looked through there a few years ago, I think I used some standard stuff- sinks, chairs, appliances to flesh out some drawings, but that's it. Just what I need for work stuff. Also, my computer is a 5 year old basic laptop, so when I put too many textures in sketchup and try to rotate things, stuff goes south and I get frustrated.
Zak
ktm
old bmw
others
Old 04-09-2013, 08:30 PM   #172
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,373
I hear you... We've got computers that are at LEAST 5 years old at school- my students tend to get frustrated with the lock ups real easy. We put off textures / coloring to the very end, seems to help a little.
-Charles De Mar.
Old 04-10-2013, 06:40 PM   #173
mud
I just wander.....
mud's Avatar
Oddometer: 1,842
For those interested.
http://www.digitaltrends.com/home-th...or-turntables/
2007 Factory Husaberg 380FE
1984 Husqvarna 500AE
mud is offline   Reply With Quote
Old 04-10-2013, 08:00 PM   #174
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,373
More experimenting...
Tried my had at "Acetone Fuming". Basically, you let the fumes from acetone melt the printed part a little bit to smooth things out.
First attempt involved a tupperware container, some acetone, and a few hours of soak time. Didn't work out so well- the part was fairly thin walled and it just crumpled up.
Second attempt I tried it again the same way on a thicker part... but gave up after about an hour.
Part:
Fuming set up:
Did a little more research and learned a few more things. HEAT helps this process out a LOT. Speeds it up and seems to make the whole part flow out more evenly.
First step was to build me a catch plate. Took an old hanger and a grass screen from a Briggs & Stratton lawnmower engine, and bent 'em up.
Theory being the part will sit on a piece of pipe up out of the acetone, the catch tray will sit in the acetone until I'm ready to take the part out, like so.
Found an old #10 can, put maybe half an inch of acetone in the bottom, and put the whole thing on my printer bed. Turned the bed heater on and set it to 90 degrees C.
Once it was warmed up, I set the pipe, catch tray, and part in there.
Quick cover out of tin foil.
It was weird, you can't see anything but when you stick your hand in there you can feel instantly where the fumes are- they condense on your skin and your skin gets cold.
10 minutes in.
I probably should have heated it up more before I put the part in. Eventually it got warm enough that the acetone started to "boil".
About 20 minutes in.
Short vid of the fuming:
Part out, after roughly 25 minutes of cooking and 15 minutes of "cooling down" in the can.
Another 10 minutes and the part has started to get harder again. Still soft enough that if I squished it it would leave finger prints.
Bottom, where it sat on the pipe. I have an idea for this I'll show you in a bit...
Finished part on the right, first attempt on the left. Came out pretty nice! The part is MUCH smoother and a whole lot shinier.
I think it would work a lot better if I had let the acetone heat up more before I put the part in- the bottom half looks really good, the top half didn't get as much exposure and it's not as smooth.
-Charles De Mar.
dorkpunch screwed with this post 04-10-2013 at 08:35 PM
Old 04-24-2013, 03:55 PM   #175
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,373
Students have finished up their projects for the most part so I started printing a few of their cars.
4 down, 33 to go.
Not bad though for a bunch of grade 7's!
-Charles De Mar.
Old 04-25-2013, 11:23 AM   #176
garandman
Wandering Minstrel
Oddometer: 6,341
You can usually just dip them quickly. Weld-On 3 is what we use but it might be even nastier than acetone.
As Acetone is highly flammable (let alone a carcinogen) we have no plans to try it as a heated vapor.
2012 WR250R, 2009 TW200, 2008 Tiger 1050 ABS, 2008 CRF100F
“The problem in defense is how far you can go without destroying from within what you are trying to defend from without.” ― Dwight D. Eisenhower
garandman is offline   Reply With Quote
Old 04-25-2013, 12:20 PM   #177
Ridemuch
SUP
Ridemuch's Avatar
Oddometer: 2,271
Don't know if it been on here before but there are some free 3D models on there.
I like the BMW bike myself.
http://www.creativebloq.com/3d/free-3d-models-10121127
"Ya Rob, well she either gets used to the fact that I ride pretty much every weekend or she needs to find herself another boyfriend" KTMike
"There is no bad weather, only bad gear." Dahveed
Ridemuch is offline   Reply With Quote
Old 04-25-2013, 05:46 PM   #178
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,373
Ran the Mendelmax 2.0 just about 8 hours straight today. Students have finished their projects so it's time to get them printed!
Just running 4 at a time so far. Takes between 2 1/2 to 3 hrs for 4 cars. Speeds are about midrange to get a little better quality but still knock 'em out fast(ish).
16 down, 17 to go.
-Charles De Mar.
Old 04-28-2013, 07:46 PM   #179
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,373
Our school district PR guy came to my class last week to take pics... Heres the scoop.
Students finishing up their Sketchup projects.
The printer... Y'all have seen it before it here it is in it's "home".
The heli's final resting place.
Edumication. Walked them through the process of exporting the file from Sketchup as an .stl, repairing it in Netfabb, and finally loading and positioning in Repetier.
Explained to them how Slic3r worked and showed them a few of the basic settings, then we sliced. They were pretty impressed that we generated 18,000 lines of code for one simple car. It was fun to make them think math for a bit- vectors / coordinates on an X/Y grid, and explain to them a few different g-codes and how the computer interpreted them the same way they do in their math classes.
Business end of the printer all set up and ready to go.
One of my most useful tools- a webcam, duct taped to a light arm. I can point it anywhere (including my monitor) so they can see what I'm doing up close on the screen without having to crowd around me.
What they see on the screen:
Annndd..... PRINT!
Not real great quality because I had the speeds cranked way up so they could see it finished during class.
Got a bunch more done- up to 26. Have just a few to finish up and then we start printing wheels.
The students love watching the printer run... We had a test on sketchup / printers on Friday, which I haven't had a chance to look through yet but one of the questions was about what they thought the future would bring to the 3D printing scene. Kind of excited to see what they think!
-Charles De Mar.
dorkpunch screwed with this post 04-28-2013 at 07:56 PM
Old 04-28-2013, 08:53 PM   #180
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,373
Two more pics of my ugly mug.
Explain some of the capabilities- manufacturing custom parts for Hotwheels.
Yeah, this pic... "BEHAVE, or I shall turn you into this vile blue goo!"
-Charles De Mar.
Thread Tools
Times are GMT -7.   It's 01:09 AM.
