Old 04-23-2013, 02:15 PM   #1
emerson.biguns OP
All idiot, no savant
emerson.biguns's Avatar
Oddometer: 10,422
Pre-Fab Panel Material/System
I need to build a bulkhead in the CreepyEuroStalkerVan and I'd like to find a rigid, light material. I've thought about laminating some blue insulation foam with 1/4" ply, but was hoping there might be something available off the shelf. I'd like to be able to hang some heavy stuff on the cargo side and cover the cabin side with carpet.
Desired qualities:
Light
Rigid
Thickness - 1/2"-2"
Insulating
air tight (gas fumes)
Any ideas?
emerson.biguns is offline   Reply With Quote
Old 04-23-2013, 02:24 PM   #2
boardrider247
Weekend Anarchist
boardrider247's Avatar
Oddometer: 768
Nida core
http://nida-core.com/english/index.php
You used to be able to order it directly through them. However it appears that 3M purchased the company now. Which means you would have to go through a 3M/nida core dealer.
Lots of variations. But the balsa lite would be closest to your plywood/blue foam panel.
Honestly it's pretty cool stuff, I ordered the sample kit just to check it out.
Life is a waste of time, Surfing is a great way to waste it
boardrider247 is online now   Reply With Quote
Old 04-23-2013, 02:35 PM   #3
mark883
Holding up Michoagán
Oddometer: 1,612
Find someone that's torn out a modern walk in cooler?
However, no structural 'guts' to it for hanging things?
DIY might be the best way to go. You could laminate on that white fiberglass 'bathroom wall material', but again, no structural value there either, other than 'better than foam'
mark883 is offline   Reply With Quote
Old 04-23-2013, 03:30 PM   #4
Manuel Garcia O'Kely
Back at last
Manuel Garcia O'Kely's Avatar
Oddometer: 13,308
Probably easier to use a layer of half inch on back, quarter on front, frame to brace and mount, holes in quarter side to shoot voids with expanding foam including sealing front from rear, then install green shag carpet.
Never ascribe to Evil that which is more resonably explained by Ignorance and Stupidity
There's casting, then there's running into the stream with a baseball bat trying to club the fish to death. - Jim Moore
Manuel Garcia O'Kely is offline   Reply With Quote
Old 04-23-2013, 03:55 PM   #5
emerson.biguns OP
Oddometer: 10,422
Originally Posted by boardrider247 View Post
Nida core
Interesting. Didn't look easily available, but that got me some better search terms.
Came across Decolite which may work, if I can find it and the price is right.
Old 04-28-2013, 05:02 PM   #6
boardrider247
Weekend Anarchist
Oddometer: 768
I agree I was pretty disappointed when I looked at their site now.
Before 3M bought them you could order all of their products directly from nida core.
Old 04-28-2013, 07:16 PM   #7
emerson.biguns OP
Oddometer: 10,422
Doesn't look like anything is going to be simple or easily available.
Old 04-28-2013, 10:38 PM   #8
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,132
Honestly, your original idea is a good one, and it's going to be faster/easier/cheaper than finding just the right material in this situation. 1" polystyrene foam, 1/2" or 1/4" maple or birch plywood skin, 2x2s ripped down to 1" thick for a frame, and some construction adhesive/disposable notched trowel and screws. The 1/2" vs 1/4" ply skins would really just be about how much stuff you wanted to hang on this wall.
I've made some garage carriage doors this way before, worked great.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 07:30 AM.
